I am beginning to work with (unstructured) FrameMaker 10 and struggling a bit with no expert help around. Hence, I have a few queries:
I’d invest in a copy of the FM bible – Publishing Fundamentals by Matt Sullivan
Thanks, Jeff for the book suggestion.
The best format for graphics depends on the type of graphic and the
output destination. If your final destination is a file that will be
stored on your computer or on the Web for viewing on screen, any of
those will work, but there are certain advantages to each.
GIF files are limited to 256 colors. So screenshots and drawings
should look great, but photographs will not show the full range of
colors and have a bit less punch.
JPGs handle 16 million colors and are meant for photographs. The
compression scheme does not work well with screenshots and drawings,
though. The result is often weird, white-noiselike artifacts around text
and lines. So use JPG for photos only.
*PNG: Combines the best features of GIF and JPG.
If your output is for printing press, then you need to consider the
ability to handle CMYK graphics. FrameMaker passes GIF, JPG, and PNG
graphics through the Windows GDI, which converts them to RGB and that's
no good for printing press. However, if you use EPS or PDF graphics,
FrameMaker passes them around the Windows GDI unchanged, and they stay
CMYK. (Be sure to include the 8-bit preview when you create your EPS
graphics or you will see in FrameMaker, I think, a gray box instead of
the image. It still prints fine.) Note also that the EPS preview image
shown in FrameMaker is a low-res image and not the full-resolution image
that prints. So it's kind of ugly on screen, but loads much faster. PDFs
both show and print in FM as full-resolution. EPS and PDF graphics also
have the advantage that they can hold both vector (such as screenshots
and drawings) and bitmap graphics (photos). So one format works for all
graphics.
Later versions of FrameMaker have some ability to convert RGB images to
CMYK, but this feature is still widely reported as buggy, so I always
use EPS or PDF for output destined for printing press.
Message #4 in the following thread describes the way I set up
graphics/captions/autonumbering:
https://forums.adobe.com/message/3020618#3020618
Mike, Many thanks for your time to get me a comprehensive answer.
I'm sure that's going to help me!
