1 Reply Latest reply on May 2, 2015 2:45 AM by BKBK
    QoQ without a commond id
    jfb00 Level 3
      Hi All,
      I use this technique for QoQ when I have a commond key:
      How to do an OUTER JOIN in Query of Queries | BealeARTS
      Now, I have data from two different table but the join is based on multiple fields as:
      select *
      from tableA, tableB
      where tableA.field1 = tableB.field1
      and tableA.field2 = tableB.field2
      and tableA.field3 = tableB.field3
      How can I do the other join in this case?
      Thanks in advanced.
        • 1. Re: QoQ without a commond id
          BKBK Adobe Community Professional & MVP
          You could use exactly the same strategy as in the reference you gave, then perhaps make it more the result more efficient.
          <cfquery name="joinQuery" dbtype="query" >
          SELECT *
          FROM QueryB
          WHERE QueryB.field1 IS NULL OR QueryB.field2 IS NULL OR QueryB.field3 IS NULL
          <cfset QueryAddRow(joinQuery) />
          <cfquery name="result" dbtype="query" >
          SELECT *
          FROM QueryA, QueryB
          WHERE QueryA.field1 = QueryB.field1
          AND QueryA.field2 = QueryB.field2
          AND QueryA.field3 = QueryB.field3
          SELECT QueryA.*, joinQuery.*
          FROM QueryA, joinQuery
          WHERE QueryA.field1 NOT IN (#ValueList(QueryB.field1)#) AND QueryA.field2 NOT IN (#ValueList(QueryB.field2)#) AND QueryA.field3 NOT IN (#ValueList(QueryB.field3)#)
