2 Replies Latest reply on May 11, 2015 5:42 PM by missij99360262
    Not sure why this isn't calculating..
    missij99360262
      Three columns...
      In time
      Out Time
      Total Time (calculate based on in and out entered)
                 <field name="hours1" w="18.182mm" h="10.04mm" access="readOnly">
                        <ui>
                           <numericEdit>
                              <border presence="hidden">
                                 <?templateDesigner StyleID aped0?></border>
                              <margin/>
                           </numericEdit>
                        </ui>
                        <font typeface="Myriad Pro"/>
                        <margin topInset="1mm" bottomInset="1mm" leftInset="1mm" rightInset="1mm"/>
                        <para vAlign="middle" hAlign="center"/>
                        <border>
                           <edge/>
                           <corner thickness="0.1778mm"/>
                        </border>
                        <calculate>
                           <script>if( HasValue(spec1b) &amp; HasValue(spec1a) ) then
      // compute time difference in minutes
      var TimeDiff = (Time2Num(spec1b.formattedValue, "h:MM A") - Time2Num(spec1a.formattedValue, "h:MM A")) / (1000 * 60)
      // truncate to hours
      var HourDiff = Floor(TimeDiff / 60)
      // get minutes less than 60
      var MinDiff = Mod(TimeDiff, 60)
      // build fomatted dispaly string
      Concat( Format("Z9", HourDiff), ":", Format("99",MinDiff) )
      else
      // if any values missing null the output
      null
      endif
      </script>
                        </calculate>
                     </field>
