5 Replies Latest reply on May 22, 2015 12:57 AM by VeluVK
    Soft enters for table column head breakup
    VeluVK Level 1
      Can i have any option for the the below requirement?
      I need to give soft enters for all table column head breakup's. (see the below screen shot). When i export to HTML the column heads are run-in against the PDF output.
      Regards,
      Velu
        • 1. Re: Soft enters for table column head breakup
          Stefan Rakete Level 2
          place your cursor in the cell and start this script. Hope this helps:
          var curSel = app.selection[0];
          var curParentCell = curSel.parent;
          var curCellText = curParentCell.texts[0];
          var allLines = curCellText.lines;
          for (var i=0; i<allLines.length-1; i++) {
              var curLine = allLines[i];
              curLine.insertionPoints.lastItem().contents = "\n";
          • 2. Re: Soft enters for table column head breakup
            VeluVK Level 1
            Hi Steven,
            Thanks for your script. I will check it.
            Regards,
            Velu
            • 3. Re: Soft enters for table column head breakup
              VeluVK Level 1
              Steve,
              Script working fine. if there any possibilities to change the entire file.
              Applied Column head style is "TCH"
              Regards,
              Velu
              • 4. Re: Soft enters for table column head breakup
                Kai Rübsamen Level 4
                Hi Velu,
                try the following:
                var curDoc = app.activeDocument;
                var allTables = curDoc.stories.everyItem().tables.everyItem();
                app.findTextPreferences = app.changeTextPreferences = null;
                app.findTextPreferences.appliedParagraphStyle = curDoc.paragraphStyles.itemByName("TCH");
                var allFounds = allTables.findText();
                for ( var i = 0; i < allFounds.length; i++ ) {
                    var tableFound = allFounds[i];
                    if ( tableFound.length > 0 ) {
                        for ( var j = 0; j < tableFound.length; j++ ) {
                            var curFound = tableFound[j];
                                    var allParaLines = curFound.lines;
                                    for (var n = allParaLines.length-2; n >= 0 ; n--) {
                                        var curLine = allParaLines[n];
                                        if (curLine.characters[-1].contents != SpecialCharacters.FORCED_LINE_BREAK) {
                                            curLine.insertionPoints[-1].contents = "\n";
                                        } // end if
                                    } // end for
                        } // end for
                    } // end if
                } // end for
                –Kai
                • 5. Re: Soft enters for table column head breakup
                  VeluVK Level 1
                  Hi Kai,
                  Script is working fine.
                  Thanks for the update.
                  Regards,
                  Velu
