2 Replies Latest reply on Apr 20, 2015 1:39 PM by CFJSGeekOmaha
    RDS "For input string" Error
    CFJSGeekOmaha
      I have ColdFusion 11 U4 running as a Amazon EC2 instance from Adobe's Windows AMI.
      I am trying to connect via ColdFusion Builder 3 (mine) and ColdFusion Studio (client's). At first I got the dreaded 404 error, so I added in /CFIDE/main/ide.cfm as an empty file so IIS would find it.
      Now the error has changed to: 'Unable to contact the RDS Server... For input string: ""' in CF Builder.
      In ColdFusion Studio the error was "server operation failure". After debugging was turned off it changed to "unhandled error, use logging enabled clients if possible."
      I had HTTP filter restrictions in place for CFIDE directory stuff, but removed all that, no change. I have also tried all three options for user authentication for RDS.
      I also tried it on my local machine but after I resolved the 404 error I get a 405 error for method not allowed. So that's no help either.
      Here's the settings:
      Description: {client name}
      Host name: {IP Address}
      Port Number: 80
      Timeout: 30s
      Context Root: empty
      User Name: {user name}
      Password: {password}
      Thanks in advance.
        • 1. Re: RDS "For input string" Error
          charlie@carehart.org Adobe Community Professional & MVP
          CFJSGeek, to be clear, the “method not allowed” is actually a GOOD thing. It confirms that, in that dev environment at least, your browser WAS able to get to RDS, but it’s setup to not allow a GET (which is what your browser sends by default). Are you saying you proceeded to setup CFB or CFS to point to that dev environment and it still didn’t work? Or did you misinterpret that message in your browser and stop there?
          As for your other environment, let me say first that you do NOT need to add an empty CFIDE/main/ide.cfm. Instead, that request gets processed by CF as a servlet filter. There is no need for that file to exist.
          That said, yes if you block the CFIDE folder (in IIS, for instance, if that’s what you mean by “http filter”), then yes it would fail.
          And it shouldn’t matter whether debugging is on or not. As for the message you get when you say you turned it off, “unhandled error, use logging enabled clients if possible”, that’s one I never heard of, and I’ve been using the RDS feature (and helping people use it) for over 15 years, in CFS, HS, DW, and CFB. But I do see in googling that message that an old JRun Studio FAQ (it was an off-shoot of CFS) indicates that could happen if you have an invalid password.
          Do you have the CF admin RDS security settings to “single password”, “separate username and password”, or “no password” (the latter would be dangerous on any public server, but of course having RDS at all on a public server would be worrisome). Are you positive you’re using the password defined there in the configuration of RDS in HS? Also, you mention using a username and password, which presumes then you need to have changed to “separate username and password”, and defined such a user in the “user manager” page of the CF Admin. You also need to give that user RDS access there, of course.
          Can you confirm all these things, and we can try to go from there?
          /charlie
          • 2. Re: RDS "For input string" Error
            CFJSGeekOmaha Level 1
            Thanks for the response Charlie. Right now I'm going to focus on the ColdFusion Studio environment issue.
            I added the blank CFIDE/main/ide.cfm file because otherwise it would give me a 404 error. I know you can also set IIS to not check is a file exists, but I opted for this solution. If there is a better fix for this I'm all ears.
            I will have the guy double check his password again. I've been trying "separate username and password" with him but I'll give "single password" a shot. I'm wonder if because CFS is so old that it didn't support separate logins.
            Chris
