3 Replies Latest reply on Jan 16, 2007 11:06 AM by oscar7878
    help creating a path using variables.
    oscar7878
      HI
      I;m trying to create a path to a movievclip created with attachMovie. I need tio create the path using variable:
      _root.var1.var2.gotoAndPlay("something");
      How can I tell flash that var1, var2, etc are variables and not a relative path?
      Tks,
        • 1. Re: help creating a path using variables.
          willie_lee
          Hello Tks,
          depending where the movieclip is that you are trying communicate with you need to use either other movieclips or you will need to use _parent.
          var gong:MovieClip;
          var bong:MovieClip;
          var song:MovieClip;
          this.attachMovie("gong".....
          gong.attachMovie("bong"....
          bong.attachMovie("song"...
          to access song from the timeline in which all these movie clips were attached
          this.gong.bong.song.variable
          from song to the timeline in which all movie clips were attached
          song._parent._parent._parent.variable
          Hope this helps..
          moozungu
          • 2. Re: help creating a path using variables.
            jonnybennett Level 1
            rootTimeline=_root;
            // You can set var1 or var2 to what you like.
            var1='mc2';
            var2='mc3';
            rootTimeline[var1][var2].gotoAndPlay("something");
            //I think that is what you wanted to do?
            • 3. Re: help creating a path using variables.
              oscar7878 Level 1
              Hi and thank you for your reply.
              I'm creating the movie clips using actionscript. The path to each movie clip is different each time. I dont need to call variable inside a movieClip i need define the path. so:
              in your example:
              Then
              var var1:String =gong;
              var var2:String =bong;
              var var3:String =song;
              I need to create the path to access "song" and gotoAndPlay("something") inside "Song"
              _root.var1.var2..var3.gotoAndPlay("something");
              tks
