3 Replies Latest reply on Jun 19, 2018 9:52 AM by resdesign
    Adding custom css classes from within edge animate
    mads18950258 Level 1
      is it possible to add  CSS classes from within Edge Animate, im not talking about adding your own stylesheet by ex. manually editing the .html document, but rather adding classes via ex. the code window ?, it would be immensely helpful to have everything in one place.
      any suggestions on this one ?
        • 1. Re: Adding custom css classes from within edge animate
          resdesign Adobe Community Professional & MVP
          Yes - you can use addclass() and you can use UI.
          1- UI
          Select elements in elements panel. Click the C button in the property panel.
          Use this for example
          sym.$('.classname').css({'color':'red'});
          2- addclaas()
          sym.$("name').addclass('classname');
          Use same as above.
          On Sat, Apr 25, 2015 at 8:56 AM mads18950258 <forums_noreply@adobe.com>
          • 2. Re: Adding custom css classes from within edge animate
            dSparks Level 1
            1- UI
            resdesign I've tried your method but it still escapes me on EA 2015 latest version. Could you elaborate or give a sample code that works in the latest version? I've clicked the "C" button and pasted your sample code and tried various options to make it work. I've used the sample as-is and replaced '.classname' with a custom and with the class name of the element via the dev inspector in chrome. Thus far, nothing works. The edge reference PDF shows nothing. This is the most frustrating thing about the app is there is no practical way to add or edit the css files as actual css.
            So let's say I select an element on the stage. I click on the C button and I put ...?... in the white box.
            • 3. Re: Adding custom css classes from within edge animate
              Sorry this was not answered at the time. I missed it.
              When you add the class name in the box in your screenshot, then you now have the ability to use this class name in code.
              For example if the class name is highlight you could use this in stage/compositionReady:
              sym.$("highlight").css({"border": "2px solid red"});    // do not forget the dot that specify the element is a class name
              So now, anything that has this class with have the border.
