3 Replies Latest reply on Apr 23, 2015 2:25 PM by Capital Mailing Services
    DataMerge to a pdf not in memory InDesign(cc2014) JavaScript
      I am having an issue with the file merging in ram not to a pdf document.
      When I am merging 20 thousand records having it merge in ram not only takes for ever it some times runs out of ram.
      any ideas? This is my Current code.
                    var jobNumber = prompt("what is your job number");
                   // Setting the Folder to get the indesign and the Data File file from.
                  var myTemplateFolder = Folder("~/Documents/hotfolder/template/");
                  var myDataFolder = Folder ("~/Documents/hotfolder/data/");
                  // Retrieving the Indesign FIle
                  var myTemplates = myTemplateFolder.getFiles("*.indd");
                  var myDataSet = myDataFolder.getFiles("*.csv");
                  //Open the Template and Declare its value of myDocument
                  var myDocument = app.open(File( myTemplates ));
                  // Turning on the BackGround Layer For Proofing
                  var myLayer = app.documents.item(0).layers.item("Background");
                  myLayer.visible = false ;
                  //Setting the data source to be merged
                  myDocument.dataMergeProperties.selectDataSource(File(myDataSet));
                  // Merging the Records and creating the overset text document to make sure nothing is wrong with the file.
                  myDocument.dataMergeProperties.mergeRecords(File("~/Documents/hotfolder/output/"+ jobNumber+"-composedoverset.txt"));
                  //close the unmerged document.
                  myDocument.close(SaveOptions.no);
                  //Exporting the merged document as composed file
                  app.activeDocument.exportFile(ExportFormat.pdfType, File("~/Documents/hotfolder/output/"+ jobNumber+"-composed.pdf"),false,"bandwPrinting");
                  //Closing the merged document.
                  app.activeDocument.close(SaveOptions.no);
                  alert("Complete");
