3 Replies Latest reply on Apr 20, 2015 6:13 AM by Rick Gerard
    3D Motion Tracking Error/Crash in progress [Urgent Help Please!]
    Spiral Motion
      Hey there!
      I'm an video editor and I use 3D Motion Tracking a lot but recently every time I use it, it comes up with an error and says crash in progress,
      It never used to do it and I can't seem to find any solutions to fix it.
      Computer Specs:
      Manufacturer: Toshiba
      Model: Notebook
      Processor: AMD E1-2100 APU with Radeon(TM) HD Graphics 1.00 GHz
      Installed Memory: 4.00 GB (3.45 GB Usable)
      System type: 64-bit Operating System, x64-based processor
      So here's how I get to the problem. (I'll try provide as much detail as possible)
      1. I import a mp4/avi file into After Effects,
      2. Create a new composition with:
      • 1280 x 720 (16:9)
      • Frame Rate = 30
      • Duration = 30 seconds
      • Resolution = Third
      • Advanced
        Renderer = Classic 3D
        (Boxes Underneath all unchecked)
        Shadow Map Resolution = Comp Size
      Motion Blur:
      Shutter Angle = 180 Degrees
      Shutter Phrase = -90 Degrees
      Samples Per Frame = 16
      Adaptive Sample Limit = 128
         3.  Drag the mp4/avi into the composition to use it. (1.21 Seconds Long)
         4.  Right click on it and go to Effect > Perspective > 3D Camera Tracker
         5.  The 3D Camera Tracker initializes with these settings:
      • Shot type = Fixed Angle of View
      • Show Track Points = 3D Solved
      • Track Point Size = 100.0%
      • Target Size = 100.0%
         6.   Loads Frames 0% > 100% then as soon as the orange line shows up with Solving camera it shows this,
         and when I click okay it shows this,
         and then finally this,
         and then it crashes. that's the same process every time and it still comes up with this.
         Help would be appreciated !
         Thank you !
