1 Reply Latest reply on Jan 12, 2007 9:27 AM by MotionMaker
    XML DOM
    kanukukreja Level 1
      I need to parse XML DOM in flash......
      server side script is sending one var "req" through that XML DOM
      And after parsing that XML DOM i'll get a XML again from which i need to parse the path to load an image
        • 1. Re: XML DOM
          MotionMaker Level 1
          Flash automatically parses the XML into the Flash XML object if you are getting XML from server. You use the XML sendAndLoad or load method to communicate with server script.
          If XML is in a LoadVars variable req=xml, then you use the Flash LoadVars load or sendAndLoad methods and then you can create an XML object in FLash and feed the variable to the constructor.
