1 Reply Latest reply on Apr 23, 2015 8:05 AM by K.Daube
    Not well-formed (invalid token)
    K.Daube Level 2
      Dear experts,
      During developing my script - I can not use the ESTK on my system - with editing it in EditPad (UTF-8 file) and then executing it in FM-12 I got the message:
      Script Error :
      Error Message      : Not well-formed (invalid token)
      Script, Line#   : E:\_DDDprojects\FM-biblio\test-scripts\t-read-formatted.jsx,  6
      Fiddling around a lot, deleting initial comment lines, converting the file to Windows code page back and then again to UTF-8 the error persisted.
      I then run the script in ETSK on the pc of my wife (which is very slow, but is a standard Windows 7 x32 installation) - no problem at all. I saved the script and went back to my system: problem was gone!
      But now I have the same error with another script. The really strange thing is this: the reported line is always 6, even if I either delete (for the time beeing) irreleant lines or insert such at the beginning.
      More strange things. My growing script in the project I have mentioned more than once now cretates the error when starting it.
      Script Error :
      Error Message      : Character conversion error
      Script, Line#   : H:\Adobe\framemaker.12en\AdobeFrameMaker12\10,  0
      This messages in itself is rubbish: the script loaded is E:\_DDDprojects\FM-biblio\escript\FM-biblio.jsx ...
      Well at first I will restart Windows and then look at this again.
        • 1. Re: Not well-formed (invalid token)
          K.Daube Level 2
          Well, it turns out that a jsx file must not contain umlauts if it is coded in cp 1252 (Windows).
          var menuRes1 =   {en: "Resolve temp. citations",
                            de: "Temp. zitate auflösen"};
          You will get very strange error messages which You can not
          -  Error Message      : Unterminated string constant
             Script, Line#   : E:\_DDDprojects\FM-biblio\test-scripts\t-menu-setup.jsx,  31 (line 01 in the example above).
          - No definition found in script for function 'Command'
             Script : "E:\_DDDprojects\FM-biblio\test-scripts\t-menu-setup.jsx"
          Although You do not have a real error in the script.
          Hence such script files must be UTF-8
          And sorry, in my first post in this thread the first error cited was a 'grievous fault of me' (to cite Shakespeare):
          was the result of not opening a jsx file, but a FrameMaker file ...
          My wife is completely right when she says: often you are to fast with your reaction.
          The finding for my second remark is this:
          at least the character ¶ is not allowed in the script comments, although it is coded in UTF-8. How to know what else is not allowed - and how about string constants?
