3 Replies Latest reply on Jan 19, 2007 3:45 AM by Newsgroup_User
    check input mouse in order
    Level 7
      Hello:
      I need to control the mouseclick in a specific sequence :
      four buttons in order 1,2,3 and 4.
      If that happens then do something.
      For example if user click on buttons 2,4,1,3 or 3,1,2,4 etc do nothing but
      if push 1,2,3,4 then works.
      Can you help me, please?
      thank you
        • 1. Re: check input mouse in order
          Level 7
          Excuse me.
          I think that the principal problem is to put this code in a exitframe.
          "Anne" <anmalo42@lycos.es> escribió en el mensaje
          news:eoq5b3$jfu$1@forums.macromedia.com...
          > Hello:
          > but if push 1,2,3,4 then works.
          > thank you
          • 2. Re: check input mouse in order
            Level 7
            "this" code? What code?
            Craig Wollman
            Lingo Specialist
            Word of Mouth Productions
            212-928-9581
            www.wordofmouthpros.com
            "Anne" <anmalo42@lycos.es> wrote in message
            news:eoq669$kgd$1@forums.macromedia.com...
            > Excuse me.
            >> Hello:
            >> thank you
            • 3. Re: check input mouse in order
              Level 7
              Put this in a movie script
              global gSequenceList, gClickedList
              on startMovie
              gSequenceList = [3, 2, 4, 1]
              gClickedList = []
              end
              Create 1 behavior with the code below and attach it to all four buttons,
              making sure each sprite is in a channel that is also represented in the list
              you created above. Using the above list you should have sprites in channels
              4, 5, 3, and 6. Otherwise it won't work. There is a way to have the 4
              sprites themselves create the list but you'd be limited to an ascending
              order of sprites only.
              property pS, spriteNum
              on beginSprite me
              pS = sprite (spriteNum)
              end
              on mouseUp me
              if gClickedList.count < 4 then
              gClickedList.add (spriteNum)
              end if
              if gClickedList.count = 4 then
              if gClickedList = gSequenceList then
              -- DO WHAT YOU WANT HERE WHEN SEQUENCE IS CORRECT
              end if
              end if
              end
              Craig Wollman
              Lingo Specialist
              212-928-9581
              > Hello:
              > thank you
