9 Replies Latest reply on Apr 29, 2015 12:38 AM by c.pfaffenbichler
    can i use this script in illustrator?
    wilbirita78496655 Level 1
      Newsgroup_User
        • 2. Re: can i use this script in illustrator?
          // This script exports extended layer.bounds information to [psd_file_name].xml
          // by pattesdours
          function docCheck() {
              // ensure that there is at least one document open
              if (!documents.length) {
                  alert('There are no documents open.');
                  return; // quit
          docCheck();
          var originalRulerUnits = preferences.rulerUnits;
          preferences.rulerUnits = Units.PIXELS;
          var docRef = activeDocument;
          var docWidth = docRef.width.value;
          var docHeight = docRef.height.value;
          var mySourceFilePath = activeDocument.fullName.path + "/";
          //  Code to get layer index / descriptor
          cTID = function(s) { return app.charIDToTypeID(s); };
          sTID = function(s) { return app.stringIDToTypeID(s); };
          function getLayerDescriptor (doc, layer) {
              var ref = new ActionReference();
              ref.putEnumerated(cTID("Lyr "), cTID("Ordn"), cTID("Trgt"));
              return executeActionGet(ref)
          function getLayerID(doc, layer) {
            var d = getLayerDescriptor(doc, layer);
            return d.getInteger(cTID('LyrI'));
          var stackorder = 0;
          // function from Xbytor to traverse all layers
          traverseLayers = function(doc, ftn, reverse) {
            function _traverse(doc, layers, ftn, reverse) {
              var ok = true;
              for (var i = 1; i <= layers.length && ok != false; i++) {
                var index = (reverse == true) ? layers.length-i : i - 1;
                var layer = layers[index];
                //  alert("layer.typename  >>> "+layer.typename );
                if (layer.typename == "LayerSet") {
                  ok = _traverse(doc, layer.layers, ftn, reverse);
                } else {
            stackorder = stackorder + 1;
                  ok = ftn(doc, layer, stackorder);
              return ok;
            return _traverse(doc, doc.layers, ftn, reverse);
          // create a string to hold the data
          var str ="";
          // class using a contructor
          function cLayer(doc, layer) {
          //this.layerID = Stdlib.getLayerID(doc, layer);
            this.layerID = getLayerID(doc, layer);
            //alert("layer ID: " + this.layerID);
            this.layerWidth = layer.bounds[2].value - layer.bounds[0].value;
                this.layerHeight = layer.bounds[3].value - layer.bounds[1].value;
            // these return object coordinates relative to canvas
                this.upperLeftX = layer.bounds[0].value;
                this.upperLeftY = layer.bounds[1].value;
                this.upperCenterX = this.layerWidth / 2 + layer.bounds[0].value;
                this.upperCenterY = layer.bounds[1].value;
                this.upperRightX = layer.bounds[2].value;
                this.upperRightY = layer.bounds[1].value;
                this.middleLeftX = layer.bounds[0].value;
                this.middleLeftY = this.layerHeight / 2 + layer.bounds[1].value;
                this.middleCenterX = this.layerWidth / 2 + layer.bounds[0].value;
                this.middleCenterY = this.layerHeight / 2 + layer.bounds[1].value;
                this.middleRightX = layer.bounds[2].value;
                this.middleRightY = this.layerHeight / 2 + layer.bounds[1].value;
                this.lowerLeftX = layer.bounds[0].value;
                this.lowerLeftY = layer.bounds[3].value;
                this.lowerCenterX = this.layerWidth / 2 + layer.bounds[0].value;
                this.lowerCenterY = layer.bounds[3].value;
                this.lowerRightX = layer.bounds[2].value;
                this.lowerRightY = layer.bounds[3].value;
             // I'm adding these for easier editing of flash symbol transformation point (outputs a 'x, y' format)
             // because I like to assign shortcut keys that use the numeric pad keyboard, like such:
             // 7 8 9
             // 4 5 6
             // 1 2 3
                var windowW=2048;
                var windowH=1536;
             this.leftBottom = this.lowerLeftX + ", " + (windowH-this.lowerLeftY);
             this.bottomCenter = this.lowerCenterX + ", " +  (windowH-this.lowerCenterY);
             this.rightBottom = this.lowerRightX + ", " + this.lowerRightY;
             this.leftCenter = this.middleLeftX + ", " + this.middleLeftY;
             this.center = this.middleCenterX + ", " + this.middleCenterY;
             this.rightCenter = this.middleRightX + ", " + this.middleRightY;
             this.leftTop = this.upperLeftX + ", " + this.upperLeftY;
             this.topCenter = this.upperCenterX + ", " + this.upperCenterY;
             this.rightTop = this.upperRightX + ", " + this.upperRightY;
            // these return object coordinates relative to layer bounds
                this.relUpperLeftX = layer.bounds[1].value - layer.bounds[1].value;
                this.relUpperLeftY =  layer.bounds[0].value - layer.bounds[0].value;
                this.relUpperCenterX = this.layerWidth / 2;
                this.relUpperCenterY = layer.bounds[0].value - layer.bounds[0].value;
                this.relUpperRightX = this.layerWidth;
                this.relUpperRightY = layer.bounds[0].value - layer.bounds[0].value;
                this.relMiddleLeftX = layer.bounds[1].value - layer.bounds[1].value;
                this.relMiddleLeftY = this.layerHeight / 2;
                this.relMiddleCenterX = this.layerWidth / 2;
                this.relMiddleCenterY = this.layerHeight / 2;
                this.relMiddleRightX = this.layerWidth;
            this.relMiddleRightY = this.layerHeight / 2;
                this.relLowerLeftX = layer.bounds[1].value - layer.bounds[1].value;
                this.relLowerLeftY = this.layerHeight;
                this.relLowerCenterX = this.layerWidth / 2;
            this.relLowerCenterY = this.layerHeight / 2;
                this.relLowerRightY = this.layerHeight;
                this.relLowerRightX = this.layerWidth;
            return this;
          // add header line
          str = "<psd filename=\"" + docRef.name + "\" path=\"" + mySourceFilePath + "\" width=\"" + docWidth + "\" height=\"" + docHeight + "\">\n";
          // now a function to collect the data
          var isParentAvailable=false;
          var prevLayerSetName="";
          function exportBounds(doc, layer, i) {
              var isVisible = layer.visible;
              var layerData = cLayer(doc, layer);
          //alert("layer.name  >>> "+layer.name );
          //alert("typename >>> "+layer.typename);
          /*if(layer.parent.name == "ParentTest"){
          for(var i in layer.parent){
              alert(" III >>> "+i+"<<<layer.parent>>"+layer.parent[i]);
            if(isVisible){
          // Layer object main coordinates relative to its active pixels
          var startStr="";
              if(layer.parent.typename=="LayerSet"){
                  if(prevLayerSetName!="LayerSet")    {
                      startStr="\t<parentlayer id='"+layer.parent.name+"'>\n\t";
                  }else{
                         startStr="\t";
                  // endStr="\t</parentlayer>\n";
                   prevLayerSetName=layer.parent.typename;
                }else{
                     if(prevLayerSetName=="LayerSet"){
                          startStr="\t</parentlayer>\n";
            var positionStr=layer.name.split(".")[0].substr(layer.name.split(".")[0].length-3,layer.name. split(".")[0].length);
            var assetPosition=leftTop;
            if(positionStr=="L_B"){
            assetPosition=leftBottom;
            }else if(positionStr=="B_C"){
            assetPosition=bottomCenter;
            }else if(positionStr=="R_B"){
            assetPosition=rightBottom;
            }else if(positionStr=="L_C"){
            assetPosition=leftCenter;
            }else if(positionStr=="C"){
            assetPosition=center;
            }else if(positionStr=="R_C"){
            assetPosition=rightCenter;
            }else if(positionStr=="L_T"){
            }else if(positionStr=="T_C"){
            assetPosition=topCenter;
            }else if(positionStr=="R_T"){
            assetPosition=rightTop;
            var str2 =startStr+ "\t<layer name=\"" + layer.name
            + "\" stack=\"" + (i - 1) // order in which layers are stacked, starting with zero for the bottom-most layer
            + "\" position=\"" + assetPosition // this is the
            + "\" layerwidth=\"" + layerData.layerWidth
            + "\" layerheight=\"" + layerData.layerHeight
            + "\" transformpoint=\"" + "center" + "\">" // hard-coding 'center' as the default transformation point
            + layer.name + ".png" + "</layer>\n" // I have to put some content here otherwise sometimes tags are ignored
          str += str2.toString();
          // call X's function using the one above
          traverseLayers(app.activeDocument, exportBounds, true);
          // Use this to export XML file to same directory where PSD file is located
          // create a reference to a file for output
              var csvFile = new File(mySourceFilePath.toString().match(/([^\.]+)/)[1] + app.activeDocument.name.match(/([^\.]+)/)[1] + ".xml");
          // open the file, write the data, then close the file
          csvFile.open('w');
          csvFile.writeln(str + "</psd>");
          csvFile.close();
          preferences.rulerUnits = originalRulerUnits;
          // Confirm that operation has completed
          alert("Operation Complete!" + "\n" + "Layer coordinates were successfully exported to:" + "\n" + "\n" + mySourceFilePath.toString().match(/([^\.]+)/)[1] + app.activeDocument.name.match(/([^\.]+)/)[1] + ".xml");
          • 3. Re: can i use this script in illustrator?
            c.pfaffenbichler Level 9
            Hardly likely, Illustrator and Photoshop have different DOMs and this Script even employs Action Manager code, which (as far as I know) is strictly Photoshop.
            • 4. Re: can i use this script in illustrator?
              I'm looking for a simple script that will export the coordinates (layer bounds - top left x,y) of the layers to an seperate xml/txt file in illusrator.
              • 6. Re: can i use this script in illustrator?
                is there any alternate script to use in illustrator?
                • 7. Re: can i use this script in illustrator?
                  This Forum is dedicated to Photoshop Scripting, I think you really should post on the Illustrator Scripting Forum.
                  • 9. Re: can i use this script in illustrator?
                    There are considerable differences between the two applications even in what Layers basically are, so hopefully the people over there can provide you with a Script or the necessary advice to achieve what you are trying to achieve.
