6 Replies Latest reply on Jun 13, 2015 11:49 AM by AnnShelbourne
    Lightroom CC reloading on editing TIF files
    REDennis Level 1
      OK - another little Lightroom CC item I did not experience in earlier versions.
      Library catalog settings set to record data to XMP file, as is my standard operating procedure.  NEF raw file edits proceed as normally.  However, on editing TIF files, such as those created externally via Silver EFX or what have you, LR constantly "reloads" the image after every edit (so it seems), and does not keep any of the edits made to the image on reload.
      The workaround I found is to turn off recording data to XMP, however I prefer to have XMP data separate from the LR catalog.
      Anyone else experiencing this issue?
        • 1. Re: Lightroom CC reloading on editing TIF files
          johnrellis Most Valuable Participant
          Why don't you upload a sample problem pic to Dropbox or similar and post the link here.  Then others can see if the problem happens on their configuration.
          • 2. Re: Lightroom CC reloading on editing TIF files
            Stuartr414
            Yes, I am having the same issue on film scans spotted in photoshop and then worked on in Lightroom. Quitting photoshop (the image was not open...I just did it as a precaution) and then restarting Lightroom seemed to fix it. I have not had this problem in previous Lightroom versions, and I do this kind of thing all the time, as I scan a lot of film in FlexColor, use the content-aware spotting in PS and then work on the final adjustments in Lightroom. I am using a Mac Pro 2013 with 10.9.5. Lightroom is set to write data to XMP.
            • 3. Re: Lightroom CC reloading on editing TIF files
              hoganlia
              I posted the same problem just before you did... I saw your XMP work-around and tried it... yes, it works correctly now, however, this should not happen.
              Thanks for the hint, it was driving me crazy!!!!
              • 4. Re: Lightroom CC reloading on editing TIF files
                Jimre3 Level 2
                Thank you! Yes, I have exactly the same problem. Since upgrading to LR6, touching almost any slider in the Develop module would cause the image to "reload". Worse, it would often "forget" my previous develop edits: even though they were listed on the History panel, they would no longer have any effect.
                Great catch, noticing this was just for TIF files!  I didn't make that connection. But as most of my edits involve a round-trip into either PS or Nik, I was almost always editing TIF files. As you suggested, I've disabled "Automatically write changes into XMP" in the Catalog Settings - and now it once again works properly. My first guess was that this had something to do with GPU rendering, but disabling the GPU had no effect on this problem.
                This is potentially more than just an annoyance. As mentioned, such a "reload" event would often lose ALL of my previous edits (even though they were still listed in the History panel) and reset the image back to the starting point. That's actual data loss!
                • 5. Re: Lightroom CC reloading on editing TIF files
                  A number of people have reported these symptoms.  Please add your vote and lots of details to this bug report in the official Adobe feedback forum: BUG: LightRoom 6 TIFF file reloads after each Develop edit, potential data loss
                  • 6. Re: Lightroom CC reloading on editing TIF files
                    AnnShelbourne Level 2
                    Is this problem occurring when you use third-party plug-ins — particularly Nik?
                    I checked Nik's site and they list compatibility up to Lr 5. No mention of Lr 6.
                    If you absolutely need to use these plug-ins, you may want to keep Lr 5.7 on your machine for that purpose?
