6 Replies Latest reply on Apr 22, 2015 5:24 AM by catherine26
    Form not filtering results
    catherine26 Level 1
      I'm creating 2 filtering drop downs and I can't figure out why my code isn't filtering the results on the page.  Please help...
      Here's the code.
      <cfparam name="form.personnel" default="">
      <cfparam name="form.status" default="">
      <cfquery name="q" datasource="#dsn#">
           SELECT *
           FROM table
           WHERE 1=1
                <cfif val(form.personnel) GT 0>
                     AND Sector = <cfqueryparam value="#form.personnel#" cfsqltype="cf_sql_varchar">
                </cfif>
                <cfif val(form.status) GT 0>
                     AND reqStatus = <cfqueryparam value="#form.status#" cfsqltype="cf_sql_varchar">
                </cfif>
      </cfquery>
      <form method="post" action="">
           <select name="personnel">
                     <option></option>
           </select>
           <select name="status">
                     <option></option>
           </select>
           <input type="submit" />
      </form>
      <cfoutput query="q">
           #sector# || #reqstatus#
      </cfoutput>
        • 1. Re: Form not filtering results
          haxtbh Level 4
          Your options in the dropdown are blank????
          • 2. Re: Form not filtering results
            catherine26 Level 1
            Sorry I was trying to short cut the coding.  There are actually options in the drop down.
            Like this...
                 <select name="sector">
                      <option value="">All Personnel</option>
                      <option value="Air Force">Air Force</option>
                      <option value="Army">Army</option>
                      <option value="Navy">Navy</option>
                      etc...
                 </select>
                      <option value="">All Statuses</option>
                      <option value="Active">Active</option>
                      <option value="Completed">Completed</option>
                      etc...
                 </select>
            </form>
            • 3. Re: Form not filtering results
              Anit_Kumar Adobe Employee
              You can try this:-
                        etc...
                   </select>
                        etc...
                   </select>
              </form>
              <cfif IsDefined("form.sector")>
                <cfoutput>sector='#sector#' and status='#status#'</cfoutput>
              </cfif>
              Regards,
              Anit Kumar
              • 4. Re: Form not filtering results
                catherine26 Level 1
                That didn't work.  I tried it and when I make a selection and then click the submit button nothing happens.
                • 5. Re: Form not filtering results
                  haxtbh Level 4
                  Why are you checking "<cfif val(form.personnel) GT 0>" in the SQL query? What are your reasons for using val()? Your results are most likely not being filtered as your SQL query is not working as you are checking your variables wrong.
                  Are you trying to determine that the form string is not empty? In that case you want to use len()
                  • 6. Re: Form not filtering results
                    catherine26 Level 1
                    Thank you that worked.  Not sure why I used val(). It was an example I found searching online.  Thank you so much for your help.
