29 Replies Latest reply on May 12, 2015 7:59 AM by Brucgovn
    Creative Cloud crashes on startup (OS X), any ideas?
    aaront89926785
      Howdy. I can't get Creative Cloud Desktop to start anymore. It used to work fine. I've tried uninstalling and reinstalling and I've tried the Adobe Creative Cloud Cleaner to no success.
      I get the following crash at startup:
      Process:               Creative Cloud [10874]
      Path:                  /Applications/Utilities/Adobe Creative Cloud/*/Creative Cloud.app/Contents/MacOS/Creative Cloud
      Identifier:            com.adobe.acc.AdobeCreativeCloud
      Version:               2.0.0.74 (???)
      Code Type:             X86 (Native)
      Parent Process:        ??? [1]
      Responsible:           Creative Cloud [10874]
      User ID:               501
      Date/Time:             2015-04-23 17:57:07.853 -0700
      OS Version:            Mac OS X 10.10.3 (14D136)
      Report Version:        11
      Anonymous UUID:        9DFA812D-95F0-6660-DC33-75FEED1A94F2
      Time Awake Since Boot: 34000 seconds
      Crashed Thread:        23
      Exception Type:        EXC_CRASH (SIGABRT)
      Exception Codes:       0x0000000000000000, 0x0000000000000000
      Application Specific Information:
      terminating with uncaught exception of type std::logic_error: basic_string::_S_construct NULL not valid
      abort() called
        • 1. Re: Creative Cloud crashes on startup (OS X), any ideas?
          Brucgovn Adobe Community Professional
          May I know whether the Creative Cloud icon appears on Menu and disappears immediately ?
          or you are getting error message when you try  to launch?
          • 2. Re: Creative Cloud crashes on startup (OS X), any ideas?
            aaront89926785 Level 1
            The icon appears in the top bar very quickly and then disappears. There is no visible error. There's a lot more detail in the crash log but I haven't (yet) included it.
            • 4. Re: Creative Cloud crashes on startup (OS X), any ideas?
              Let me know if the permissions fix , did not work , before creating Root user account.
              • 5. Re: Creative Cloud crashes on startup (OS X), any ideas?
                Ugh, didn't seem to. I set the (recursive) permissions to read/write for my account on both Library/Adobe folders. Tried re-installing again. Still no joy. Same crash. This hardly seems like a problem with OS X and seems like a pretty epic screwup from Adobe if we'd have to create a root account...
                • 6. Re: Creative Cloud crashes on startup (OS X), any ideas?
                  Aaron did you provided Read and write access to currently logged in user account and Administrator for Adobe folder or Library itself ?
                  • 7. Re: Creative Cloud crashes on startup (OS X), any ideas?
                    For the Adobe folder only. It's asinine to suggest that a user should have blanket write privileges to the system /Library folder.
                    • 8. Re: Creative Cloud crashes on startup (OS X), any ideas?
                      To be frank, it's asinine that any of these steps should be required. There's clearly something completely backwards in Adobe's installation/deployment code unless I'm losing my mind.
                      • 9. Re: Creative Cloud crashes on startup (OS X), any ideas?
                        If you are not okay to provide permissions to main libraries itself ( both ¬/library and /library) .
                        Try below steps  :
                        1) Right click on Finder icon and  select "Go-To Folder "option.
                        2) You will get a text box, type-in below command and then hit 'Return' key.( Do not miss ~ symbol)
                        ~/library
                        3)Under ~/library  folder , locate Preferences folder and provide read and write access for currently logged in user account and Administrator users.
                        4)Open Preferences folder and move all com.adobe..xxxxx and com.adobe.xxx.plist files to Backup folder  on Desktop.
                        Then try to launch Creative cloud app and check.
                        • 10. Re: Creative Cloud crashes on startup (OS X), any ideas?
                          Got rid of them. Still no joy.
                          • 11. Re: Creative Cloud crashes on startup (OS X), any ideas?
                            Then you need to try from Root user account.
                            If the App launches fine in Root user account and crash in Regular account.
                            Then you need to check with error log files.
                            You may try with below steps also :
                            https://helpx.adobe.com/x-productkb/global/troubleshoot-unexpected-behavior-user-account.h tml
                            • 12. Re: Creative Cloud crashes on startup (OS X), any ideas?
                              Optional : If you had installed Growl application on your Mac compute , disable it and try to launch CC app.
                              Run Disk utilities .
                              First Verify disk permissions and then run Repair Disk permissions.
                              Then try to launch and check .
                              • 13. Re: Creative Cloud crashes on startup (OS X), any ideas?
                                I added the root user and ran the installer again as root. And tried to launch it. Same darn error. If even root can't launch it, changing the permissions on the libraries definitely won't work...
                                • 14. Re: Creative Cloud crashes on startup (OS X), any ideas?
                                  Never had Growl.
                                  Did a verify and repair. It said there was some things that needed to be repaired, and it repaired them, but I still get the same crash and error.
                                  • 15. Re: Creative Cloud crashes on startup (OS X), any ideas?
                                    From Root user account , try uninstallation and reinstallation again , follow below steps ( You need to perform from root account) .
                                    You may try installing from root account as it has special permissions .
                                    1)
                                    Launch Activity Monitor and "Force Quit" all the process related to Adobe like Creative Cloud, CoreSync, AAMupdater, AAMupdater notifier, Adobe Crash demon from Activity monitor.
                                    2)
                                    Click on the Finder and look for the options listed next to Apple Icon located at the top left corner of the Desktop screen and click on "Go" menu button and select "Utilities" option.
                                    (Applications>Utiliites)
                                    Locate Adobe Creative Cloud and Adobe Application Manager folder under Utilities window and trash both folders.
                                    3)
                                    Trash Adobe Creative Cloud from Applications well.
                                    4)
                                    1) Right click on Finder icon and  select "Go-To Folder " option.
                                    ~/library
                                    3)Then navigate to Application Support>Adobe.
                                    Open Adobe folder and trash folders named AAMUpdater and OOBE.
                                    5)
                                    1) Right click on Finder icon and  select "Go-To" Folder option.
                                    /library
                                    Open Adobe folder and trash folders named AAMUpdater ,Adobe Application Manager and OOBE.
                                    6)
                                    Click on the below link and download & run Adobe Cleaner tool :
                                    Select the option "Adobe Application Manager for Mac OS X 10.6" and then click on "Clean up Selected" .
                                    https://helpx.adobe.com/content/help/en/creative-suite/kb/cs5-cleaner-tool-installation-pr oblems/_jcr_content/main-pars/…
                                    7)
                                    Click on the below link and download and install Adobe Application Manager.
                                    http://download.adobe.com/pub/adobe/creativesuite/cc/mac/ApplicationManager8.0_all.dmg
                                    Once the installation is completed , the install box will disappear, '
                                    Then open Applications folder and locate Adobe Application Manager icon and double click on it.
                                    It will start update process and gets update to Creative Cloud desktop app.
                                    • 16. Re: Creative Cloud crashes on startup (OS X), any ideas?
                                      Well that failed with error code A12E6 once I ran the application manager and it started updating. At least it's a new and different failure?
                                      • 17. Re: Creative Cloud crashes on startup (OS X), any ideas?
                                        Ugh, sorry missed the "from root account"; give me a sec to re-run these.
                                        • 18. Re: Creative Cloud crashes on startup (OS X), any ideas?
                                          A12E6 is an network issue.
                                          Before updating from root user accounr  ,  uncheck FTP passive mode .
                                          1)Click on Apple menu icon and select System Preferences, and then click Network.
                                          2)Choose the network that is currently connected to internet that can be Ethernet or Airport(Wireless).
                                          3)Then click on Advanced button and click Proxies Tab.
                                          4)Under 'Select a Proxy server to Configure' Uncheck all the proxy check boxes, then uncheck 'Use Passive FTP Mode (PASV)'.
                                          5)Then click on Apply Now button.
                                          Disable Firewall Temporarily if it is okay.
                                          • 19. Re: Creative Cloud crashes on startup (OS X), any ideas?
                                            And everything "worked" through the process you provided this time without the A12E6 error, except now I'm back to where I was. Launching Adobe CC ... it crashes on startup with the same old error. From root account.
                                            • 20. Re: Creative Cloud crashes on startup (OS X), any ideas?
                                              You will need to check with Error log files then.
                                              You can locate Error logs under
                                              ~/library/logs.
                                              Check with PDAPP  ,
                                              AMT3 OOBELIB (Tmp)
                                              Installation logs :
                                              /Library/Logs/Adobe/Installers folder.
                                              • 21. Re: Creative Cloud crashes on startup (OS X), any ideas?
                                                Okie dokie. PDApp.log:
                                                04/23/15 22:31:20:853 | [INFO] |  | ASU | PIM | PIM |  |  | 195693 | Build Version - 3.0.0.74
                                                04/23/15 22:31:20:853 | [INFO] |  | ASU | PIM | PIM |  |  | 195693 | Logging Level verbosity Set  to 4
                                                04/23/15 22:31:20:853 | [INFO] |  | ASU | PIM | PIM |  |  | 195693 | Creating PIM instance for path: /Applications/Utilities/Adobe Creative Cloud
                                                04/23/15 22:31:20:854 | [INFO] |  | ASU | PIM | PIM |  |  | 195693 | trying to createOrUpdatePIMDbSchema.
                                                04/23/15 22:31:20:856 | [INFO] |  | ASU | PIM | PIM |  |  | 195693 | Current db schema version on machine 2.
                                                04/23/15 22:31:20:856 | [INFO] |  | ASU | PIM | PIM |  |  | 195693 | Current db schema version to install 2.
                                                04/23/15 22:31:20:856 | [INFO] |  | ASU | PIM | PIM |  |  | 195693 | PIM DB Schema is up to date. Current schema version is 2.
                                                04/23/15 22:31:20:856 | [INFO] |  | ASU | PIM | PIM |  |  | 195693 | PIM Database is Up To Date.
                                                04/23/15 22:31:20:860 | [INFO] |  | ASU | PIM | PIM |  |  | 195693 | PIMSqlite closeDB status 0
                                                04/23/15 22:31:20:860 | [INFO] |  | ASU | PIM | PIM |  |  | 195693 | sqlite(pim.db) at path /Applications/Utilities/Adobe Creative Cloud is already closed
                                                04/23/15 22:31:20:860 | [INFO] |  | ASU | PIM | PIM |  |  | 195693 | FREE PIM Instance ...
                                                04/23/15 22:31:20:866 | [INFO] |  | ASU | PIM | PIM |  |  | 195693 | Build Version - 3.0.0.74
                                                04/23/15 22:31:20:866 | [INFO] |  | ASU | PIM | PIM |  |  | 195693 | Logging Level verbosity Set  to 4
                                                04/23/15 22:31:20:866 | [INFO] |  | ASU | PIM | PIM |  |  | 195693 | Creating PIM instance for path: /Library/Application Support/Adobe/Adobe Desktop Common
                                                04/23/15 22:31:20:867 | [INFO] |  | ASU | PIM | PIM |  |  | 195693 | trying to createOrUpdatePIMDbSchema.
                                                04/23/15 22:31:20:868 | [INFO] |  | ASU | PIM | PIM |  |  | 195693 | Current db schema version on machine 2.
                                                04/23/15 22:31:20:868 | [INFO] |  | ASU | PIM | PIM |  |  | 195693 | Current db schema version to install 2.
                                                04/23/15 22:31:20:868 | [INFO] |  | ASU | PIM | PIM |  |  | 195693 | PIM DB Schema is up to date. Current schema version is 2.
                                                04/23/15 22:31:20:868 | [INFO] |  | ASU | PIM | PIM |  |  | 195693 | PIM Database is Up To Date.
                                                04/23/15 22:31:20:869 | [INFO] |  | ASU | PIM | PIM |  |  | 195693 | PIMSqlite closeDB status 0
                                                04/23/15 22:31:20:869 | [INFO] |  | ASU | PIM | PIM |  |  | 195693 | sqlite(pim.db) at path /Library/Application Support/Adobe/Adobe Desktop Common is already closed
                                                04/23/15 22:31:20:869 | [INFO] |  | ASU | PIM | PIM |  |  | 195693 | FREE PIM Instance ...
                                                ACC.log:
                                                04/23/15 22:31:20:817 | [INFO] | 27142 | ACCC | C3App | ApplicationContext |  | C3App | 195693 | ************************* START Adobe Creative Cloud. Version: 2.0.0.74 *************************
                                                04/23/15 22:31:20:832 | [INFO] | 27142 | ACCC | Core | AsyncMessageProcessor |  | Core | 195693 | AsyncMessageProcessorMac initialized...
                                                04/23/15 22:31:20:832 | [INFO] | 27142 | ACCC | Core | AsyncMessageProcessor |  | Core | 195693 | AsyncMessageProcessorMac Message Queue initialized...
                                                04/23/15 22:31:20:839 | [INFO] | 27142 | ACCC | Core | AppletManager |  | Core | 195693 | Loading PIM library from path: /Library/Application Support/Adobe/Adobe Desktop Common/Core/AdobePIM.dylib
                                                04/23/15 22:31:20:852 | [INFO] | 27142 | ACCC | Core | AppletManager |  | Core | 195693 | Querying applet database
                                                04/23/15 22:31:20:861 | [INFO] | 27142 | ACCC | Core | AppletManager |  | Core | 195693 | Registering Applets...
                                                04/23/15 22:31:20:870 | [INFO] | 27142 | ACCC | Core | AppletManager |  | Core | 195693 | Registering Applets...
                                                04/23/15 22:31:20:873 | [INFO] | 27142 | ACCC | Core | AppletManager |  | Core | 195693 | Identifying applet relationships...
                                                04/23/15 22:31:20:877 | [INFO] | 27142 | ACCC | Core | AppletManager |  | Core | 195693 | Identifying applet relationships...
                                                04/23/15 22:31:20:881 | [INFO] | 27142 | ACCC | Core | Applet |  | Core | 195693 | Loading Applet - CmdCntr_CoreExt for InstanceID - CoreInstance
                                                04/23/15 22:31:21:001 | [INFO] | 27142 | ACCC | VulcanWrapper | VulcanInterface |  | VulcanWrapper | 195716 | Received RefreshEndPoints callback:
                                                04/23/15 22:31:21:044 | [INFO] | 27142 | ACCC | Core | Applet |  | Core | 195693 | Loading Applet - C3Prefs_CoreExt for InstanceID - CoreInstance
                                                04/23/15 22:31:21:059 | [INFO] | 27142 | ACCC | C3PrefsCoreExt |  |  | C3PrefsCoreExt | 195693 | Initialize called: <?xml version="1.0" encoding="UTF-8" standalone="no"?>
                                                <CommandLineArguments ApplicationID="ACCC" IsServiceInstance="0">
                                                    <appletID>C3Prefs_CoreExt</appletID>
                                                    <appletVersion>1.0</appletVersion>
                                                    <appletInstanceID>CoreInstance</appletInstanceID>
                                                    <appletDIR>/Library/Application Support/Adobe/Adobe Desktop Common/CoreExt</appletDIR>
                                                </CommandLineArguments>
                                                04/23/15 22:31:21:059 | [INFO] | 27142 | ACCC | Core | Applet |  | Core | 195693 | Loading Applet - LocManager_CoreExt for InstanceID - CoreInstance
                                                04/23/15 22:31:21:072 | [INFO] | 27142 | ACCC | LocalizationManager |  |  | LocalizationManager | 195693 | LocalizationManager Initialized
                                                04/23/15 22:31:21:072 | [INFO] | 27142 | ACCC | Core | Applet |  | Core | 195693 | Loading Applet - Analytics_CoreExt for InstanceID - CoreInstance
                                                04/23/15 22:31:21:084 | [INFO] | 27142 | ACCC | ACE | ACE |  | ACE | 195693 | ACE Initialized
                                                04/23/15 22:31:21:085 | [INFO] | 27142 | ACCC | C3PrefsCoreExt | C3PrefsMessageProcessor |  | C3PrefsCoreExt | 195693 | Inside GetLocalConfigXmlPath
                                                04/23/15 22:31:21:095 | [WARN] | 27142 | ACCC | C3PrefsCoreExt |  |  | C3PrefsCoreExt | 195693 | Could not initialize C3Config sig file as XML data
                                                04/23/15 22:31:21:096 | [INFO] | 27142 | ACCC | ACE |  |  | ACE | 195693 | ETS environment is: 7
                                                04/23/15 22:31:21:096 | [INFO] | 27142 | ACCC | ACE |  |  | ACE | 195693 | OS Bitness is: 64
                                                04/23/15 22:31:21:227 | [INFO] | 27142 | ACCC | C3App | LocalizationManager |  | C3App | 195693 | Dictionary Path: /Applications/Utilities/Adobe Creative Cloud/ACC/Creative Cloud.app/Contents/Resources/Dictionary/en_US/stringTable.zdct
                                                04/23/15 22:31:21:227 | [INFO] | 27142 | ACCC | C3App | LocalizationManager |  | C3App | 195693 | Dictionary reading successful.
                                                04/23/15 22:31:21:239 | [INFO] | 27142 | ACCC | Core | Applet |  | Core | 195693 | Loading Applet - HEX_UIX for InstanceID - UIXInstance
                                                04/23/15 22:31:21:265 | [INFO] | 27142 | ACCC | HEX |  |  | HEX | 195693 | Initialize called: <?xml version="1.0" encoding="UTF-8" standalone="no"?>
                                                <CommandLineArguments ApplicationID="" IsServiceInstance="">
                                                    <appletID>HEX_UIX</appletID>
                                                    <appletInstanceID>UIXInstance</appletInstanceID>
                                                    <appletDIR>/Library/Application Support/Adobe/Adobe Desktop Common/HEX</appletDIR>
                                                04/23/15 22:31:21:274 | [INFO] | 27142 | ACCC | Core | Applet |  | Core | 195693 | Loading Applet - C3Container_UINative for InstanceID - 2FD2BC96-E72A-4289-8F3F-4175EBD12637
                                                04/23/15 22:31:21:424 | [INFO] | 27142 | ACCC | c3containerUI | UIManager |  | c3containerUI | 195693 | CreateView
                                                04/23/15 22:31:21:453 | [INFO] | 27142 | ACCC | c3containerUI | UIManager |  | c3containerUI | 195693 | Load UICore & UIMain
                                                04/23/15 22:31:21:454 | [INFO] | 27142 | ACCC | HEX | HEX |  | HEX | 195693 | Inside LoadBindings
                                                04/23/15 22:31:21:455 | [INFO] | 27142 | ACCC | HEX | HEX |  | HEX | 195693 | Inside LoadBindings
                                                04/23/15 22:31:21:456 | [INFO] | 27142 | ACCC | HEX | HEX |  | HEX | 195693 | Inside loadEventBindings
                                                04/23/15 22:31:21:456 | [INFO] | 27142 | ACCC | HEX | HEX |  | HEX | 195693 | Return from loadEventBindings: 1
                                                04/23/15 22:31:21:456 | [INFO] | 27142 | ACCC | HEX | HEX |  | HEX | 195693 | Inside loadPropertyBindings
                                                04/23/15 22:31:21:457 | [INFO] | 27142 | ACCC | HEX | HEX |  | HEX | 195693 | Inside registerPropertyBindingsWithCore
                                                04/23/15 22:31:21:457 | [WARN] | 27142 | ACCC | Core | CoreCommandHandler |  | Core | 195693 | No property specified in RegisterProperties xml data
                                                04/23/15 22:31:21:457 | [INFO] | 27142 | ACCC | HEX | HEX |  | HEX | 195693 | Return from registerPropertyBindingsWithCore
                                                04/23/15 22:31:21:457 | [INFO] | 27142 | ACCC | HEX | HEX |  | HEX | 195693 | Return from loadPropertyBindings: 1
                                                04/23/15 22:31:21:458 | [INFO] | 27142 | ACCC | HEX | HEX |  | HEX | 195693 | Inside LoadBindings
                                                04/23/15 22:31:21:458 | [INFO] | 27142 | ACCC | HEX | HEX |  | HEX | 195693 | Inside loadEventBindings
                                                04/23/15 22:31:21:459 | [INFO] | 27142 | ACCC | HEX | HEX |  | HEX | 195693 | Return from loadEventBindings: 1
                                                04/23/15 22:31:21:459 | [INFO] | 27142 | ACCC | HEX | HEX |  | HEX | 195693 | Inside loadPropertyBindings
                                                04/23/15 22:31:21:459 | [INFO] | 27142 | ACCC | HEX | HEX |  | HEX | 195693 | Inside registerPropertyBindingsWithCore
                                                04/23/15 22:31:21:460 | [WARN] | 27142 | ACCC | Core | CoreCommandHandler |  | Core | 195693 | No property specified in RegisterProperties xml data
                                                04/23/15 22:31:21:460 | [INFO] | 27142 | ACCC | HEX | HEX |  | HEX | 195693 | Return from registerPropertyBindingsWithCore
                                                04/23/15 22:31:21:460 | [INFO] | 27142 | ACCC | HEX | HEX |  | HEX | 195693 | Return from loadPropertyBindings: 1
                                                04/23/15 22:31:21:460 | [INFO] | 27142 | ACCC | HEX | HEX |  | HEX | 195693 | Inside LoadBindings
                                                04/23/15 22:31:21:461 | [INFO] | 27142 | ACCC | HEX | HEX |  | HEX | 195693 | Inside LoadBindings
                                                04/23/15 22:31:21:462 | [INFO] | 27142 | ACCC | HEX | HEX |  | HEX | 195693 | Inside loadEventBindings
                                                04/23/15 22:31:21:462 | [INFO] | 27142 | ACCC | HEX | HEX |  | HEX | 195693 | Return from loadEventBindings: 1
                                                04/23/15 22:31:21:463 | [INFO] | 27142 | ACCC | HEX | HEX |  | HEX | 195693 | Inside loadPropertyBindings
                                                04/23/15 22:31:21:463 | [INFO] | 27142 | ACCC | HEX | HEX |  | HEX | 195693 | propertyBindings Node not present in XML
                                                04/23/15 22:31:21:463 | [INFO] | 27142 | ACCC | HEX | HEX |  | HEX | 195693 | Inside registerPropertyBindingsWithCore
                                                04/23/15 22:31:21:463 | [WARN] | 27142 | ACCC | Core | CoreCommandHandler |  | Core | 195693 | No property specified in RegisterProperties xml data
                                                04/23/15 22:31:21:463 | [INFO] | 27142 | ACCC | HEX | HEX |  | HEX | 195693 | Return from registerPropertyBindingsWithCore
                                                04/23/15 22:31:21:463 | [INFO] | 27142 | ACCC | HEX | HEX |  | HEX | 195693 | Return from loadPropertyBindings: 0
                                                04/23/15 22:31:21:464 | [INFO] | 27142 | ACCC | HEX | HEX |  | HEX | 195693 | Inside LoadBindings
                                                04/23/15 22:31:21:467 | [INFO] | 27142 | ACCC | LocalizationManager |  |  | LocalizationManager | 195693 | Inside GetLocaleForApplet
                                                04/23/15 22:31:21:472 | [INFO] | 27142 | ACCC | c3containerUI | UIManager |  | c3containerUI | 195693 | View Created
                                                04/23/15 22:31:21:478 | [INFO] | 27142 | ACCC | VulcanWrapper | VulcanInterface |  | VulcanWrapper | 195716 | Received RefreshEndPoints callback:
                                                And then the only other thing that's generated is the crash log, which looks like this:
                                                Process:               Creative Cloud [9185]
                                                Responsible:           Creative Cloud [9185]
                                                User ID:               501
                                                Date/Time:             2015-04-23 22:31:21.500 -0700
                                                Report Version:        11
                                                Time Awake Since Boot: 16000 seconds
                                                Crashed Thread:        24
                                                abort() called
                                                Thread 0:: CrBrowserMain  Dispatch queue: com.apple.main-thread
                                                0   libobjc.A.dylib               0x92c6b39c objc::DenseMapBase<objc::DenseMap<DisguisedPtr<objc_object>, unsigned long, true, objc::DenseMapInfo<DisguisedPtr<objc_object> > >, DisguisedPtr<objc_object>, unsigned long, objc::DenseMapInfo<DisguisedPtr<objc_object> >, true>::FindAndConstruct(DisguisedPtr<objc_object> const&) + 38
                                                1   libobjc.A.dylib               0x92c6a1ce objc_object::sidetable_retain() + 90
                                                2   com.apple.CoreFoundation       0x90b4955c -[__NSPlaceholderArray initWithObjects:count:] + 204
                                                3   com.apple.CoreFoundation       0x90b96ca4 +[NSArray array] + 68
                                                4   com.apple.AppKit               0x998a014a -[NSView subviews] + 46
                                                5   com.apple.AppKit               0x99ffba84 _testForVibrancyForViewHierarchyStartingAt + 142
                                                6   com.apple.AppKit               0x99ffbadc _testForVibrancyForViewHierarchyStartingAt + 230
                                                7   com.apple.AppKit               0x99ffc128 -[NSStatusBarWindow flushWindow] + 35
                                                8   com.apple.AppKit               0x99952a68 -[NSView _displayRectIgnoringOpacity:isVisibleRect:rectIsVisibleRectForView:] + 4830
                                                9   com.apple.AppKit               0x999052ce -[NSView displayIfNeeded] + 1629
                                                10  com.apple.AppKit               0x99ac8cf6 -[NSNextStepFrame displayIfNeeded] + 48
                                                11  com.apple.AppKit               0x99904bbc -[NSWindow displayIfNeeded] + 324
                                                12  com.apple.AppKit               0x999047a0 _handleWindowNeedsDisplayOrLayoutOrUpdateConstraints + 1262
                                                13  com.apple.AppKit               0x9a0ef58b __83-[NSWindow _postWindowNeedsDisplayOrLayoutOrUpdateConstraintsUnlessPostingDisabled]_block_invoke1579 + 58
                                                14  com.apple.CoreFoundation       0x90bc8e3d _runLoopObserverWithBlockContext + 29
                                                15  com.apple.CoreFoundation       0x90bc881e __CFRUNLOOP_IS_CALLING_OUT_TO_AN_OBSERVER_CALLBACK_FUNCTION__ + 30
                                                16  com.apple.CoreFoundation       0x90bc8760 __CFRunLoopDoObservers + 400
                                                17  com.apple.CoreFoundation       0x90bba0c2 __CFRunLoopRun + 946
                                                18  com.apple.CoreFoundation       0x90bb9aa6 CFRunLoopRunSpecific + 390
                                                19  com.apple.CoreFoundation       0x90bb990b CFRunLoopRunInMode + 123
                                                20  com.apple.HIToolbox           0x911d98f8 RunCurrentEventLoopInMode + 262
                                                21  com.apple.HIToolbox           0x911d9503 ReceiveNextEventCommon + 192
                                                22  com.apple.HIToolbox           0x911d942c _BlockUntilNextEventMatchingListInModeWithFilter + 99
                                                23  com.apple.AppKit               0x99901721 _DPSNextEvent + 742
                                                24  com.apple.AppKit               0x99900dc5 -[NSApplication nextEventMatchingMask:untilDate:inMode:dequeue:] + 350
                                                25  com.apple.AppKit               0x998f577c -[NSApplication run] + 907
                                                26  libcef.dylib                   0x046ade17 0x44a3000 + 2141719
                                                27  libcef.dylib                   0x046ad61c 0x44a3000 + 2139676
                                                28  libcef.dylib                   0x046e16f8 0x44a3000 + 2352888
                                                29  libcef.dylib                   0x046fa11e 0x44a3000 + 2453790
                                                30  libcef.dylib                   0x046e0d6a 0x44a3000 + 2350442
                                                31  libcef.dylib                   0x0451a22f 0x44a3000 + 487983
                                                32  HEX.dylib                     0x043e0e6a HEXMessageProcessor::runLoop(std::string const&) + 378
                                                33  HEX.dylib                     0x043b3a28 0x43b1000 + 10792
                                                34  HEX.dylib                     0x043e8e6d HEXMessageProcessor::processMessage(std::string const&, std::string const&, ProcessMessageOutput&, MessageObject const&) + 77
                                                35  HEX.dylib                     0x043b211f processMessage + 175
                                                36  Core.dylib                     0x002b8541 ExternalGateway::sendMessageToApplet(MessageObject const&, MessageStruct const*, bool (**)(void const*), char const**) + 1617
                                                37  Core.dylib                     0x002b7d07 ExternalGateway::handleMessage(MessageObject const&, MessageStruct const*, bool (**)(void const*), char const**) + 439
                                                38  Core.dylib                     0x002ba2b6 ExternalGateway::processMessageFromOutside(MessageStruct const*, bool (**)(void const*)) + 390
                                                39  com.adobe.acc.AdobeCreativeCloud 0x0010dc95 0xee000 + 130197
                                                40  com.adobe.acc.AdobeCreativeCloud 0x000fbba7 0xee000 + 56231
                                                41  com.adobe.acc.AdobeCreativeCloud 0x000fe588 0xee000 + 66952
                                                42  com.adobe.acc.AdobeCreativeCloud 0x000fd98a 0xee000 + 63882
                                                43  com.adobe.acc.AdobeCreativeCloud 0x000fcec9 0xee000 + 61129
                                                44  com.adobe.acc.AdobeCreativeCloud 0x000efbe5 start + 53
                                                Thread 1:: Dispatch queue: com.apple.libdispatch-manager
                                                0   libsystem_kernel.dylib         0x970248ce kevent64 + 10
                                                1   libdispatch.dylib             0x916f173f _dispatch_mgr_invoke + 245
                                                2   libdispatch.dylib             0x916f13a2 _dispatch_mgr_thread + 52
                                                Thread 2:: Dispatch queue: NSOperationQueue 0x7d022c70 :: NSOperation 0x7d196140 (QOS: USER_INITIATED)
                                                0   libsystem_kernel.dylib         0x970238f6 __semwait_signal + 10
                                                1   libsystem_c.dylib             0x951b8c06 nanosleep$UNIX2003 + 218
                                                2   libsystem_c.dylib             0x951b8ab2 usleep$UNIX2003 + 60
                                                3   VulcanWrapper.dylib           0x01e132cc adobe::VulcanWrapper::VulcanInterface::refreshEndPoints(bool const&) + 172
                                                4   VulcanWrapper.dylib           0x01e149af adobe::VulcanWrapper::VulcanInterface::sendMessageHelper(VulcanWrapperMsg*, adobe::vulcan::api5::SuiteMessage&) + 335
                                                5   VulcanWrapper.dylib           0x01e15174 adobe::VulcanWrapper::VulcanInterface::sendMessage(VulcanWrapperMsg*) + 820
                                                6   VulcanWrapper.dylib           0x01e129e1 sendMessage + 49
                                                7   CmdCntr.dylib                 0x01d95844 adobe::CmdCntr::VulcanWrapperInterface::sendMessage(VulcanWrapperMsg*) + 36
                                                8   CmdCntr.dylib                 0x01d9004d adobe::CmdCntr::MessageRouter::handleMsgFromCore(MessageObject*) + 765
                                                9   CmdCntr.dylib                 0x01d8edb3 adobe::CmdCntr::AppletCoreInterface::receiveMessageFromCore(MessageStruct const*, char**) + 99
                                                10  CmdCntr.dylib                 0x01d8b039 processMessage + 265
                                                11  Core.dylib                     0x002b8dcd ExternalGateway::sendMessageToCmdCntr(MessageObject const&, MessageStruct const*, bool (**)(void const*), char const**) + 445
                                                12  Core.dylib                     0x002b9654 ExternalGateway::sendMessageToOtherInstances(MessageObject const&, std::string const&, std::string const&, std::string const&) + 996
                                                13  Core.dylib                     0x002b86c1 ExternalGateway::sendMessageToApplet(MessageObject const&, MessageStruct const*, bool (**)(void const*), char const**) + 2001
                                                14  Core.dylib                     0x002b7d07 ExternalGateway::handleMessage(MessageObject const&, MessageStruct const*, bool (**)(void const*), char const**) + 439
                                                15  Core.dylib                     0x002ba2b6 ExternalGateway::processMessageFromOutside(MessageStruct const*, bool (**)(void const*)) + 390
                                                16  Analytics.dylib               0x023cd278 ExternalGatewayBase::sendMessage(MessageObject const&) + 72
                                                17  Analytics.dylib               0x023d29c5 AnalyticsManager::updateUserProfile() + 453
                                                18  Analytics.dylib               0x023d41d4 AnalyticsManager::sendETSEvent(MessageObject const&) + 692
                                                19  Analytics.dylib               0x023ccf36 processMessage + 550
                                                20  Core.dylib                     0x002b87c3 ExternalGateway::sendMessageToApplet(MessageObject const&, MessageStruct const*, bool (**)(void const*), char const**) + 2259
                                                21  Core.dylib                     0x002b8fca ExternalGateway::sendMessageToAllAppletInstances(Applet*, MessageObject&) + 202
                                                22  Core.dylib                     0x002b8085 ExternalGateway::sendMessageToApplet(MessageObject const&, MessageStruct const*, bool (**)(void const*), char const**) + 405
                                                23  Core.dylib                     0x002b7d07 ExternalGateway::handleMessage(MessageObject const&, MessageStruct const*, bool (**)(void const*), char const**) + 439
                                                24  Core.dylib                     0x002b6f32 0x293000 + 147250
                                                25  com.apple.CoreFoundation       0x90b8003d __invoking___ + 29
                                                26  com.apple.CoreFoundation       0x90b7ff1d -[NSInvocation invoke] + 317
                                                27  com.apple.Foundation           0x9184cac9 -[NSInvocationOperation main] + 219
                                                28  com.apple.Foundation           0x917f337e -[__NSOperationInternal _start:] + 770
                                                29  com.apple.Foundation           0x917f3071 -[NSOperation start] + 71
                                                30  com.apple.Foundation           0x917f2d8b __NSOQSchedule_f + 213
                                                31  libdispatch.dylib             0x916ee130 _dispatch_client_callout + 50
                                                32  libdispatch.dylib             0x916f1d05 _dispatch_queue_drain + 1017
                                                33  libdispatch.dylib             0x916f399d _dispatch_queue_invoke + 186
                                                34  libdispatch.dylib             0x916f0f89 _dispatch_root_queue_drain + 395
                                                35  libdispatch.dylib             0x9170063d _dispatch_worker_thread3 + 97
                                                36  libsystem_pthread.dylib       0x916261da _pthread_wqthread + 724
                                                37  libsystem_pthread.dylib       0x91623e2e start_wqthread + 30
                                                Thread 3:
                                                0   libsystem_kernel.dylib         0x97023e6a __workq_kernreturn + 10
                                                1   libsystem_pthread.dylib       0x916262b1 _pthread_wqthread + 939
                                                2   libsystem_pthread.dylib       0x91623e2e start_wqthread + 30
                                                Thread 4:
                                                Thread 5:
                                                0   libsystem_kernel.dylib         0x9702376e __recvfrom + 10
                                                1   libsystem_c.dylib             0x951b8d22 recv$UNIX2003 + 55
                                                2   VulcanMessage5.dylib           0x01e9ae5f vcfoundation::net::Bsd::Recv(int, void*, int, int) + 45
                                                3   VulcanMessage5.dylib           0x01e98c31 vcfoundation::io::BSDNamedPipe::Read(void*, unsigned long) + 43
                                                4   VulcanMessage5.dylib           0x01e965ea vcfoundation::io::BufferedReader::InternalRead(char*, long) + 102
                                                5   VulcanMessage5.dylib           0x01e9665f vcfoundation::io::BufferedReader::Read(void*, unsigned long) + 67
                                                6   VulcanMessage5.dylib           0x01e8ebbd vcfoundation::io::IVCChannel::ReadFully(void*, unsigned long) + 75
                                                7   VulcanMessage5.dylib           0x01e8f791 vcfoundation::io::Serializer::InternalDeserialize() + 43
                                                8   VulcanMessage5.dylib           0x01e8f64b vcfoundation::io::Serializer::Deserialize() + 17
                                                9   VulcanMessage5.dylib           0x01e94fb7 vcfoundation::ncomm::Connection::ReadIn() + 23
                                                10  VulcanMessage5.dylib           0x01e95110 vcfoundation::ncomm::NCService::ReadResponse(vcfoundation::ncomm::INCRequest*, vcfoundation::ncomm::INCListener&, vcfoundation::ncomm::NCService::ConRef&) + 32
                                                11  VulcanMessage5.dylib           0x01e94ec3 vcfoundation::ncomm::NCService::Execute(vcfoundation::ncomm::INCRequest*, vcfoundation::ncomm::INCListener&) + 135
                                                12  VulcanMessage5.dylib           0x01e94e2b vcfoundation::ncomm::NCService::Execute(vcfoundation::ncomm::INCRequest*) + 49
                                                13  VulcanMessage5.dylib           0x01e85595 adobe::vulcan::servicemgr::CSIRequest::Execute() + 65
                                                14  VulcanMessage5.dylib           0x01e8685e adobe::vulcan::servicemgr::RegisterForEventsRequest::Run() + 416
                                                15  VulcanMessage5.dylib           0x01e95bac vcfoundation::thread::AbstractThread::Run() + 50
                                                16  VulcanMessage5.dylib           0x01e9a635 vcfoundation::thread::Thread::ThreadProc(void*) + 17
                                                17  libsystem_pthread.dylib       0x91625e13 _pthread_body + 138
                                                18  libsystem_pthread.dylib       0x91625d89 _pthread_start + 162
                                                19  libsystem_pthread.dylib       0x91623e52 thread_start + 34
                                                Thread 6:
                                                0   libsystem_kernel.dylib         0x97023512 __psynch_cvwait + 10
                                                1   libsystem_pthread.dylib       0x91626a4a _pthread_cond_wait + 726
                                                2   libsystem_pthread.dylib       0x9162a1c0 pthread_cond_wait$UNIX2003 + 71
                                                3   Analytics.dylib               0x023f755b OOBEUtils::OOBEEventsIntl::WaitforEvntIntl(long long) + 171
                                                4   Analytics.dylib               0x0242b578 ETSFramework::AsynchEventProcessor::MainThreadProc(void*) + 264
                                                5   libsystem_pthread.dylib       0x91625e13 _pthread_body + 138
                                                6   libsystem_pthread.dylib       0x91625d89 _pthread_start + 162
                                                7   libsystem_pthread.dylib       0x91623e52 thread_start + 34
                                                Thread 7:
                                                Thread 8:
                                                Thread 9:: NetworkConfigWatcher
                                                0   libsystem_kernel.dylib         0x9701d9ce mach_msg_trap + 10
                                                1   libsystem_kernel.dylib         0x9701ca70 mach_msg + 68
                                                2   com.apple.CoreFoundation       0x90bbaef6 __CFRunLoopServiceMachPort + 214
                                                3   com.apple.CoreFoundation       0x90bba309 __CFRunLoopRun + 1529
                                                4   com.apple.CoreFoundation       0x90bb9aa6 CFRunLoopRunSpecific + 390
                                                5   com.apple.CoreFoundation       0x90bb990b CFRunLoopRunInMode + 123
                                                6   com.apple.Foundation           0x9182e34a -[NSRunLoop(NSRunLoop) runMode:beforeDate:] + 305
                                                7   libcef.dylib                   0x046ad94f 0x44a3000 + 2140495
                                                8   libcef.dylib                   0x046ad61c 0x44a3000 + 2139676
                                                9   libcef.dylib                   0x046e16f8 0x44a3000 + 2352888
                                                10  libcef.dylib                   0x046fa11e 0x44a3000 + 2453790
                                                11  libcef.dylib                   0x046e0d6a 0x44a3000 + 2350442
                                                12  libcef.dylib                   0x04712851 0x44a3000 + 2553937
                                                13  libcef.dylib                   0x047128ed 0x44a3000 + 2554093
                                                14  libcef.dylib                   0x0470d2e5 0x44a3000 + 2532069
                                                15  libsystem_pthread.dylib       0x91625e13 _pthread_body + 138
                                                16  libsystem_pthread.dylib       0x91625d89 _pthread_start + 162
                                                17  libsystem_pthread.dylib       0x91623e52 thread_start + 34
                                                Thread 10:: DnsConfigService
                                                0   libsystem_kernel.dylib         0x970248b2 kevent + 10
                                                1   libcef.dylib                   0x04a4bca6 0x44a3000 + 5934246
                                                2   libcef.dylib                   0x04a49919 0x44a3000 + 5925145
                                                3   libcef.dylib                   0x046ac681 0x44a3000 + 2135681
                                                4   libcef.dylib                   0x046e16f8 0x44a3000 + 2352888
                                                5   libcef.dylib                   0x046fa11e 0x44a3000 + 2453790
                                                6   libcef.dylib                   0x046e0d6a 0x44a3000 + 2350442
                                                7   libcef.dylib                   0x04712851 0x44a3000 + 2553937
                                                8   libcef.dylib                   0x047128ed 0x44a3000 + 2554093
                                                9   libcef.dylib                   0x0470d2e5 0x44a3000 + 2532069
                                                10  libsystem_pthread.dylib       0x91625e13 _pthread_body + 138
                                                11  libsystem_pthread.dylib       0x91625d89 _pthread_start + 162
                                                12  libsystem_pthread.dylib       0x91623e52 thread_start + 34
                                                Thread 11:: WorkerPool/26891
                                                2   libsystem_pthread.dylib       0x9162a20c pthread_cond_timedwait$UNIX2003 + 71
                                                3   libcef.dylib                   0x047061f9 0x44a3000 + 2503161
                                                4   libcef.dylib                   0x04714acf 0x44a3000 + 2562767
                                                5   libcef.dylib                   0x04714fbc 0x44a3000 + 2564028
                                                6   libcef.dylib                   0x0470d2e5 0x44a3000 + 2532069
                                                Thread 12:: WorkerPool/27667
                                                Thread 13:: AudioThread
                                                Thread 14:: Chrome_DBThread
                                                3   libcef.dylib                   0x04706003 0x44a3000 + 2502659
                                                4   libcef.dylib                   0x04706c8b 0x44a3000 + 2505867
                                                5   libcef.dylib                   0x04706a92 0x44a3000 + 2505362
                                                6   libcef.dylib                   0x046e574c 0x44a3000 + 2369356
                                                7   libcef.dylib                   0x046e16f8 0x44a3000 + 2352888
                                                8   libcef.dylib                   0x046fa11e 0x44a3000 + 2453790
                                                9   libcef.dylib                   0x046e0d6a 0x44a3000 + 2350442
                                                10  libcef.dylib                   0x04712851 0x44a3000 + 2553937
                                                11  libcef.dylib                   0x064a96c9 0x44a3000 + 33580745
                                                12  libcef.dylib                   0x064a9aef 0x44a3000 + 33581807
                                                Thread 15:: Chrome_WebKitThread
                                                11  libcef.dylib                   0x064a9759 0x44a3000 + 33580889
                                                12  libcef.dylib                   0x064a9b00 0x44a3000 + 33581824
                                                Thread 16:: Chrome_FileThread
                                                8   libcef.dylib                   0x064a97e9 0x44a3000 + 33581033
                                                9   libcef.dylib                   0x064a9b11 0x44a3000 + 33581841
                                                10  libcef.dylib                   0x047128ed 0x44a3000 + 2554093
                                                11  libcef.dylib                   0x0470d2e5 0x44a3000 + 2532069
                                                12  libsystem_pthread.dylib       0x91625e13 _pthread_body + 138
                                                13  libsystem_pthread.dylib       0x91625d89 _pthread_start + 162
                                                14  libsystem_pthread.dylib       0x91623e52 thread_start + 34
                                                Thread 17:: Chrome_FileUserBlockingThread
                                                11  libcef.dylib                   0x064a9879 0x44a3000 + 33581177
                                                12  libcef.dylib                   0x064a9b22 0x44a3000 + 33581858
                                                Thread 18:: Chrome_ProcessLauncherThread
                                                11  libcef.dylib                   0x064a9909 0x44a3000 + 33581321
                                                12  libcef.dylib                   0x064a9b33 0x44a3000 + 33581875
                                                Thread 19:: Chrome_CacheThread
                                                8   libcef.dylib                   0x064a9999 0x44a3000 + 33581465
                                                9   libcef.dylib                   0x064a9b41 0x44a3000 + 33581889
                                                Thread 20:: Chrome_IOThread
                                                3   libcef.dylib                   0x046ac77c 0x44a3000 + 2135932
                                                8   libcef.dylib                   0x064a9a29 0x44a3000 + 33581609
                                                9   libcef.dylib                   0x064a9b4f 0x44a3000 + 33581903
                                                Thread 21:: MediaStreamDeviceThread
                                                11  libcef.dylib                   0x047128ed 0x44a3000 + 2554093
                                                12  libcef.dylib                   0x0470d2e5 0x44a3000 + 2532069
                                                13  libsystem_pthread.dylib       0x91625e13 _pthread_body + 138
                                                14  libsystem_pthread.dylib       0x91625d89 _pthread_start + 162
                                                15  libsystem_pthread.dylib       0x91623e52 thread_start + 34
                                                Thread 22:: NetworkConfigWatcher
                                                Thread 23:: Proxy resolver
                                                Thread 24 Crashed:
                                                0   libsystem_kernel.dylib         0x9702369a __pthread_kill + 10
                                                1   libsystem_pthread.dylib       0x91627f19 pthread_kill + 101
                                                2   libsystem_c.dylib             0x95198eee abort + 156
                                                3   libc++abi.dylib               0x900e22f9 abort_message + 169
                                                4   libc++abi.dylib               0x90105483 default_terminate_handler() + 272
                                                5   libc++abi.dylib               0x90102ac0 std::__terminate(void (*)()) + 14
                                                6   libc++abi.dylib               0x901024db __cxa_throw + 122
                                                7   libstdc++.6.dylib             0x97877c9a std::__throw_logic_error(char const*) + 106
                                                8   libstdc++.6.dylib             0x978a4e79 char* std::string::_S_construct<char const*>(char const*, char const*, std::allocator<char> const&, std::forward_iterator_tag) + 143
                                                9   libstdc++.6.dylib             0x978a2db7 std::basic_string<char, std::char_traits<char>, std::allocator<char> >::basic_string(char const*, std::allocator<char> const&) + 53
                                                10  com.adobe.acc.ContainerUI     0x07fdac44 OOBEUtils::ProcessUtils::GetProcessInstancesCount(std::string const&, bool, std::string const&, void*) + 548
                                                11  com.adobe.acc.ContainerUI     0x07fdb29f OOBEUtils::ProcessUtils::GetUserProcessInstancesCount(std::string const&, bool, void*) + 111
                                                12  com.adobe.acc.ContainerUI     0x07fa0c9e ApplicationContext::launchADSIfNotRunning() + 78
                                                13  com.adobe.acc.ContainerUI     0x07f96c01 0x7f2e000 + 429057
                                                14  com.adobe.acc.ContainerUI     0x07fed470 threadProcHandlerMac(void*) + 48
                                                Thread 24 crashed with X86 Thread State (32-bit):
                                                  eax: 0x00000000  ebx: 0xa09226d0  ecx: 0xb6c7e79c  edx: 0x00000000
                                                  edi: 0xb6c7f000  esi: 0x00000006  ebp: 0xb6c7e7b8  esp: 0xb6c7e79c
                                                   ss: 0x00000023  efl: 0x00000206  eip: 0x9702369a   cs: 0x0000000b
                                                   ds: 0x00000023   es: 0x00000023   fs: 0x00000023   gs: 0x0000000f
                                                  cr2: 0xa0920a00
                                                Logical CPU:     0
                                                Error Code:      0x00080148
                                                Trap Number:     132
                                                Binary Images:
                                                   0xee000 -   0x168ff3 +com.adobe.acc.AdobeCreativeCloud (2.0.0.74 - ???) <4E7EB4CE-6960-31E4-B66F-795823389DAD> /Applications/Utilities/Adobe Creative Cloud/*/Creative Cloud.app/Contents/MacOS/Creative Cloud
                                                  0x293000 -   0x309ff7 +Core.dylib (3.0.0.74 - 3.0.0.74) <6745CC0F-075C-3872-B7E7-A89F0AC570A5> /Library/Application Support/Adobe/*/Core.dylib
                                                0x1a83000 -  0x1b04ff7  com.apple.xquery (1.3.1 - 30) <6B4EF9B6-DF7B-3A1A-8C60-2419453F0BFE> /System/Library/PrivateFrameworks/XQuery.framework/XQuery
                                                0x1b91000 -  0x1d6aff7 +AdobePIM.dylib (3.0.0.74 - 3.0.0.74) <DB3BD13F-7E2F-3804-A4EC-9707E0A47AC3> /Library/Application Support/Adobe/*/AdobePIM.dylib
                                                0x1d8a000 -  0x1de8ff7 +CmdCntr.dylib (3.0.0.74 - 3.0.0.74) <A5E15BA8-19A3-3F24-B4C0-ED56DD83CE91> /Library/Application Support/Adobe/*/CmdCntr.dylib
                                                0x1e11000 -  0x1e56ff3 +VulcanWrapper.dylib (3.0.0.74 - 3.0.0.74) <B6A37A1D-76AB-39AB-B06E-8AF24AD8604D> /Library/Application Support/Adobe/*/VulcanWrapper.dylib
                                                0x1e7b000 -  0x1eb4ff7 +VulcanMessage5.dylib (5.0.0.75 - 5.0.0.75 © 2013 Adobe Systems, Inc. All rights reserved.) <06D86E7A-4799-30BF-833D-BA96ECE7A353> /Library/Application Support/Adobe/*/VulcanMessage5.dylib
                                                0x1ef2000 -  0x2131fff +PrefsManager.dylib (3.0.0.74 - 3.0.0.74) <E0F4F7EB-FEAD-35C1-A7C6-B807C4B84849> /Library/Application Support/Adobe/*/PrefsManager.dylib
                                                0x2326000 -  0x23a6ff3 +LocManager.dylib (3.0.0.74 - 3.0.0.74) <DEAE6FAD-76C5-34AE-A564-F484CAE3B28A> /Library/Application Support/Adobe/*/LocManager.dylib
                                                0x23cb000 -  0x2443fff +Analytics.dylib (3.0.0.74 - 3.0.0.74) <A5AF7998-8677-3A11-B995-36994A389E40> /Library/Application Support/Adobe/*/Analytics.dylib
                                                0x27d1000 -  0x27d1ff1 +libplugin_carbon_interpose.dylib (31339.5.173) <A11A7D5A-49C9-34E4-A15B-70F29CA0FAF3> /Library/Application Support/Adobe/*/libplugin_carbon_interpose.dylib
                                                0x27eb000 -  0x27effff  com.apple.audio.AppleHDAHALPlugIn (272.18 - 272.18) <FCD052AE-05F8-39C1-A378-F10B15F589E6> /System/Library/Extensions/AppleHDA.kext/Contents/PlugIns/AppleHDAHALPlugIn.bundle/Conten ts/MacOS/AppleHDAHALPlugIn
                                                0x3a62000 -  0x3aaffff  com.apple.CloudDocs (1.0 - 321.6) <EF208D9F-9E6C-3FF9-AC82-3C2B4EBFAB89> /System/Library/PrivateFrameworks/CloudDocs.framework/CloudDocs
                                                0x43b1000 -  0x446dff7 +HEX.dylib (3.0.0.74 - 3.0.0.74) <90DF20AC-6AAB-39CE-82E1-9911CD5C04A8> /Library/Application Support/Adobe/*/HEX.dylib
                                                0x44a3000 -  0x79deffb +libcef.dylib (31339.5.173) <E46B2271-6FE3-3328-859B-9026ECD0C41E> /Library/Application Support/Adobe/*/Chromium Embedded Framework.framework/Libraries/libcef.dylib
                                                0x7f2e000 -  0x8055ff7 +com.adobe.acc.ContainerUI (3.0.0.74 - 3.0.0.74) <E720E64F-E2C4-31CB-BC6E-DCE4B1A90DD3> /Applications/Utilities/Adobe Creative Cloud/*/ContainerUI.bundle/Contents/MacOS/ContainerUI
                                                0x8fe08000 - 0x8fe3be03  dyld (353.2.1) <06B1254D-9BB9-327C-BA15-8F18FFF97586> /usr/lib/dyld
                                                0x90008000 - 0x9007eff7  com.apple.SearchKit (1.4.0 - 1.4.0) <3693A221-B615-37D4-9FB1-F5F6CC7EE1A7> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/SearchKit.framewo rk/Versions/A/SearchKit
                                                0x9007f000 - 0x9008bff3  libcommonCrypto.dylib (60061) <024B3913-15C6-3005-9E5A-EB24918F6977> /usr/lib/system/libcommonCrypto.dylib
                                                0x900de000 - 0x900e0ff7  libquarantine.dylib (76.20.1) <8694AC5A-7359-3CC6-8E93-CABFCC919D4B> /usr/lib/system/libquarantine.dylib
                                                0x900e1000 - 0x90107ff3  libc++abi.dylib (125) <E9AF8CA1-D54D-37E3-8363-A3E8C0840F71> /usr/lib/libc++abi.dylib
                                                0x90108000 - 0x90123ff3  com.apple.openscripting (1.4 - 162.1) <CC32543F-0BEA-3022-AF35-5149C50DE902> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/OpenScripting.framework /Versions/A/OpenScripting
                                                0x903be000 - 0x903bffff  com.apple.TrustEvaluationAgent (2.0 - 25) <28BBD931-EF7C-3753-B50E-6568F4075086> /System/Library/PrivateFrameworks/TrustEvaluationAgent.framework/Versions/A/TrustEvaluati onAgent
                                                0x903fb000 - 0x903fdfff  com.apple.securityhi (9.0 - 55006) <B87325C7-1F87-3D3C-874C-9DF59C8EBE1E> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SecurityHI.framework/Ve rsions/A/SecurityHI
                                                0x903fe000 - 0x90401fff  libdyld.dylib (353.2.1) <30CE0D0E-7E82-3CD5-92E7-9C1D6AD3327C> /usr/lib/system/libdyld.dylib
                                                0x90402000 - 0x9045fff7  com.apple.print.framework.PrintCore (10.3 - 451.1) <86895179-C54B-3D8A-B515-92DFA6315FC9> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/PrintCore. framework/Versions/A/PrintCore
                                                0x90460000 - 0x90460fff  com.apple.ApplicationServices (48 - 48) <76C301A4-705B-33DE-BA11-C89DCF1EDCDD> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/ApplicationServices
                                                0x90461000 - 0x90474fff  com.apple.CoreBluetooth (1.0 - 1) <153F2DDE-CCCF-3C63-AF70-2EA306DACDCD> /System/Library/Frameworks/CoreBluetooth.framework/Versions/A/CoreBluetooth
                                                0x904a3000 - 0x907fdff7  libmecabra.dylib (666.7) <55A50B97-92D3-3DDC-8E3A-58BC5FFE5E3F> /usr/lib/libmecabra.dylib
                                                0x907fe000 - 0x9080bff7  libbz2.1.0.dylib (36) <6BC7B049-8F03-3217-9840-B1804CCBF742> /usr/lib/libbz2.1.0.dylib
                                                0x9080c000 - 0x9080efff  libCVMSPluginSupport.dylib (11.1.2) <2C725DC9-0773-3637-B905-7A8B2001192F> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCVMSPluginSupport.dyl ib
                                                0x9080f000 - 0x90828fff  com.apple.Kerberos (3.0 - 1) <92735F11-CF1C-3FA6-8682-9A30AC9E2651> /System/Library/Frameworks/Kerberos.framework/Versions/A/Kerberos
                                                0x9082d000 - 0x90836fff  libGFXShared.dylib (11.1.2) <C67D9D93-6172-3AD6-BBB2-A18C9EC94570> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGFXShared.dylib
                                                0x90837000 - 0x90837fff  com.apple.audio.units.AudioUnit (1.12 - 1.12) <CFB6243A-1613-3468-88CE-1DDBEC1E6984> /System/Library/Frameworks/AudioUnit.framework/Versions/A/AudioUnit
                                                0x90838000 - 0x9087fff3  com.apple.AppleJPEG (1.0 - 1) <677BE130-F5AB-36F4-A51A-1FF20FC0085A> /System/Library/PrivateFrameworks/AppleJPEG.framework/Versions/A/AppleJPEG
                                                0x90a31000 - 0x90a35ffb  libGIF.dylib (1237) <F831EEB0-3193-32A7-914D-F77C7D5027E3> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libGIF.dylib
                                                0x90a36000 - 0x90a49fff  com.apple.Sharing (328.16 - 328.16) <57F64876-D785-3B35-91B9-B2800F800C37> /System/Library/PrivateFrameworks/Sharing.framework/Versions/A/Sharing
                                                0x90a4a000 - 0x90a53fff  com.apple.AppleSRP (5.0 - 1) <41C48FA8-C249-3800-A551-7F4AFA3E723F> /System/Library/PrivateFrameworks/AppleSRP.framework/Versions/A/AppleSRP
                                                0x90a59000 - 0x90a63ffb  com.apple.audio.SoundManager (4.2 - 4.2) <4312D0A7-4B6F-3A1E-9A47-24C6E8C65E51> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CarbonSound.framework/V ersions/A/CarbonSound
                                                0x90a64000 - 0x90ac8ff7  com.apple.AE (681.2 - 681.2) <E56D8304-3975-32E0-BBF2-611F04209C2B> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/AE.framework/Vers ions/A/AE
                                                0x90ac9000 - 0x90b34ff7  com.apple.framework.CoreWiFi (3.0 - 300.4) <632A811D-4706-3ED7-85E3-DD2CDB47CF8F> /System/Library/PrivateFrameworks/CoreWiFi.framework/Versions/A/CoreWiFi
                                                0x90b43000 - 0x90ef7ff7  com.apple.CoreFoundation (6.9 - 1153.18) <267B1002-C755-37B4-95CD-92358CF994B8> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation
                                                0x90ef8000 - 0x9100eff3  com.apple.desktopservices (1.9.3 - 1.9.3) <544FDA55-063A-3787-A55A-A54290E4BE6E> /System/Library/PrivateFrameworks/DesktopServicesPriv.framework/Versions/A/DesktopService sPriv
                                                0x9103d000 - 0x91093fff  libc++.1.dylib (120) <D8DE4962-66CD-3491-904E-9291EEE5E570> /usr/lib/libc++.1.dylib
                                                0x91094000 - 0x911aafff  com.apple.CoreText (352.0 - 454.6) <5F236E10-C911-3AAF-8BA6-2F0F68A87443> /System/Library/Frameworks/CoreText.framework/Versions/A/CoreText
                                                0x911ab000 - 0x91584ff3  com.apple.HIToolbox (2.1.1 - 758.7) <A7B81A48-6BB9-35EC-B128-D38AD4EC7802> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Ver sions/A/HIToolbox
                                                0x91585000 - 0x9159efff  libsystem_malloc.dylib (53.1.1) <58CD8BC7-55D1-3862-8E5D-728EE2EBE447> /usr/lib/system/libsystem_malloc.dylib
                                                0x9159f000 - 0x9159ffff  libOpenScriptingUtil.dylib (162.1) <EDDD4BA8-6212-3437-8CFF-117724C12A4E> /usr/lib/libOpenScriptingUtil.dylib
                                                0x915a0000 - 0x915a6ff7  libsystem_networkextension.dylib (167.1.10) <FC20E3AD-A53D-3346-AC71-829E82832AE8> /usr/lib/system/libsystem_networkextension.dylib
                                                0x915a7000 - 0x915aefff  com.apple.speech.recognition.framework (5.0.9 - 5.0.9) <5D268178-3812-3777-92A6-D7D3395405B8> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SpeechRecognition.frame work/Versions/A/SpeechRecognition
                                                0x915af000 - 0x91622ffb  com.apple.framework.CoreWLAN (5.0 - 500.35.2) <8D5F7007-D938-3A4D-841A-647D272D2DB6> /System/Library/Frameworks/CoreWLAN.framework/Versions/A/CoreWLAN
                                                0x91623000 - 0x9162bfff  libsystem_pthread.dylib (105.10.1) <4A229519-29A1-3ABF-8CEF-43BCE4ACDA06> /usr/lib/system/libsystem_pthread.dylib
                                                0x9162c000 - 0x916a2fff  com.apple.securityfoundation (6.0 - 55126) <2DB5BDF8-FB04-317B-9A7F-9AC8733947BF> /System/Library/Frameworks/SecurityFoundation.framework/Versions/A/SecurityFoundation
                                                0x916b1000 - 0x916dafff  libRIP.A.dylib (779.11) <4BD501EF-1671-3165-BD7A-CF227F4BD690> /System/Library/Frameworks/CoreGraphics.framework/Versions/A/Resources/libRIP.A.dylib
                                                0x916db000 - 0x916defff  libpam.2.dylib (20) <E2F34522-448A-3392-BC1D-6625BEB612B9> /usr/lib/libpam.2.dylib
                                                0x916df000 - 0x916ecff7  com.apple.speech.synthesis.framework (5.3.3 - 5.3.3) <3771942E-13BB-30C0-9992-11EE637871DC> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/SpeechSynt hesis.framework/Versions/A/SpeechSynthesis
                                                0x916ed000 - 0x91714fff  libdispatch.dylib (442.1.4) <B26A176C-39F7-3362-B128-27B1211068B9> /usr/lib/system/libdispatch.dylib
                                                0x91715000 - 0x91723ff3  com.apple.opengl (11.1.2 - 11.1.2) <F252DF22-C5E2-3A47-ACB6-2B02D6164A47> /System/Library/Frameworks/OpenGL.framework/Versions/A/OpenGL
                                                0x91724000 - 0x9172aff7  com.apple.MediaAccessibility (1.0 - 61) <81E9530E-882C-313C-A4D5-2F43EB569E4F> /System/Library/Frameworks/MediaAccessibility.framework/Versions/A/MediaAccessibility
                                                0x9173a000 - 0x91749ffb  libxar.1.dylib (255) <4FF7DB6F-3232-302F-94BC-F1188F78AF25> /usr/lib/libxar.1.dylib
                                                0x9174a000 - 0x91793ffb  libFontRegistry.dylib (134.1) <6CF6177B-D5D6-3E7B-88BC-BE833D55018C> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framew ork/Versions/A/Resources/libFontRegistry.dylib
                                                0x91794000 - 0x91af5ff3  com.apple.Foundation (6.9 - 1153.20) <B2539D54-EC35-3388-82C7-B01BB225A804> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation
                                                0x91af9000 - 0x91affff3  libsystem_platform.dylib (63) <509993B7-3F26-3360-B899-0BBB15152516> /usr/lib/system/libsystem_platform.dylib
                                                0x91b00000 - 0x91b07ff3  libunwind.dylib (35.3) <29D9343F-9A0A-3535-B0AE-E7CC761D95EE> /usr/lib/system/libunwind.dylib
                                                0x91b08000 - 0x91b0cfff  libCoreVMClient.dylib (79.1) <3DB52AB1-D41E-3AC9-A355-1B6DCEDB4DFD> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCoreVMClient.dylib
                                                0x91bad000 - 0x91bccffb  libresolv.9.dylib (57) <C2C3810A-A45E-3375-B41D-6E1BECE1BA3C> /usr/lib/libresolv.9.dylib
                                                0x91bcd000 - 0x91be7ff7  liblzma.5.dylib (7) <D0BC984D-5B33-328C-8F1E-7E9C41813433> /usr/lib/liblzma.5.dylib
                                                0x91be8000 - 0x91e6dfff  com.apple.QuickTime (7.7.3 - 2890) <34289D2B-07CC-3D12-8F32-6F97D96DEE81> /System/Library/Frameworks/QuickTime.framework/Versions/A/QuickTime
                                                0x91e6e000 - 0x92256ff7  libLAPACK.dylib (1128) <4E3D1289-2C98-3E53-BB8D-AD911357FF66> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/libLAPACK.dylib
                                                0x9256e000 - 0x925daff3  com.apple.datadetectorscore (6.0 - 396.1.1) <A1ADB604-689E-3B00-BCB2-1B6662644BBD> /System/Library/PrivateFrameworks/DataDetectorsCore.framework/Versions/A/DataDetectorsCor e
                                                0x925db000 - 0x9271fff7  com.apple.ImageIO.framework (3.3.0 - 1237) <314B3F6B-4DC5-31E9-BE67-032901676A34> /System/Library/Frameworks/ImageIO.framework/Versions/A/ImageIO
                                                0x92720000 - 0x9274cfff  com.apple.ChunkingLibrary (2.1 - 163.6) <D5446A27-C51B-36D7-A4A1-3222A87F6F48> /System/Library/PrivateFrameworks/ChunkingLibrary.framework/Versions/A/ChunkingLibrary
                                                0x9274d000 - 0x928b9ff3  com.apple.avfoundation (2.0 - 889.210) <C49EA877-535F-3E27-80B2-87AACA207F33> /System/Library/Frameworks/AVFoundation.framework/Versions/A/AVFoundation
                                                0x928ba000 - 0x9290fff3  com.apple.audio.CoreAudio (4.3.0 - 4.3.0) <2AF304F7-5DA4-3035-9E15-070F16700789> /System/Library/Frameworks/CoreAudio.framework/Versions/A/CoreAudio
                                                0x92911000 - 0x92922fff  libsystem_coretls.dylib (35.20.2) <3688680D-90B5-373F-9E0D-46809E98B023> /usr/lib/system/libsystem_coretls.dylib
                                                0x92923000 - 0x92928ff7  libcompiler_rt.dylib (35) <6630682F-AB76-3E55-BE51-0A3E61B6CFC2> /usr/lib/system/libcompiler_rt.dylib
                                                0x92929000 - 0x9292bffb  libCGXType.A.dylib (779.11) <2B22C4C3-CF75-3909-B9A0-1B9A23028FBB> /System/Library/Frameworks/CoreGraphics.framework/Versions/A/Resources/libCGXType.A.dylib
                                                0x929df000 - 0x92a34ff7  com.apple.htmlrendering (77 - 1.1.4) <B85A63B9-C9DD-3ECC-B5DC-E12533C7FDF9> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HTMLRendering.framework /Versions/A/HTMLRendering
                                                0x92a35000 - 0x92b39ff7  libJP2.dylib (1237) <3A85AB3C-AFC7-3761-A198-D6C7317E476A> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libJP2.dylib
                                                0x92b3a000 - 0x92b64fff  libxslt.1.dylib (13) <0F55B64A-6C55-304E-ACE0-B531027AA066> /usr/lib/libxslt.1.dylib
                                                0x92b65000 - 0x92c4ffff  libcrypto.0.9.8.dylib (52.20.2) <3BE03EE0-9DAE-395D-8292-0371FB21EE3F> /usr/lib/libcrypto.0.9.8.dylib
                                                0x92c50000 - 0x92e3f2ef  libobjc.A.dylib (647) <7648C174-3098-3B26-AD20-490DBFFD5D4C> /usr/lib/libobjc.A.dylib
                                                0x92e40000 - 0x92ed2fff  com.apple.CoreSymbolication (3.1 - 57020.1) <7A6A6AD6-E46A-334F-ACC4-41B179505EC9> /System/Library/PrivateFrameworks/CoreSymbolication.framework/Versions/A/CoreSymbolicatio n
                                                0x92ed3000 - 0x92edcfff  com.apple.DiskArbitration (2.6 - 2.6) <D906604A-1D8C-31BF-8F22-EA219FFC858F> /System/Library/Frameworks/DiskArbitration.framework/Versions/A/DiskArbitration
                                                0x92edd000 - 0x932d4fff  com.apple.CoreGraphics (1.600.0 - 779.11) <C335E1BE-B524-3EE8-969F-329BE9739CC4> /System/Library/Frameworks/CoreGraphics.framework/Versions/A/CoreGraphics
                                                0x932d5000 - 0x932f4ff7  com.apple.MultitouchSupport.framework (263.9.1 - 263.9.1) <9265A1BE-FA6F-38C7-BDFB-FA05EEC683CE> /System/Library/PrivateFrameworks/MultitouchSupport.framework/Versions/A/MultitouchSuppor t
                                                0x932f5000 - 0x9339dff7  com.apple.CoreMedia (1.0 - 1562.235) <BA4933F2-289D-354B-B3B7-451AAF9FBB96> /System/Library/Frameworks/CoreMedia.framework/Versions/A/CoreMedia
                                                0x9339e000 - 0x933cdff7  com.apple.DictionaryServices (1.2 - 229) <BC958000-7A7D-3C3A-B0FF-95734A35EB0A> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/DictionaryService s.framework/Versions/A/DictionaryServices
                                                0x933ce000 - 0x933d1ff7  com.apple.help (1.3.3 - 46) <FDF183E4-3B95-3CBD-A390-2536C8E7E258> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Help.framework/Versions /A/Help
                                                0x933d2000 - 0x93405fe3  libsystem_m.dylib (3086.1) <951F633F-57B7-398B-912F-F6ED4DB1C597> /usr/lib/system/libsystem_m.dylib
                                                0x93406000 - 0x93457fff  com.apple.opencl (2.4.2 - 2.4.2) <0751975F-97E4-3271-BA93-2FC7A5FDB940> /System/Library/Frameworks/OpenCL.framework/Versions/A/OpenCL
                                                0x93458000 - 0x934ccfff  com.apple.Heimdal (4.0 - 2.0) <0082F991-F391-31A6-915C-1FCB0AD004AC> /System/Library/PrivateFrameworks/Heimdal.framework/Versions/A/Heimdal
                                                0x934cd000 - 0x934d8ff7  com.apple.NetAuth (5.2 - 5.2) <3E650FB0-5EB5-3807-8B71-8FAF64D6A0FC> /System/Library/PrivateFrameworks/NetAuth.framework/Versions/A/NetAuth
                                                0x934d9000 - 0x93560fff  com.apple.CoreServices.OSServices (640.4 - 640.4) <6ABC3CCE-5A4E-3CB2-AA12-3FFAB27D835A> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/OSServices.framew ork/Versions/A/OSServices
                                                0x93593000 - 0x93593fff  com.apple.CoreServices (62 - 62) <08A581EC-2E8B-30CF-B555-64171C8FE5EE> /System/Library/Frameworks/CoreServices.framework/Versions/A/CoreServices
                                                0x93594000 - 0x935efffb  libTIFF.dylib (1237) <CEE13162-B2D3-3AA6-82A7-AA1A02E424DF> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libTIFF.dylib
                                                0x9369e000 - 0x9371bff3  com.apple.framework.IOKit (2.0.2 - 1050.20.2) <84299E45-C5F3-365F-AC1B-0EAFF8057112> /System/Library/Frameworks/IOKit.framework/Versions/A/IOKit
                                                0x9371c000 - 0x939bbffb  com.apple.RawCamera.bundle (6.03.1 - 779) <6F9D2F45-DBC7-3CB1-A412-59EBA38D0BC7> /System/Library/CoreServices/RawCamera.bundle/Contents/MacOS/RawCamera
                                                0x93acb000 - 0x93accfff  libremovefile.dylib (35) <49DCAF7B-4466-3775-9E58-EA5D7CBA8AE0> /usr/lib/system/libremovefile.dylib
                                                0x93acd000 - 0x93aecff7  com.apple.GenerationalStorage (2.0 - 209.11) <34CF76B2-8052-359D-816D-092608FB6919> /System/Library/PrivateFrameworks/GenerationalStorage.framework/Versions/A/GenerationalSt orage
                                                0x93aed000 - 0x93c1bff7  com.apple.coreui (2.1 - 308.6) <908A9C21-7AE9-3480-A858-2E4D928F661D> /System/Library/PrivateFrameworks/CoreUI.framework/Versions/A/CoreUI
                                                0x93c1c000 - 0x93c29ff3  com.apple.ProtocolBuffer (1 - 228.0.1) <B61B9562-CBDE-34E5-B19E-291A1D95D782> /System/Library/PrivateFrameworks/ProtocolBuffer.framework/Versions/A/ProtocolBuffer
                                                0x93c7a000 - 0x93c7bfff  libSystem.B.dylib (1213) <C45CC429-5DE4-3B01-8450-B3BD1AA03C3F> /usr/lib/libSystem.B.dylib
                                                0x93c7c000 - 0x93c90fff  com.apple.ImageCapture (9.0 - 9.0) <4B84B5D5-A5F3-3B35-93CE-568A73486B92> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/ImageCapture.framework/ Versions/A/ImageCapture
                                                0x93c91000 - 0x93d08fff  com.apple.ApplicationServices.ATS (360 - 375.2) <A5CA2D71-673F-3FD8-B515-DAB1B3CC52C5> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framew ork/Versions/A/ATS
                                                0x93d09000 - 0x93d11fff  libsystem_dnssd.dylib (561.1.1) <45CDAF46-03DE-33DB-A627-14F245993EF2> /usr/lib/system/libsystem_dnssd.dylib
                                                0x93d12000 - 0x93d22ff7  com.apple.LangAnalysis (1.7.0 - 1.7.0) <DBECFAD5-DB53-390C-AE92-09549733C861> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/LangAnalys is.framework/Versions/A/LangAnalysis
                                                0x93d23000 - 0x93d23fff  com.apple.Cocoa (6.8 - 21) <6AF80DDB-C28E-36FF-BC11-D7D561AC52A9> /System/Library/Frameworks/Cocoa.framework/Versions/A/Cocoa
                                                0x93d24000 - 0x93dd3ffb  com.apple.Bluetooth (4.3.4 - 4.3.4f4) <90D495A0-431F-363B-8818-230CB096D6E1> /System/Library/Frameworks/IOBluetooth.framework/Versions/A/IOBluetooth
                                                0x93dd4000 - 0x93ddcfff  com.apple.CoreServices.FSEvents (1210.20.1 - 1210.20.1) <FDCAA783-356F-3CA4-B960-16555CD7E34A> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/FSEvents.framewor k/Versions/A/FSEvents
                                                0x93ddd000 - 0x93e38fff  com.apple.LanguageModeling (1.0 - 1) <9B39E059-F48E-31AF-B1B3-B0872F362627> /System/Library/PrivateFrameworks/LanguageModeling.framework/Versions/A/LanguageModeling
                                                0x93e39000 - 0x93f25fe7  libvMisc.dylib (516) <C784D56E-112E-359F-848B-3419E0572EB4> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/libvMisc.dylib
                                                0x93f26000 - 0x941bdfff  com.apple.CoreData (111 - 526.3) <93295B9D-6C48-3919-8B9C-A4291D3522CE> /System/Library/Frameworks/CoreData.framework/Versions/A/CoreData
                                                0x941be000 - 0x941c1fff  libextension.dylib (55.2) <BE3B5B43-A1BB-3BB6-9CD9-946BC61241FC> /usr/lib/libextension.dylib
                                                0x94c00000 - 0x94c9dfff  com.apple.ink.framework (10.9 - 213) <F47949BC-ABEE-329B-B568-71C6FEF761F6> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Ink.framework/Versions/ A/Ink
                                                0x94c9e000 - 0x94ceffff  libcups.2.dylib (408.2) <425E4328-ECA1-31EE-B2C4-0D67FB8848BE> /usr/lib/libcups.2.dylib
                                                0x94cf0000 - 0x94d2ffff  com.apple.NavigationServices (3.8 - 215.1) <46D8B66D-CB59-36F5-BD26-FD8309337BB3> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/NavigationServices.fram ework/Versions/A/NavigationServices
                                                0x94d30000 - 0x94d62ffb  com.apple.GSS (4.0 - 2.0) <2E9B0C48-962E-3CAB-ABCE-0A16CFCEF53E> /System/Library/Frameworks/GSS.framework/Versions/A/GSS
                                                0x94d63000 - 0x94e70fe3  libvDSP.dylib (516) <53F7A960-01E1-3B79-A7FD-67BD19471420> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/libvDSP.dylib
                                                0x94e7a000 - 0x94e91ffb  com.apple.AppContainer (4.0 - 238.20.2) <0A9A3DD3-2D64-3548-8374-96FCE828D151> /System/Library/PrivateFrameworks/AppContainer.framework/Versions/A/AppContainer
                                                0x94e92000 - 0x94ea2fff  libGL.dylib (11.1.2) <44DD250B-CB98-3FD1-BF5B-6AD85A68BF9A> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGL.dylib
                                                0x94ea3000 - 0x94fd5fff  com.apple.UIFoundation (1.0 - 1) <B5B0D178-E1F5-3625-9391-46495E35D540> /System/Library/PrivateFrameworks/UIFoundation.framework/Versions/A/UIFoundation
                                                0x94fd6000 - 0x94fd8ffb  libsystem_secinit.dylib (18) <3CBA3BD3-8BA2-358D-BD1A-A1C3DF5D84E6> /usr/lib/system/libsystem_secinit.dylib
                                                0x94fd9000 - 0x94fe1ff7  libCGCMS.A.dylib (779.11) <EFC325D4-B616-3739-BAB6-D9C8B74F102F> /System/Library/Frameworks/CoreGraphics.framework/Versions/A/Resources/libCGCMS.A.dylib
                                                0x94fe2000 - 0x94febff7  libsystem_notify.dylib (133.1.1) <B8503E99-214B-3AC3-A7CA-CC837ABD7B25> /usr/lib/system/libsystem_notify.dylib
                                                0x94fec000 - 0x9503ffff  com.apple.CoreMediaIO (601.0 - 4760) <A3BA21A9-5841-3C98-BBE8-A945020745DF> /System/Library/Frameworks/CoreMediaIO.framework/Versions/A/CoreMediaIO
                                                0x95040000 - 0x95042ffb  libRadiance.dylib (1237) <A9D5C5E7-8D9E-308A-BA4F-20491E3F15C4> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libRadiance.dylib
                                                0x95043000 - 0x95139ff7  libxml2.2.dylib (26) <2F37833C-4D55-3A09-9A0C-5904E8B6892A> /usr/lib/libxml2.2.dylib
                                                0x9513a000 - 0x951cffff  libsystem_c.dylib (1044.10.1) <9804163C-4DEC-3B94-9854-00248E44554F> /usr/lib/system/libsystem_c.dylib
                                                0x951d0000 - 0x951d0fff  libkeymgr.dylib (28) <06DDCEF8-EB84-3F68-9E19-FD1A12B764FD> /usr/lib/system/libkeymgr.dylib
                                                0x951d1000 - 0x951d3fff  libsystem_sandbox.dylib (358.20.5) <FA3A0729-6839-38AC-B365-5E89A125F091> /usr/lib/system/libsystem_sandbox.dylib
                                                0x95228000 - 0x95264ff3  com.apple.RemoteViewServices (2.0 - 99) <2839C2F1-88DA-3843-87BF-441A374A8967> /System/Library/PrivateFrameworks/RemoteViewServices.framework/Versions/A/RemoteViewServi ces
                                                0x95265000 - 0x952beff3  libAVFAudio.dylib (118.6) <D91F498D-AF1E-368B-9DCB-CDA3AAA0E6CD> /System/Library/Frameworks/AVFoundation.framework/Versions/A/Resources/libAVFAudio.dylib
                                                0x962ea000 - 0x96369fff  com.apple.SystemConfiguration (1.14 - 1.14) <6081992E-6825-3F69-AACF-70ABFA4CE379> /System/Library/Frameworks/SystemConfiguration.framework/Versions/A/SystemConfiguration
                                                0x96519000 - 0x96559ffb  libGLImage.dylib (11.1.2) <9BAF083D-12EF-3CD9-A875-191B1A3CC687> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLImage.dylib
                                                0x9655a000 - 0x9655efff  com.apple.CommonPanels (1.2.6 - 96) <955375E6-2416-38E1-AFC6-477827119329> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CommonPanels.framework/ Versions/A/CommonPanels
                                                0x9700a000 - 0x97029fff  libsystem_kernel.dylib (2782.20.48) <D1D17CE0-1D1D-3243-9E9D-78C70F19B0ED> /usr/lib/system/libsystem_kernel.dylib
                                                0x9705f000 - 0x97092fff  com.apple.CoreServicesInternal (221.7.2 - 221.7.2) <709E9F1B-D266-399B-9A4B-3785BBF64E01> /System/Library/PrivateFrameworks/CoreServicesInternal.framework/Versions/A/CoreServicesI nternal
                                                0x97093000 - 0x9709cfff  libcopyfile.dylib (118.1.2) <FAF3268F-C580-33D3-A5B4-74B8A8713216> /usr/lib/system/libcopyfile.dylib
                                                0x9709d000 - 0x973b1fef  com.apple.CoreAUC (211.1.0 - 211.1.0) <4ECEBB32-FAA9-357E-BD7D-039E2633AAD5> /System/Library/PrivateFrameworks/CoreAUC.framework/Versions/A/CoreAUC
                                                0x973b2000 - 0x973beff7  libkxld.dylib (2782.20.48) <A318FD58-B9BA-3548-A8C9-116DB33719A5> /usr/lib/system/libkxld.dylib
                                                0x973bf000 - 0x973dcfff  libCRFSuite.dylib (34) <781A92EF-410E-39B2-953D-FEE12748D834> /usr/lib/libCRFSuite.dylib
                                                0x973dd000 - 0x97409ffb  libsandbox.1.dylib (358.20.5) <5AFB311B-D796-3851-BC5B-72EF603DB2B6> /usr/lib/libsandbox.1.dylib
                                                0x97435000 - 0x97448fff  libcmph.dylib (1) <2449B048-208E-36FB-9DFA-47E0F3BCF132> /usr/lib/libcmph.dylib
                                                0x97449000 - 0x9744bfff  com.apple.loginsupport (1.0 - 1) <BA8EEAD0-8E97-3219-949B-50AE67F8869E> /System/Library/PrivateFrameworks/login.framework/Versions/A/Frameworks/loginsupport.fram ework/Versions/A/loginsupport
                                                0x9744c000 - 0x976caff3  com.apple.security (7.0 - 57031.20.26) <7E5439C5-752D-367F-A28A-AA34C7307981> /System/Library/Frameworks/Security.framework/Versions/A/Security
                                                0x976cb000 - 0x976d2fff  libMatch.1.dylib (24) <428CD037-5261-39A6-83EE-A7D9ABF446EB> /usr/lib/libMatch.1.dylib
                                                0x976d3000 - 0x9785bff7  com.apple.audio.toolbox.AudioToolbox (1.12 - 1.12) <CA1E6D99-F534-3D3B-9AA5-038E171AD0A9> /System/Library/Frameworks/AudioToolbox.framework/Versions/A/AudioToolbox
                                                0x97872000 - 0x978c5fff  libstdc++.6.dylib (104.1) <D0EB2C99-5939-3ABA-9C18-D9AD75CE23A1> /usr/lib/libstdc++.6.dylib
                                                0x978c6000 - 0x97906fff  libauto.dylib (186) <1609D0F9-6E3A-3C67-87EF-BB0BD93EDAC9> /usr/lib/libauto.dylib
                                                0x97907000 - 0x9791eff7  com.apple.CoreMediaAuthoring (2.2 - 951) <C1019289-9E99-39A2-9580-6C2FCAE9B666> /System/Library/PrivateFrameworks/CoreMediaAuthoring.framework/Versions/A/CoreMediaAuthor ing
                                                0x9791f000 - 0x97c11ff3  com.apple.CoreImage (10.3.4) <6A0E17E6-9F56-3450-8892-670A9C489C30> /System/Library/Frameworks/QuartzCore.framework/Versions/A/Frameworks/CoreImage.framework /Versions/A/CoreImage
                                                0x97c12000 - 0x97c38ff3  libxpc.dylib (559.20.9) <15931AC6-7282-332D-9A44-6CFF84AC63AF> /usr/lib/system/libxpc.dylib
                                                0x97d05000 - 0x97d59fff  com.apple.HIServices (1.22 - 522.1) <E46DFA95-A419-32CD-AD1F-C5839F9CF923> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/HIServices .framework/Versions/A/HIServices
                                                0x97d5a000 - 0x97d5bfff  libDiagnosticMessagesClient.dylib (100) <3EE83437-AA9C-356B-810B-589346B73797> /usr/lib/libDiagnosticMessagesClient.dylib
                                                0x97d6f000 - 0x97da9ff7  com.apple.DebugSymbols (115 - 115) <D01FFA10-1734-31C5-B5A1-9CB61463FC15> /System/Library/PrivateFrameworks/DebugSymbols.framework/Versions/A/DebugSymbols
                                                0x97daa000 - 0x97dc5ff7  com.apple.CFOpenDirectory (10.10 - 187) <44C81E98-710E-30EB-829D-7374B9339345> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/Frameworks/CFOpenDirectory. framework/Versions/A/CFOpenDirectory
                                                0x97dc6000 - 0x97e03fff  libsystem_network.dylib (412.20.3) <039F7709-8BFA-3299-8FD7-168145568642> /usr/lib/system/libsystem_network.dylib
                                                0x97e04000 - 0x98102ffb  com.apple.CoreServices.CarbonCore (1108.6 - 1108.6) <ABEA5906-26AE-308F-B078-5944ABDF94DF> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CarbonCore.framew ork/Versions/A/CarbonCore
                                                0x98103000 - 0x9810eff7  com.apple.AppSandbox (4.0 - 238.20.2) <E81603D8-FA25-3667-999C-E5A9DF790CB4> /System/Library/PrivateFrameworks/AppSandbox.framework/Versions/A/AppSandbox
                                                0x9810f000 - 0x9811bfff  com.apple.CrashReporterSupport (10.10 - 631) <456980E6-2F31-321B-B35D-CA54B88C6F1C> /System/Library/PrivateFrameworks/CrashReporterSupport.framework/Versions/A/CrashReporter Support
                                                0x9811c000 - 0x982abff3  libsqlite3.dylib (168) <C3F78985-C19B-3320-9F71-543969632128> /usr/lib/libsqlite3.dylib
                                                0x982ac000 - 0x98339ff3  com.apple.PerformanceAnalysis (1.0 - 1) <AADDDFC1-B4F3-311A-94EF-4D8EAFC2E2C7> /System/Library/PrivateFrameworks/PerformanceAnalysis.framework/Versions/A/PerformanceAna lysis
                                                0x9833a000 - 0x98351fff  libsystem_asl.dylib (267) <85BD88AD-618E-3325-AC31-10DBAB8E9AF3> /usr/lib/system/libsystem_asl.dylib
                                                0x98352000 - 0x9838cfff  com.apple.AirPlaySupport (2.0 - 215.18) <62CFE5FC-293F-36C8-9371-243892E55D73> /System/Library/PrivateFrameworks/AirPlaySupport.framework/Versions/A/AirPlaySupport
                                                0x9838d000 - 0x9838ffff  com.apple.SecCodeWrapper (4.0 - 238.20.2) <E70AD7E3-F4A1-3315-ABD9-9FF5078E9EDD> /System/Library/PrivateFrameworks/SecCodeWrapper.framework/Versions/A/SecCodeWrapper
                                                0x98390000 - 0x98390fff  liblaunch.dylib (559.20.9) <A0885899-CDE9-3688-8C3C-B583E24090E0> /usr/lib/system/liblaunch.dylib
                                                0x98391000 - 0x98492ff7  com.apple.LaunchServices (644.56 - 644.56) <CFF2C4B8-8111-3B9B-A6F7-E2AB33163238> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/LaunchServices.fr amework/Versions/A/LaunchServices
                                                0x98493000 - 0x984fcff7  libcorecrypto.dylib (233.1.2) <F188C1A7-E88F-3EC5-A6AA-22C02E3F0C93> /usr/lib/system/libcorecrypto.dylib
                                                0x984fd000 - 0x985a3fff  com.apple.Metadata (10.7.0 - 917.35) <3A9CD210-E9CC-3C1C-A72F-278F0694C1B1> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/Metadata.framewor k/Versions/A/Metadata
                                                0x985a4000 - 0x98644fff  com.apple.QD (301 - 301) <4DFE3689-59DE-3FBC-806B-6A4056573E52> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/QD.framewo rk/Versions/A/QD
                                                0x98645000 - 0x9864bff7  libsystem_trace.dylib (72.20.1) <5F23BE77-1C60-3859-B528-C6B3C184C95C> /usr/lib/system/libsystem_trace.dylib
                                                0x9864c000 - 0x98842fff  libicucore.A.dylib (531.48) <A1002DA8-DAA9-30E8-95AE-1BF575AC5AB5> /usr/lib/libicucore.A.dylib
                                                0x98843000 - 0x98843fff  com.apple.Accelerate.vecLib (3.10 - vecLib 3.10) <F968D12F-F59D-3148-951D-76735C3C1B57> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/vecLib
                                                0x98935000 - 0x98942ff7  com.apple.OpenDirectory (10.10 - 187) <60A9481B-2191-35A2-AB7E-E48A2B49BF09> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/OpenDirectory
                                                0x98943000 - 0x98944fff  libsystem_blocks.dylib (65) <5D98F022-E863-31D4-8ADE-D53B2AE0D331> /usr/lib/system/libsystem_blocks.dylib
                                                0x98945000 - 0x98cc8ff7  com.apple.VideoToolbox (1.0 - 1562.235) <52EE731A-400A-3670-8904-03636C41B4CD> /System/Library/Frameworks/VideoToolbox.framework/Versions/A/VideoToolbox
                                                0x98cd2000 - 0x98cd7ff7  libmacho.dylib (862) <48DE74F8-09E3-344F-A82F-665083A3BF8F> /usr/lib/system/libmacho.dylib
                                                0x98cd8000 - 0x98cdafff  libsystem_coreservices.dylib (9) <20E66A47-8D67-344A-A393-73926F0E5FB2> /usr/lib/system/libsystem_coreservices.dylib
                                                0x98cdb000 - 0x98ce9ff7  com.apple.SpeechRecognitionCore (2.1.2 - 2.1.2) <CDD0CAA1-DF2E-3FE1-AEE4-4C0823E6FD5C> /System/Library/PrivateFrameworks/SpeechRecognitionCore.framework/Versions/A/SpeechRecogn itionCore
                                                0x98cea000 - 0x98ceafff  com.apple.Accelerate (1.10 - Accelerate 1.10) <C2367B5B-AE20-3084-A864-104743BE478E> /System/Library/Frameworks/Accelerate.framework/Versions/A/Accelerate
                                                0x98ceb000 - 0x98ddcffb  libiconv.2.dylib (42) <4AF77F10-0BEC-3BE0-99DF-C5170EDB316B> /usr/lib/libiconv.2.dylib
                                                0x98ddd000 - 0x98deefff  libbsm.0.dylib (34) <C9F0C608-2794-3F6B-8078-583FC0046039> /usr/lib/libbsm.0.dylib
                                                0x98def000 - 0x98df7ffb  com.apple.NetFS (6.0 - 4.0) <141BFE7E-634E-32A0-8EC9-0A1A4DFEA7D9> /System/Library/Frameworks/NetFS.framework/Versions/A/NetFS
                                                0x98df8000 - 0x99358ff3  com.apple.MediaToolbox (1.0 - 1562.235) <44C382D2-F7B2-312A-B6CC-AD27D0F17011> /System/Library/Frameworks/MediaToolbox.framework/Versions/A/MediaToolbox
                                                0x99359000 - 0x9937fff7  com.apple.IconServices (47.1 - 47.1) <9C537499-B375-3F84-BF4A-EEF757FC26A9> /System/Library/PrivateFrameworks/IconServices.framework/Versions/A/IconServices
                                                0x99380000 - 0x994f5ff7  com.apple.QTKit (7.7.3 - 2890) <2438CD70-8D13-3287-9A43-50B0CD1745DF> /System/Library/Frameworks/QTKit.framework/Versions/A/QTKit
                                                0x994f6000 - 0x994f9fff  com.apple.xpc.ServiceManagement (1.0 - 1) <D23A7F03-979D-3A78-B1F6-645D2EFEEF66> /System/Library/Frameworks/ServiceManagement.framework/Versions/A/ServiceManagement
                                                0x994fa000 - 0x99571ff7  com.apple.CoreUtils (1.1 - 110.1) <1667BF42-48D3-3B3D-A9CF-0868178DD2EB> /System/Library/PrivateFrameworks/CoreUtils.framework/Versions/A/CoreUtils
                                                0x99572000 - 0x995a5fff  com.apple.CoreAVCHD (5.7.5 - 5750.4.1) <103A5EA0-9B75-3B23-BE72-C4DD52744A6A> /System/Library/PrivateFrameworks/CoreAVCHD.framework/Versions/A/CoreAVCHD
                                                0x995a6000 - 0x995e9fff  libGLU.dylib (11.1.2) <D044C93B-4FCF-378E-9CD4-50E2EBA17EF0> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLU.dylib
                                                0x995ea000 - 0x995ecfff  libsystem_configuration.dylib (699.1.5) <CC818B5B-D6A6-3313-A0FD-6F781B24DAD4> /usr/lib/system/libsystem_configuration.dylib
                                                0x995ed000 - 0x997fbff7  com.apple.CFNetwork (720.3.13 - 720.3.13) <2593580E-5547-37C7-A99A-9D1B086C8B69> /System/Library/Frameworks/CFNetwork.framework/Versions/A/CFNetwork
                                                0x997fc000 - 0x99800ff3  com.apple.TCC (1.0 - 1) <EE0D6865-A6E0-3BF0-93F1-837C09AA7978> /System/Library/PrivateFrameworks/TCC.framework/Versions/A/TCC
                                                0x99801000 - 0x99824fff  libJPEG.dylib (1237) <6838FF44-9DF6-349E-AFB4-182F80C2DA79> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libJPEG.dylib
                                                0x99825000 - 0x99865fff  com.apple.Symbolication (1.4 - 56045) <BE1C4846-DA11-365D-9B46-3FF130401839> /System/Library/PrivateFrameworks/Symbolication.framework/Versions/A/Symbolication
                                                0x99866000 - 0x99867fff  liblangid.dylib (117) <34A0F807-755F-300B-B01F-AABAE3838451> /usr/lib/liblangid.dylib
                                                0x99868000 - 0x9a494fff  com.apple.AppKit (6.9 - 1347.57) <2E995EB6-3DB5-3FE0-B140-3E7563903322> /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit
                                                0x9a4bf000 - 0x9a51ffff  com.apple.AppleVAFramework (5.0.31 - 5.0.31) <2FFC7C07-CA18-3959-B8F6-F620025BCD86> /System/Library/PrivateFrameworks/AppleVA.framework/Versions/A/AppleVA
                                                0x9a520000 - 0x9a617ff7  libFontParser.dylib (134.2) <1CE9DA9E-FBF3-32E4-838D-455EA531F26E> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framew ork/Versions/A/Resources/libFontParser.dylib
                                                0x9a618000 - 0x9a63cffb  com.apple.framework.Apple80211 (10.3 - 1030.71.6) <84F7040E-713D-3B0E-8397-7CE0C377C52A> /System/Library/PrivateFrameworks/Apple80211.framework/Versions/A/Apple80211
                                                0x9a63d000 - 0x9a644fff  com.apple.XPCService (2.0 - 1) <9A59D63D-446A-33A4-BB21-56E42417DA93> /System/Library/PrivateFrameworks/XPCService.framework/Versions/A/XPCService
                                                0x9a645000 - 0x9a649fff  libheimdal-asn1.dylib (398.10.1) <6F113AF8-F5AD-330B-B029-F7AF28A93F28> /usr/lib/libheimdal-asn1.dylib
                                                0x9a657000 - 0x9a686fff  com.apple.CoreVideo (1.8 - 145.1) <A59466FC-6B5A-3B36-BDD4-AC9CD581B7A1> /System/Library/Frameworks/CoreVideo.framework/Versions/A/CoreVideo
                                                0x9a6c2000 - 0x9a6d9ff3  libLinearAlgebra.dylib (1128) <B20FAAAA-1C76-3B20-B100-5FC90F7FE023> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/libLinearAlgebra.dylib
                                                0x9a6da000 - 0x9a84bffb  libBLAS.dylib (1128) <ACEF468C-5DB1-38F3-BCB2-6F3D7F2B2040> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/libBLAS.dylib
                                                0x9a84f000 - 0x9ac82ff3  com.apple.vision.FaceCore (3.1.6 - 3.1.6) <EF92C25B-3E33-379F-A862-75C2FCA8B386> /System/Library/PrivateFrameworks/FaceCore.framework/Versions/A/FaceCore
                                                0x9b12c000 - 0x9b1c6fff  com.apple.ColorSync (4.9.0 - 4.9.0) <E3442A3A-181A-3C39-86D5-89292AF8115F> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ColorSync. framework/Versions/A/ColorSync
                                                0x9b1c7000 - 0x9b1ccfff  com.apple.print.framework.Print (10.0 - 265) <7C3984BB-8337-3B90-A414-17C181A45744> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Print.framework/Version s/A/Print
                                                0x9b1cd000 - 0x9b298fff  com.apple.backup.framework (1.6.4 - 1.6.4) <75DC1CA0-5D18-3E8F-A8BC-D737FC9C55C4> /System/Library/PrivateFrameworks/Backup.framework/Versions/A/Backup
                                                0x9b299000 - 0x9b29dffb  libcache.dylib (69) <55501A00-AF64-3554-8F46-8D5AFEDEC332> /usr/lib/system/libcache.dylib
                                                0x9b2d3000 - 0x9b2f0ffb  com.apple.Ubiquity (1.3 - 313) <9ED23769-0725-3D4B-B7F4-AF08020D73C3> /System/Library/PrivateFrameworks/Ubiquity.framework/Versions/A/Ubiquity
                                                0x9b2f1000 - 0x9b2f1fff  libunc.dylib (29) <CE960997-9D4A-3848-BAC7-B2255E6765FD> /usr/lib/system/libunc.dylib
                                                0x9b2f2000 - 0x9b72dfeb  com.apple.vImage (8.0 - 8.0) <56F6B317-9D70-3DC5-9868-BB6D7CB6E55D> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vImage.framework/Ve rsions/A/vImage
                                                0x9b72e000 - 0x9b72efff  com.apple.Carbon (154 - 157) <CA90E930-DE59-3AD9-B158-3A940BA1FA8A> /System/Library/Frameworks/Carbon.framework/Versions/A/Carbon
                                                0x9b72f000 - 0x9b758fff  libsystem_info.dylib (459.20.1) <91DEA2CC-26A7-32CD-ABC5-0B2754874E38> /usr/lib/system/libsystem_info.dylib
                                                0x9b759000 - 0x9b86cfff  com.apple.MediaControlSender (2.0 - 215.18) <D35B4B09-AE31-3028-ACEE-E86991772577> /System/Library/PrivateFrameworks/MediaControlSender.framework/Versions/A/MediaControlSen der
                                                0x9b86d000 - 0x9ba32fff  com.apple.QuartzCore (1.10 - 361.18) <C2F1A85F-EA5E-3B73-81A2-06E3078202BC> /System/Library/Frameworks/QuartzCore.framework/Versions/A/QuartzCore
                                                0x9ba33000 - 0x9ba59ffb  libPng.dylib (1237) <7EA0DEBE-4000-39D4-89E5-17F655BA317E> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libPng.dylib
                                                0x9ba5a000 - 0x9ba5effb  com.apple.IOSurface (97.4 - 97.4) <FD6AD351-BD60-337C-8D3D-42CDA7EE137C> /System/Library/Frameworks/IOSurface.framework/Versions/A/IOSurface
                                                0x9ba5f000 - 0x9ba68ffb  com.apple.CommonAuth (4.0 - 2.0) <FFE760A3-FEF7-3009-92E8-893ABB3BC91A> /System/Library/PrivateFrameworks/CommonAuth.framework/Versions/A/CommonAuth
                                                0x9bb23000 - 0x9bb31ff7  libz.1.dylib (55) <DF3B8F77-8931-3A6B-8BDF-DB67315050E6> /usr/lib/libz.1.dylib
                                                0x9bb32000 - 0x9bb60ff7  libarchive.2.dylib (30) <8758D35F-ADF8-30F6-8EB2-9B852876EAC8> /usr/lib/libarchive.2.dylib
                                                0xba900000 - 0xba91dfff  libJapaneseConverter.dylib (64) <7265FE24-923E-3CF7-92D6-DB6EFB9E8379> /System/Library/CoreServices/Encodings/libJapaneseConverter.dylib
                                                External Modification Summary:
                                                  Calls made by other processes targeting this process:
                                                    task_for_pid: 1
                                                    thread_create: 0
                                                    thread_set_state: 0
                                                  Calls made by this process:
                                                    task_for_pid: 0
                                                    thread_create: 0
                                                    thread_set_state: 0
                                                  Calls made by all processes on this machine:
                                                    task_for_pid: 86964
                                                    thread_create: 0
                                                    thread_set_state: 0
                                                VM Region Summary:
                                                ReadOnly portion of Libraries: Total=238.2M resident=140.9M(59%) swapped_out_or_unallocated=97.3M(41%)
                                                Writable regions: Total=209.0M written=4036K(2%) resident=8364K(4%) swapped_out=0K(0%) unallocated=200.9M(96%)
                                                REGION TYPE                      VIRTUAL
                                                CG backing stores                     8K
                                                CG image                              4K
                                                CG shared images                    208K
                                                CoreUI image data                    20K
                                                Image IO                              4K
                                                Kernel Alloc Once                     4K
                                                MALLOC                             73.6M
                                                MALLOC (admin)                       48K
                                                Stack                             172.0M
                                                Stack (reserved)                    516K        reserved VM address space (unallocated)
                                                VM_ALLOCATE                        17.2M
                                                WebKit Malloc                      1248K
                                                __DATA                             9524K
                                                __IMAGE                             528K
                                                __LINKEDIT                         47.3M
                                                __OBJC                             2716K
                                                __TEXT                            191.0M
                                                __UNICODE                           552K
                                                mapped file                       156.1M
                                                shared memory                         4K
                                                TOTAL                             672.1M
                                                TOTAL, minus reserved VM space    671.6M
                                                ... and that's it; no other logs are generated on crash. /Library/Logs/Adobe doesn't exist.
                                                • 22. Re: Creative Cloud crashes on startup (OS X), any ideas?
                                                  Brucgovn Adobe Community Professional
                                                  You may try with below steps provided in the posts  :
                                                  https://forums.adobe.com/thread/1249579
                                                  Before that, please check for any files starts with com.adobe as well com.adobe.acc.plist...etc , and move to it to backup folder on desktop, make sure that , they are not in Preferences folder any more.
                                                  ~/library/Preferences.
                                                  ( do not miss ~ symbol)
                                                  Try with Safeboot mode once.
                                                  [Note : Screen may look different in Safeboot mode , but once you restart and login with normal mode ,it will be normal]
                                                  https://support.apple.com/kb/PH18760?locale=en_US
                                                  OS X: What is Safe Boot, Safe Mode? - Apple Support
                                                  • 23. Re: Creative Cloud crashes on startup (OS X), any ideas?
                                                    EXC_CRASH (SIGABRT) is an controllabe crash on Mac computers,It's an Mac exception that indicates that the application terminated abnormally.
                                                    Some times, it will prompt this error  , if the application does not have enough permissions to access or write in to Preferences folder.
                                                    As mentioned earlier , make sure Preference folder under ~/library has Read and Write access to Currently logged in user account and Administrator user name also .
                                                    While providing permissions , please make sure to select the option " select Apply to Enclosed Items"  by Clicking on Ger setting  icon in GetInfo .
                                                    All the best
                                                    • 24. Re: Creative Cloud crashes on startup (OS X), any ideas?
                                                      Tone Garrett
                                                      I am right there with you I hope Adobe can solve this. It is only on my Powerbook my desktops are ok????
                                                      • 25. Re: Creative Cloud crashes on startup (OS X), any ideas?
                                                        aaront89926785 Level 1
                                                        Appreciate all the efforts, but really think Adobe needs to step up and officially look at this since I'm paying for a product I can't use after all. And it isn't working.
                                                        • 26. Re: Creative Cloud crashes on startup (OS X), any ideas?
                                                          1) Right click on Finder icon and  select "Go-To" Folder option.
                                                          2) You will get a text box, type-in below command and then hit 'Return' key.
                                                          /library
                                                          3)Then navigate to Application Support>Adobe.
                                                          Open Adobe folder , locate folder Input Manager or Input method.
                                                          move all its contents to Desktop. on to back up folder  , make sure they are empty and then try launching Creative Cloud desktop app .
                                                          • 27. Re: Creative Cloud crashes on startup (OS X), any ideas?
                                                            That folder doesn't exist.
                                                            • 28. Re: Creative Cloud crashes on startup (OS X), any ideas?
                                                              I bought a new computer since Adobe couldn't be bothered to support me. It works fine on the new computer. Adobe reached out to me today (weeks later) saying they were going to close the case after having never contacted me in the first place. I appreciate all of your attempts to help, Brucgovn; you certainly went well above and beyond anything the company itself attempted.
                                                              • 29. Re: Creative Cloud crashes on startup (OS X), any ideas?
        So sorry to hear that .
        If you are still facing same issue , you can reopen and create new Case .
        Aaron , however  in the below , person named Danny has posted the steps which might work .
        You may refer below link :
        https://forums.adobe.com/thread/1830010
        Or you can contact Adobe Tech Support and still if you need to higher level assistance , you can have the case escalated if the issue is not resolved by the agent.
