22 Replies Latest reply on Apr 24, 2015 11:37 AM by mathews96862287
    Each file on it's own layer + layer name
    mathews96862287 Level 1
      I create interactive maps in illustrator and export individual al's to InDesign. I run the following script to place each file on it's own layer. I would like it to name the layer the file name that is being placed on that layer minus the .ai
      The reason I do this to export to PDF in chunks then combine in Acrobat to have headings and sub headings which can be toggled on/off depending on what the person operating the map would like to see.
      If there is an easier way to do this I'm all ears. I cannot export directly from Illustrator as there are simply 100s of layers that can be turned on or off without any headings. Any suggestions or rewrites of the script are greatly appreciated.
      For example:
      County Lands by owner
           Johnson land
           Scott land
           Minden
      Roads
           Highways
           Unpaved roads
      var mySels = app.selection.length;
      if (mySels == 0) {
          alert("Select the object and Run the script");
           exit(0)
      else{
      while(mySels--){
                var objLayer=app.activeDocument.layers.add();
                app.selection[mySels].itemLayer = objLayer;
