12 Replies Latest reply on Apr 21, 2015 11:49 PM by tariq_za
    LIghtroom CC does not open
    Tor Omnes
      As a cloud member I have updated to Lightroom CC, but after installing it, I am not able to open the app. When trying to open it,nothing happens.
        • 1. Re: LIghtroom CC does not open
          sergretouch
          I have the same problem =\
          Upd: I fix it. Just logout in Creative cloud, then login and start Lightroom. And he has started.
          If this don't work also can do like this: logout in Creative cloud, launch Lightroom and he offer to login...
          • 2. Re: LIghtroom CC does not open
            tariq_za
            I have the same problem. Splash screen appears and promptly disappears; but the app itself doesn't open. Both Photoshop CC and Lightroom 5.7.1 still work fine. Log file when starting Lightroom CC is as follows:
            2015/04/21 10:56:38,534 PM WindowServer[192]: Received display connect changed for display 0x4280382
            2015/04/21 10:56:38,559 PM WindowServer[192]: Found 27 modes for display 0x04280382 [27, 0]
            2015/04/21 10:56:38,661 PM WindowServer[192]: Received display connect changed for display 0x3f003f
            2015/04/21 10:56:38,661 PM WindowServer[192]: Found 1 modes for display 0x003f003f [1, 0]
            2015/04/21 10:56:38,661 PM WindowServer[192]: Received display connect changed for display 0x3f0040
            2015/04/21 10:56:38,661 PM WindowServer[192]: Found 1 modes for display 0x003f0040 [1, 0]
            2015/04/21 10:56:38,661 PM WindowServer[192]: Received display connect changed for display 0x3f0041
            2015/04/21 10:56:38,662 PM WindowServer[192]: Found 1 modes for display 0x003f0041 [1, 0]
            2015/04/21 10:56:38,663 PM WindowServer[192]: CGXMuxAcknowledge: Posting glitchless acknowledge
            2015/04/21 10:56:38,675 PM WindowServer[192]: MPAccessSurfaceForDisplayDevice: Set up page flip mode on display 0x04280382 device: 0x7fdc82513cf0  isBackBuffered: 0 numComp: 1 numDisp: 3
            2015/04/21 10:56:38,750 PM WindowServer[192]: Received display connect changed for display 0x4280382
            2015/04/21 10:56:38,750 PM WindowServer[192]: Found 1 modes for display 0x04280382 [1, 0]
            • 3. Re: LIghtroom CC does not open
              Jim Wilde Adobe Community Professional
              Try signing out of the CC desktop app, then sign back in again.
              • 4. Re: LIghtroom CC does not open
                Tor Omnes Level 1
                Jim, I have tried, but it did not help me!
                • 5. Re: LIghtroom CC does not open
                  tariq_za Level 1
                  Also tried that, didn't help either...
                  • 6. Re: LIghtroom CC does not open
                    sergretouch Level 1
                    Tor, Do you try do like i'm my message second way?
                    [quote]logout in Creative cloud, launch Lightroom and he offer to login... [/quote]
                    You must logut from you account of Creative cloud. Not just close and open..
                    • 7. Re: LIghtroom CC does not open
                      Did you sign out, or did you just quit and restart? You have to sign out and sign back in again (maybe a few times).
                      • 8. Re: LIghtroom CC does not open
                        Tor Omnes Level 1
                        Hello Jim
                        Tried once more, and now I succeeded.
                        Thank you for your help!
                        Regards
                        Tor
                        • 9. Re: LIghtroom CC does not open
                          tariq_za Level 1
                          Jim - Signed out, quit all apps (except browser), resigned in and tried to launch Lightroom CC and problem persists. Have repeated this cycle about 10 times now. Also tried restarting the PC, uninstalling and re-installing Lightroom CC.
                          • 10. Re: LIghtroom CC does not open
                            tariq_za Level 1
                            sergretou - Tried your method as well; and once a pop-up appeared asking for acceptance of the licence agreement; but the app still didn't start. I'm repeating the process and monitoring this thread...
                            • 11. Re: LIghtroom CC does not open
                              sandorw73744131
                              The second solution worked perfectly for me.  Do EXACTLY as follows:
                              1. Log out of Creative Cloud - don't just close the app (no need to close it at all), go into preferences and click on Log Out.
                              2. Click on Lightroom CC to open the app.
                              3. You will see the license agreement blah blah - accept and go through the rest of the motions as prompted.
                              Lightroom CC should be open and functioning normally after the above!  You can then go back to Creative Cloud and Log In again.
                              • 12. Re: LIghtroom CC does not open
                                tariq_za Level 1
                                Tried Jim's solution again at work (different internet connection) and it magically worked - it seems to be a case of persistence; and perhaps trying different net connections if Jim's solution doesn't work.
