3 Replies Latest reply on Apr 21, 2015 1:26 PM by clauderozsa
    Problem linking a video clip to a 3D element in After effects
    clauderozsa Level 1
      Good morning
      In the following picture from my project I want to link the fire to the basin in front of the statue. The camera pans up when approaching the statue and at this moment my fire flies up!!! :oops:
      The temple is a unique group I built in Element 3D . The fire consists of three layers of a clip from Videocopilot action essentials 2.
      At first I thought of tracking the clip or the temple, but for the clip it's impossible as its background is black and Mocha doesn't load the Temple Element layer. AE gives me the only Mocha tracker as an option for tracking here but doesn't seem to recognize the 3D group element.
      I thought of creating a group null in Element 3D but I can't find the resulting null in the workspace...It's lost somewhere into space!
      So I must be very dumb but I do not see how to solve my problem. I've checked different tutorials and experienced some of the proposed solutions without success.
      Could anyone suggest a solution or explain me which of the above could do and how?
      Thanks in advance
      Claude
        • 1. Re: Problem linking a video clip to a 3D element in After effects
          If you want to track multiple layers or layers with an effect you must first pre-compose them. If you want to use Mocha then you have to Pre-render them. If you have a camera move you can use expressions to analyze the move but since we know very little about your composition I can't begin to suggest what you should be doing. Here's how to easily tell us all about your comp. Select all of the layers in the time line that are important to the shot. Press the "u" key twice. This will reveal all modified properties. If an effect is applied to a layer that may be causing problems then make sure the Effects Control Panel is visible for that layer or layers. Now take a screenshot. If you need to reduce the size of your Composition Panel to 50% or even 25% to fit things in do that. Now drag the screenshot to the Reply field on this forum and describe in detail what you are trying to do.
          • 2. Re: Problem linking a video clip to a 3D element in After effects
            clauderozsa Level 1
            Hi Rick, sorry to react late to your message; I'm testing suggestions made by the forum of videocopilot to which I presented my problem too. I haven't finished using their ideas but as soon as I draw conclusions of their suggestions I'll let you know and eventually develop here my problem as you suggested it.
            Claude
            • 3. Re: Problem linking a video clip to a 3D element in After effects
              clauderozsa Level 1
              Hi Rick,
              I found the solution to my problem. In fact I had watched a tutorial which explained this with a green screen and had completely forgotten it. Here is the link
              to the video. Its the equivalent of linking to  the classic link to a null in 2D; there you take advantage of being able to use group null. I just had to take out the basin from the temple and create a group for its own and then create the group null and apply to the clip the position of the null. So the temple is finished and I"ll go on to another part of my scenario! Thanks anyway. Claude
