I have found online a tutorial to flip am movie clip like a card. I'm playing around with it seeing if I can flip multiple movie clips (one after another), and then see/experiment with changing the content inside when it ha flipped to the other side.
Right now I'm having a bit of a problem with the multiple. I set up another Movieclip the same as the orig, and set up the script to flip and switch mc
(using timer). The original mc works fine, the other tens to shift (off center), and the two mc in the container slightly separate. Im unsure is the problem lies in the code, or how I built the other MC. I can't see how to attach the flash file to see, heres the script and some images.
import fl.transitions.easing.*;
import fl.transitions.TweenEvent;
import flash.events.Event;
import fl.transitions.Tween;
stop();
//con.sidea.flip.addEventListener (MouseEvent.CLICK,onflip);
//con.sideb.flip.addEventListener (MouseEvent.CLICK,onflip);
addEventListener(Event.ENTER_FRAME, loop);
var isStill:Boolean = true;
var arraytween:Array = new Array();
var tweenside = con
var flipside:String = "righthandside"
function onflip (e:Event)
if (isStill)
arraytween.push(new Tween(con,'rotationY',Strong.easeOut,con.rotationY,con.rotationY+180,4, true));
arraytween[0].addEventListener(TweenEvent.MOTION_FINISH,reset);
function reset(e:Event)
isStill = true;
arraytween = [];
if (flipside == "righthandside")
{flipside = "lefthandside"; tweenside = con2}
else
{flipside = "righthandside"; tweenside = con}
//var myTimer:Timer = new Timer(5000,1);
//myTimer.addEventListener(TimerEvent.TIMER, nextframe);
//myTimer.start()
function loop(e:Event)
if (tweenside.rotationY>=90 && con.rotationY<=270)
tweenside.addChild(con.sideb)
tweenside.scaleX=-1
else
tweenside.addChild(con.sidea);
tweenside.scaleX=1
if(tweenside.rotationY>=360)
tweenside.rotationY=0;
var flipit:Timer = new Timer(5000,10);
flipit.addEventListener(TimerEvent.TIMER, theflip);
function theflip (e:TimerEvent):void
arraytween.push(new Tween(tweenside,'rotationY',Strong.easeOut,con.rotationY,con.rotationY+180,1, true));
flipit.start();
clickTAG_btn.addEventListener(MouseEvent.MOUSE_UP, function(event: MouseEvent): void {
var sURL: String;
if ((sURL = root.loaderInfo.parameters.clickTAG)) {
navigateToURL(new URLRequest(sURL), "_blank");
The only properties of the movieclips that this code deals with are the scaleX and rotationY. So, if the movieclip seems to be out of alignment at the end of the animation, I'm guessing that the registration point of the movieclip is not at its center.
check your transform points. you probably want them to be in the center of each flipping card.
also, all tweens are much easier using greensocks tween libraries (eg, tweenlite).
