5 Replies Latest reply on May 2, 2015 11:37 PM by BKBK
    Error when consuming a web service in CF 11
      I am consuming a web service in ColdFusion what was written in .NET.  Some methods of the web service work fine, but some we get the below error.  We have identified the issue is the name of one of the properties in the web service appears to be the issue.  The property name is ID.  This is a very common property name so I would think someone has run across this before.  It appears that maybe ID is a default property for Axis?  I can dump the method that works and I see there is a getID() method with a return type of org.apache.axis.types.Id.
      If we change the name of the property to something other than ID it works, but this will cause us to refactor a lot of code.
      Here is the error I get when I try to call GetRoles method, which contains an ID property:
      Cannot perform web service invocation GetRoles. The fault returned when invoking the web service operation is:
      faultCode: {http://schemas.xmlsoap.org/soap/envelope/}Server.userException
      faultString: org.xml.sax.SAXException: For input string: "i1"
      java.lang.NumberFormatException: For input string: "i1"
      {http://xml.apache.org/axis/}stackTrace:org.xml.sax.SAXException: For input string: "i1"
      at org.apache.axis.encoding.ser.BeanDeserializer.onStartElement(BeanDeserializer.java:462)
      at org.apache.axis.encoding.DeserializerImpl.startElement(DeserializerImpl.java:393)
      at org.apache.axis.encoding.ser.BeanDeserializer.startElement(BeanDeserializer.java:154)
      at org.apache.axis.encoding.DeserializationContext.startElement(DeserializationContext.java: 1048)
      at org.apache.axis.message.SAX2EventRecorder.replay(SAX2EventRecorder.java:165)
      at org.apache.axis.message.MessageElement.publishToHandler(MessageElement.java:1141)
      at org.apache.axis.message... ''
      I am running CF 11 Update 4.
