2 Replies Latest reply on Apr 19, 2015 10:25 AM by K.Daube
    Copy paragraph to another doc - lesson 2
    K.Daube Level 1
      I need to separate the task into 2 functions, because the second function will be used multiple times if processing book files.
      In GetBiblioFromRTF paragraphs from document-1 are stored into a global array.
      In PasteAtEnd the array-items are read and copied/pasted to the end of the active document-2..
      If not closing the first document (outcomment line 18), the second document does not become active and hence the data is copied to its end.
      However, if closing document-1 after filling the global array, the array is empty in each position and nothng is pasted (see the alerts).
      #target FrameMaker
      var gaBibliography= [];                           // keep bibliography lines from processed RTF
      GetBiblioFromRTF ();
      function GetBiblioFromRTF () {
        var nBib = 0, newDoc, pgf, pgf1, tRange;
        newDoc = app.ActiveDoc;
        pgf = newDoc.MainFlowInDoc.FirstTextFrameInFlow.FirstPgf;
      // --- read the bibliography into the global array
        while(pgf.ObjectValid()) {                      // until end of doc - take whole paragraphs
          nBib += 1;                                    // count biblio paragraphs for later use in message
          gaBibliography.push(pgf);                     // place the paragraph
          pgf = pgf.NextPgfInFlow;
      alert (GetText (gaBibliography[nBib-1], newDoc)); // => expected text
        newDoc.Close (Constants.FF_CLOSE_MODIFIED);     // source document
      } // --- end GetBiblioFromRTF
      function PasteAtEnd () {
        var j, jMax, oDoc, lastPgf, pgf, textLoc, tRange;
        jMax = gaBibliography.length;
        if (app.ActiveDoc.ObjectValid()) {              // target document
          oDoc = app.ActiveDoc;
        } else {
          Alert ("No active document!");
        lastPgf = oDoc.MainFlowInDoc.FirstTextFrameInFlow.LastPgf;
        pgf = oDoc.NewSeriesPgf (lastPgf);              // Add a new paragraph at end of flow
        tRange = new TextRange;
        for (j = 0; j < jMax; j += 1) {
          pgf1 = gaBibliography[j];                     // is object paragraph
      alert (GetText (gaBibliography[j], oDoc));        // => nothing
          tRange.beg.obj = pgf1;                        // select it
          tRange.beg.offset = 0;
          tRange.end.obj = pgf1;
          tRange.end.offset = Constants.FV_OBJ_END_OFFSET;
          oDoc.TextSelection = tRange;
          PushClipboard ();
          oDoc.Copy (0);                                // copy selection to clipboard not interactive
          textLoc = new TextLoc (pgf, 0);
          textRange = new TextRange (textLoc, textLoc);
          oDoc.TextSelection = textRange;               // set TextSelection to insertion point
          oDoc.Paste ();                                // "replace" TextSelection
          PopClipboard ();
      function GetText (textObj, doc) {
        var text = "", textItems;
        if (textObj.constructor.name !== "TextRange") { // Get a list of the strings in the text object or text range
          var textItems = textObj.GetText(Constants.FTI_String);
        } else {
          textItems = doc.GetTextForRange(textObj, Constants.FTI_String);
        for (var i = 0; i < textItems.len; i += 1) {    // Concatenate the strings
          text += (textItems[i].sdata);
        return text;                                    // Return the text
      } // --- end GetText
      There seems to be a 'hidden connection' between the array items and the first document, which of course will be broken, if this is closed. I thought to have all the stuff in the array which is needed for the second step.
      Can anybody give me a hint how get this running correctly?
        • 1. Re: Copy paragraph to another doc - lesson 2
          Klaus Göbel Level 3
          Hi Klaus,
          the simlest way is to avoid "acticeDoc".
          Why dont you use sth. like:
          myOldDoc = Open (fileNameOldDoc, openParams, openReturnParams);
          myNewDoc = Open (fileNameNewDoc, openParams, openReturnParams);
          And don't close one of the until the script has finished. Otherwise the ID's of the paragraphs get lost.
          BTW: Are you in Darmstadt this week? http://tagungen.tekom.de/f15/startseite/
          So we could meet!
          • 2. Re: Copy paragraph to another doc - lesson 2
            K.Daube Level 1
            Thanks Klaus for the idea presented to avoid the ActiveDoc. The paragraph ID's seem to be the missing link which I assumed to exist.
            For the first type of references it was sufficient to work with strings - so no paragraph-IDs were involved. But for replacing placeholders in footnotes with full bibliographic references I need the formatted paragraphs. I will continue my development with Your hint.
            Retired since seven years I'm no more in real business - attend only now and then a tecom.ch or itl event in Switzerland or Munich; mainly to meet old friends and stay in contact with doc-technology.
