I would like to know how can I compile a XPJ project in
Command Line (CLI mode) to get two different ouputs using
conditional Build Tags ? I checked the Help Files
Usage: RHCL [-?] project [-l layout_name] [-p
[server_name[:user_name:password]]
[-o output_folder_name] [-d]
Option Description:
project Specifies a RoboHelp project file .xpj.
-l Specifies a layout name.
Primary layout is used by default.
-p Specifies publishing server with optional username and
password.
If no server name is specified after -p, RHCL will publish
the result
to all servers that are available to the layout.
-o Specifies output folder name.
The layout's default output folder is used by default.
-d Displays all layout name(s) and publishing server name(s).
-b Generates all layouts set for batch generation in the
project.
-g Log File name.
-?, -h Requests online help.
There is no configuration for Conditional Tag ,
Do I have to manually open the XPJ project in robohelp and
then change the Conditional Tag and save the project. If this is
the only way is it not a limitation in CLI feature ?
Please let me know if there is any better way for the above
issue ?
Regards,
Yogesh
