1 Reply Latest reply on May 6, 2015 3:36 AM by owen_bayley
    Idle Timeout Code
    evana45602007
      I am hoping to get help with an idle timeout code.  I am creating a short photo book using Adobe Edge Animate and if someone is on Page 3 for longer than lets say 1 minute without clicking to the next page I want to return the the cover image.  As a test I have set the stage for 5 seconds to set an alert if not clicked and its works great!  Unfortunately, this was just a test and I wanted to replace the alert with symbols (the cover image)  but it hasn't worked at all.  Help would be appreciated!
      Stage Code
      var r;
      var timer;
      function doIt() {
        r = confirm ("hello");
        if (r == true) {
        setIt();
        } else {
        //screen saver
        alert("bye!");}};
      function setIt() {
        timer = setTimeout(doIt, 5000);};
      Stage.Click Code:
      clearTimeout(timer);
           setIt();
        • 1. Re: Idle Timeout Code
          owen_bayley Level 1
          hey evanam,
          I'm not sure how you have layer out your project but this might work but you could try :
          var r;
          var timer;
          function doIt() {
            if (r == true) {
            setIt();
            } else {
          sym.getComposition().getStage().$("cover").show();
          function setIt() {
            timer = setTimeout(doIt, 60000);};
          Stage.Click Code:
               setIt();
          All I have done is extended the timer to 60 seconds and edited the else so if you are in a symbol you can go to the main stage and show the element of cover.
          hope this helps (if not any example of the project would help)
          Owen
