3 Replies Latest reply on Apr 30, 2015 1:40 PM by Russ Ward
    Remove Save Files dialog in FM12
    hanzelko Level 1
      Hello.
      We have FrameMaker plugin system, which manages our own saving of FrameMaker files.
      It works in FrameMaker 10. But now in FM12 this dialog appears:
      And we need to disable this dialog and continue with close of FrameMaker.
      I have tried to use  FA_Note_Dialog and return CancelOperation, but then the close event chain of FrameMaker is not continuing.
      Basicaly we need to have Close of FrameMaker event chain same as in FM10.
      Is it possible to do this?
      [Moved to Scripting Forum by moderator]
        • 1. Re: Remove Save Files dialog in FM12
          Russ Ward Level 4
          hanzelko,
          How did you get around the dialog in FM10? Earlier versions did not have this dialog box, but they did have individual prompts for each unsaved file. What notification do you use to trigger your own saving process?
          Russ
          • 2. Re: Remove Save Files dialog in FM12
            hanzelko Level 1
            Hello.
            In FrameMaker 10 we handle PreQuitDoc. And by clicking X for FrameMaker, it calls PreQuitDoc for all open documents.
            We perform our save to our DMS, save file locally and we will not close the document.
            And the rest in done by FrameMaker. (the document is saved, FM will close it and it can proceed to PreQuitSession);
            • 3. Re: Remove Save Files dialog in FM12
              Russ Ward Level 4
              So I see. In FM10, PreQuitDoc fires before the prompt. In FM12, that prompt appears before any notification. It would seem that Adobe has once again made a change that interferes with API users. I don't have any answer for you, only a confirmation that your observations are correct. Historically, the most egregious obstacle to FrameMaker automation has been UI prompts that can't be avoided. It's unfortunate that this trend continues. In my opinion, the API is the major feature that keeps this product competitive.
              Russ
