1 Reply Latest reply on Jan 16, 2007 12:30 AM by WestSide
    Loop over multiple Objects and Populate Datagrid?
    WestSide Level 1
      Any help on this would be highly appreciated. I think I am almost there.
      I am new to Flex and trying to populate this datagrid from a result that I get from a remote call. Basically I traced my result and I see the following in the console:
      [object Object],[object Object]
      Which is correct. So it appears I have an array of objects. I want to populate each row in the datagrid with the data contained in the array.
      So in my code the following is a reference to the "whole" array.
      trace(ApplicationState.instance.employeesArray);
      I want to take this "employeesArray" and populate the datagrid. Or should I assign this "ApplicationState.instance.employeesArray" to some private var and then assign the private var to my datagrid as the provider??
      How can I do this?
      -Westside
