2 Replies Latest reply on Oct 2, 2015 2:17 AM by DeGraye
    Make original folder default for Save As, Export, Place
    DeGraye Level 1
      One thing that has annoyed me immensely over the years is when using Save As, Export, Place, Indesign often use the location of the last used file in the "file dialog window" instead of the current documents folder.
      I keep my jobs in separate folders and not in one big folder (as the current behaviour of Indesign seems to believe is the best) and therefore have to manually navigate to/search for the correct folder, which is quite annoying in the long run.
      I would like to set the same folder as the original file is contained in, as the default folder for all file actions (import, export, place) every time.
      Is that possible and if so, where is that setting to be found?
      (I`m using Indesign CC2014)
