3 Replies Latest reply on Apr 21, 2015 12:42 PM by A.T. Romano
    PrE 13 Movie Menu Title is corrupted when project is closed and re-opened
    ABWay0 Level 1
      The following Title:
      "Keewaydin
      Section "B" 1955
      Section "A" 1956"
      is corrupted to:
      "Keewaydin
Section "B" Dumoine R. 1955
Section "A" Harricanaw R. 1956"
        • 1. Re: PrE 13 Movie Menu Title is corrupted when project is closed and re-opened
          A.T. Romano Level 7
          ABWay0
          I know of this problem in Premiere Elements 13/13.1 and have written about it. It relates to using more than one line of text in a Movie Menu customization. The following is a copy/paste excerpt from my blog write up on this
          ATR Premiere Elements Troubleshooting: Premiere Elements 13 Daily Discoveries
          Item 19.
          0019. Premiere Elements 13 Movie Menu Title Issue: More Than One Line of Text
          A Premiere Elements 13/13.1 user reports that, if he creates a 3 lines of text title for Faux Widescreen theme's main menu in the Movie Maker customization area of the project, those 3 lines of text end up "scrambled" in the reopened project after it had been saved closed.
          We have confirmed this report and extended it to include that this issue appears for 13's Movie Menus other than Faux Widescreen. This issue is not seen in Premiere Elements 12/12.1 and earlier versions.
          BEFORE THE SAVE CLOSE REOPEN
          Figure 1. Spring Flower Main Menu Originally With 3 Lines Of Text As Seen Before The Save Close Reopen
          AFTER THE SAVE CLOSE REOPEN
          Figure 2. Spring Flower Main Menu Title Originally With 3 Lines Of Text As Seen After The Save Close Reopen
          The only way found so far to get the end product to have the 3 lines of text title for the menus in the end product is to customize the Movie Menu theme in the Movie Menu customization area of the project, do not save close the project at that point, and then do the burn to.
          Many variables have been looked at to explain this behavior. So far no answer for why.
          Please review and consider. Any questions, please do not hesitate to ask.
          Thank you.
          ATR
          • 2. Re: PrE 13 Movie Menu Title is corrupted when project is closed and re-opened
            ABWay0 Level 1
            Thanks so much for your confirmation of the as-yet unsolved problem. Burning before saving/re-opening works for now.
            Even more thanks for pointing me to your Daily Discoveries blog.
            • 3. Re: PrE 13 Movie Menu Title is corrupted when project is closed and re-opened
              A.T. Romano Level 7
              ABWay0
              Thanks for the reply.
              I will keep watch for alternative solutions to this Movie Menu theme's text customization issue.
              Glad the suggestion in the write up worked for you.
              Best wishes
              ATR
