I originally had spinning wheel forever and deleting OOBE did not help the issue.
I just uninstalled all Adobe products from my Windows 7 desktop, including an old Air installation from 2010.
I have also since performed the Adobe Cleaner Tool. So, I think I am ready to re-download the Cloud and try again.
Do I need to install Air first? Do I need it at all?
LL
If you had uninstall all Adobe apps ,.
It is ideal to remove / rename Adobe app associated folders as well in order to avoid conflict with new installation.
So that you can perform fresh and clean installation.
Locations of Adobe folders :
C:\Program Files>Adobe.
C:\Program Files(x86)>Adobe.
C:\Program Files>Common Files>Adobe.
C:\Program Files(x86)>Common Files>Adobe.
C:\Program Data>Adobe. (Hidden by default)
Press Windows button (located between Ctrl and Alt buttons) along with R button together at a time , you will get a run command window.
Type in below command and hit 'Enter' key.
appdata
It will open Appdata folder.
Open it ,you will get 3 folders .
Local ,
Local Low
Roaming.
Each one will have Adobe inside remove/rename it.
Then download and install Creative Cloud app and check.
Thank you for the tips! I found a lot of Adobe folders in my C: drive, because I have been dealing with this issue since March.
Some are labeled OLD and others are not.
I'm going to clean these up and throw a lot of them away, since they don't need to be there.
Do I need to install a new version of Air, or is that necessary at all?
You may install it later on
You may go ahead and install Creative Cloud app.
Wonderful, thanks again for the advice.
Fingers crossed!
You are welcome.
Let me know if you face any issue.
OK, I will. Have a great day.
