3 Replies Latest reply on Jan 29, 2007 8:23 AM by SymTsb
    I have a preloader, but...
      I have an mp3 file in a Flash movie using Flash MX.
      The movie purely consists of the mp3 file and a stop and play button.
      I would like the music (or movie) to play when 50% loaded and I am searching the net to find a way.
      I already have a preloader which works perfectly using the following actionscript...but I'd like to know what to tweak in order to make the music (movie) play when 50% loaded. My current action script is as follows...
      lBytes = _root.getBytesLoaded();
      tBytes = _root.getBytesTotal();
      percentLoaded = Math.floor((lBytes/tBytes)*100);
      loader.bar._xscale = percentLoaded;
      loader.percent.text = percentLoaded + "% of " + Math.floor(tBytes/1024) + "K loaded.";
      if (lBytes>=tBytes && tBytes>0) {
      if (count>=12) {
      } else {
      } else {
      ....I know that there are other ways of playing mp3 on Flash (ie. Media Playback Component and a multitude of templates on the net) however I find that the Flash players that load the mp3 externally play at different speeds in different browers, so becuase of this I choose to have the mp3 located within the flash movie to avoid any inconsistancies amongst browsers. All I require is actionscript that makes the music (or movie) play when 50% loaded.
      I'm gonna continue to search for an answer, and if I find a solution I will update my post.
      You can see the swf file in the following htm page...
        • 1. Re: I have a preloader, but...
          SymTsb Level 2
          The thing you need to remember about sound in Flash is that Flash will resample the audio to a rate it supports so either 44, 22 or 11. This way, you can use the Sound Class to load your mp3s.
          About your preloader though...
          • 2. Re: I have a preloader, but...
            racky Level 1
            Thanks for the info.
            I tried the action script provided, but it didn't work...maybe I inserted it in the wrong place.
            Anyhow, I am currently trying out your other suggestion. I'm in the process of creating the mp3 with 44HZ.
            If that doesn't work (fingers crossed it will), I will have another play around with the action script.
            • 3. Re: I have a preloader, but...
              SymTsb Level 2
              the conditional test should be if(percentL >= 50) sorry. was tired writing this. lol. the current test would always fail. hence the reason the code is not working.
