1 Reply Latest reply on Nov 28, 2006 3:45 AM by Marghoob Suleman
    Searching for libary member usage
    Level 7
      Hello,
      I'm a pretty inexperienced with Flash, but am a Director expert. In
      Director there is a way to find out if a cast member is used in the score.
      In Flash, is there something similar? I mean is there a way to find out if a
      library member is used in a timeline? I'm trying to clear out unused
      resources and don't want to delete something that is being used.
      Brian
        • 1. Searching for libary member usage
          Marghoob Suleman Level 1
          Flash can do itself but only if you are using symbols on stage.
          To find unused library items:
          Do one of the following:
          Select Unused Items from the Library options menu.
          Sort library items by the Use Count column.
          NOTE: It is not necessary to delete unused library items to reduce a Flash document's file size because unused library items are not included in the SWF file. However, items linked for export are included in the SWF file.
