2 Replies Latest reply on Apr 21, 2015 3:59 PM by Jeff S GP2
    Ignore Error
    Jeff S GP2 Level 1
      I have this simple script  ( action converted to java) that renames a layer "Test" to "H_Test' than duplicates with the name "B_Test"
      Is there an additional line of code i can include to ignore this process, if the layer name "Test" does not appear within the layers list?
      Many thanks!
      #target photoshop
      cTID = function(s) { return app.charIDToTypeID(s); };
      sTID = function(s) { return app.stringIDToTypeID(s); };
      //==================== Select_byName_AddPrefix_Duplicate ==============
      function Select_byName_AddPrefix_Duplicate() {
        // Select
        function step1(enabled, withDialog) {
          if (enabled != undefined && !enabled)
            return;
          var dialogMode = (withDialog ? DialogModes.ALL : DialogModes.NO);
          var desc1 = new ActionDescriptor();
          var ref1 = new ActionReference();
          ref1.putName(cTID('Lyr '), "Test");
          desc1.putReference(cTID('null'), ref1);
          desc1.putBoolean(cTID('MkVs'), false);
          executeAction(cTID('slct'), desc1, dialogMode);
        // Set
        function step2(enabled, withDialog) {
            return;
          ref1.putEnumerated(cTID('Lyr '), cTID('Ordn'), cTID('Trgt'));
          var desc2 = new ActionDescriptor();
          desc2.putString(cTID('Nm  '), "H_Test");
          desc1.putObject(cTID('T   '), cTID('Lyr '), desc2);
          executeAction(cTID('setd'), desc1, dialogMode);
        // Duplicate
        function step3(enabled, withDialog) {
            return;
          desc1.putString(cTID('Nm  '), "B_Test");
          desc1.putInteger(cTID('Vrsn'), 2);
          executeAction(cTID('Dplc'), desc1, dialogMode);
        step1();      // Select
        step2();      // Set
        step3();      // Duplicate
      //                    Select_byName_AddPrefix_Duplicate.main
      Select_byName_AddPrefix_Duplicate.main = function () {
        Select_byName_AddPrefix_Duplicate();
      Select_byName_AddPrefix_Duplicate.main();
      // EOF
      "Select_byName_AddPrefix_Duplicate.jsx"
      // EOF
        • 1. Re: Ignore Error
          DBarranca Level 4
          easiest one is to wrap step1 in a try/catch block.
          #target photoshop
            // Select
                return;
            // Set
                return;
            // Duplicate
                return;
            try {
              step1();      // Select
            } catch(e) {
              return;
            step2();      // Set
          // EOF
          // EOF
          Regards
          Davide Barranca
          www.davidebarranca.com
          www.cs-extensions.com
          • 2. Re: Ignore Error
            Jeff S GP2 Level 1
            Thank you very much!
            Cheers!
