4 Replies Latest reply on May 5, 2015 6:41 PM by Monkybomb Studios
    Timer function
    Monkybomb Studios Level 1
      Hi There guys,
      I need to add timers to each page of my project to return to the homepage if inactive for x seconds is there a way to apply this universally to the entire project?  How do i set the mouse inactive functions, if you can give me a hand i would be very grateful!!
      Thanks in advance!
        • 1. Re: Timer function
          Robyn_cpl Level 2
          I use this code below
          setTimeout(function ()
          }, 1000);
          Every 1000 = to 1 second.
          The inside the {} I would add an if statement to say if (inactive ==0) then return to home page.
          I hope this helps
          • 2. Re: Timer function
            Hi Thanks for the reply!
            Will this work if noone has touched the screen for the set limit then will return to homescreen? And where do i use this code on the trigger for each page? or do i use it on the creation complete or document ready areas?
            Your help is very much appreciated!
            Thanks so much in advance!
            • 3. Re: Timer function
              mads18950258 Level 1
              you could use setTimeout but remember to remove previously setTimeout objects.
              you would do it like this.
              on your Stage CompositionReady
              create a 'global' variable like so
              sym.timer1;
              from you symbol (scene or whatever), assign an mousemove event (for testing purpose i assigned this to the stage), within this event add the following code.
              clearTimeout(  sym.getComposition().getStage().timer1)
              sym.getComposition().getStage().timer1 = setTimeout(function ()
              alert("hello");
              }, 1000);
              Voila, after 1 second you should get an alert, if you comment out the clearTimeout you get an alert for every time the mousemove event is executed .
              performance wise im not sure if this is the best solution, but it may do the job for you or inspire to another solution.
              hope it helped.
              • 4. Re: Timer function
                Hey there, Thanks so much for the help this worked like a charm!! You saved my bacon haha!
