3 Replies Latest reply on Apr 20, 2015 2:05 PM by trshaner
    turn off auto-stack
    ralphsomma
      Can I turn off auto-stacking in LR?
      By default LR seems to auto-stack photos with the same time stamp.
      Because a number of old photos that I imported into LR have the same time-stamp they are all stacked.
      However, the time stamps are inaccurate and the photos have nothing in common that would warrant their stacking.
      Is there a way to shut off auto-stacking all together?
      I can set the auto-stack function to only stack photos whose time between capture is 0:00; however, because a large number of my old photos have the same time stamp they are all included within that parameter and are therefore stacked.
      If I cannot turn off auto-stacking:
      is there a way to only apply it going forward or
      can I view all photos that are stacked in the Library and then select then all for unstacking?
        • 1. Re: turn off auto-stack
          trshaner Adobe Community Professional & MVP
          I believe auto-stacking can only be manually applied, so no need to "turn off' anything. You may have inadvertently applied auto-stack to a group of image files.
          In the Library module left panel under Catalog click on 'All Photographs,' Select ALL' (CTRL + A), and go to Photo> Stacking> Unstack.
          • 2. Re: turn off auto-stack
            ralphsomma Level 1
            Thanks.
            I believe you are right - I did turn on auto-stacking but didn't realize it would be applied retroactively to all photos already in my catalogue and that many of those images had date/time stamps that would result in their stacking.
            I will make sure in the future to apply stacking manually.
            In any case, your solution worked - selected all photos in Catalog and then Photo> Stacking> Unstack.
            Thanks again.
            • 3. Re: turn off auto-stack
              ralphsomma wrote:
              Thanks.
              Auto Photo> Stacking> 'Stack By Capture Time' function only stacks the images in the currently open folder and the images in its subfolders if Library> 'Show Photos in Subfolders' is checked. Perhaps you selected a top-level folder and had 'Show Photos in Subfolders' checked, so it also stacked the image files in the subfolders? Anyhow you should be OK going forward.
