I am new to framemaker. We have a list of Framemaker document files (*.fm files) coming into a folder. We need to pick up these files and convert to xml format (same as the saveAs opertion from the File menu).
I have written the follwing function to Save fm files to xml
Code to Save fm files to xml files |
function saveAsXml (doc) { // Get required parameters for the save function. var params = GetSaveDefaultParams(); var returnParamsp = new PropVals();
// Replace the .fm extension with .mif. var saveName = doc.Name.replace (/\.[^\.\\]+$/,".xml");
var i = GetPropIndex(params, Constants.FS_FileType); params.propVal.ival = Constants.FV_SaveFmtXml; // Save the document as XML. doc.Save(saveName, params, returnParamsp); } |
How to automate this process so that code checks -
1) New fm files in the folder
2) Saves the fm file as xml
3) Moves the saved fm file to a different folder
GC
[Message moved to Scripting Forum by moderator]
Have a look at the sample script below. The "while" loop waits for the specified number of milliseconds, then reads the contents of a directory and processes every individual file in the directory. In my example, it just prints the file path to the console. You would replace this part with your Open / Save as / Move sequence.
For more file system commands, refer to Adobe's Javascript Tools Guide, "File object functions".
var stop = false;
while( stop==false ) {
// Wait for 20.000 ms
$.sleep(20000);
var fld = new Folder("c:/incoming");
var filesInFld = fld.getFiles("*.fm");
for(var f=0; f < filesInFld.length; f++) {
// process the individual file
$.writeln(filesInFld
// Exit the loop after 19:00
var time = new Date();
if( time.getHours() > 19 ) stop = true;
JoH's script is good but it may eventually time out or run out of memory. Where are the .fm files coming from? A better approach may be to have a script on their machine that will automatically save and send an XML file to the incoming folder whenever they close the .fm document.
