1 Reply Latest reply on Feb 1, 2007 9:40 PM by m gupta
    connection timeout
    bit_thick
      One of my contribute sites seems to timeout after about two minutes when users are editing pages. There's no error message and it reconnects straight away when you click connect but it's obviously frustrating. I've checked all the ftp settings and they are exactly the same as another site which is working fine. Are there any other settings I need to change anywhere?
      Thanksl
        • 1. Re: connection timeout
          m gupta
          Is the other site which is working fine is using the same FTP server?
          In case if you have any settings like "Idle Time out" set for the FTP server which is getting used and if there is no data transfer for that time then FTP server will assume that the connection has timed out and disconnect.
          If it is set, then increasing the time will help.
          Manoj
