Hi.
i'm using Captivate 8 and responsive project.
i want to use external JS file for my project, and i read here that the best way is to use the standart.js file from the installation dir.
the problem is that when i publish my project this file is not included and i can't use the functions i wrote there.
i can add this file manually to the js folder and index.htm, but i will have to do this on every publish..
am i missing something? is there any other way to use external JS file?
Thanks.
That is why I was pointing to the HTML/Assets folder which is where all the templates are stored. You don't have to add manually anymore in that case, if you edit the HTM files and store your JS file there.
I learned from Jim Leichliter, that you can create a JS-folder in the HTML\Assets folder (was there in CP7, no longer in CP8) and put your external JS-file there. Do not forget to include the call to it in the HTM and HTML-files, depending on your output.
Thanks, but i want to be able to include a JS file without adding it manually every time..
Since every publish will create a new index.htm i will have to add the file and include it in the html every time i publish the project.. i'm sure there is a better way
Thanks!
I didn't understood you well in the first massage..
Now its all working fine, thanks again.
You can edit the template index.html to include the js file in the following location:
C:\Program Files\Adobe\Adobe Captivate 8 x64\HTML\index.html
Also, add your js file to the following location, if the location doesn't exist, create it:
C:\Program Files\Adobe\Adobe Captivate 8 x64\HTML\assets\js\
