2 Replies Latest reply on Jan 11, 2007 2:40 PM by JulianQuist
    Flex Data Services and Websphere Community Edition (Geronimo)
    JulianQuist
      I deployed the three Flex Data Services 2 WAR files to Websphere Application Server Community Edition (via the web admin console), but when I go to any of the sample applications, I get the following error page:
      Compilation Results
      Errors, warnings or exceptions were found while compiling /dataservice/notes/notes.mxml. Visit the online Flex documentation or API reference for further information.
      1 Exception found.
      Exception java.lang.NoSuchMethodError
      org/apache/xpath/XPath.<init>(Ljava/lang/String;Lorg/apache/xml/utils/PrefixResolver;Ljava x/xml/xpath/XPathFunctionResolver;Ljavax/xml/xpath/XPathVariableResolver;ZZ)V
      The geronimo.out log file contains the following stack trace, which for the life of me I can't figure out:
      01/10 06:34:19 ERROR java.lang.NoSuchMethodError:
      at org.apache.xpath.jaxp.XPathImpl.compile(XPathImpl.java:182)
      at org.apache.xpath.jaxp.XPathImpl.evaluate(XPathImpl.java:217)
      at flex.messaging.config.XPathClientConfigurationParser.selectSingleNode(XPathClientConfigur ationParser.java:52)
      at flex.messaging.config.ClientConfigurationParser.parseTopLevelConfig(ClientConfigurationPa rser.java:41)
      at flex.messaging.config.AbstractConfigurationParser.parse(AbstractConfigurationParser.java: 66)
      at flex.messaging.config.ServicesDependencies.getClientConfiguration(ServicesDependencies.ja va:123)
      at flex.messaging.config.ServicesDependencies.<init>(ServicesDependencies.java:39)
      at flex2.compiler.common.CompilerConfiguration.getServicesDependencies(CompilerConfiguration .java:422)
      at flex.services.config.Configurator.calculateServicesChecksum(Configurator.java:251)
      at flex.services.config.Configurator.generateConfiguration(Configurator.java:235)
      at flex2.server.j2ee.IncrementalCompileFilter.compileMxml(IncrementalCompileFilter.java:75)
      at flex2.server.j2ee.BaseCompileFilter.mxmlToSwf(BaseCompileFilter.java:318)
      at flex2.server.j2ee.BaseCompileFilter.invoke(BaseCompileFilter.java:60)
      at flex2.server.j2ee.RecompileFilter.invoke(RecompileFilter.java:37)
      at flex2.server.j2ee.PathExistsFilter.invoke(PathExistsFilter.java:42)
      at flex2.server.j2ee.AboutFilter.invoke(AboutFilter.java:48)
      at flex2.server.j2ee.MxmlServlet.doGet(MxmlServlet.java:158)
      at javax.servlet.http.HttpServlet.service(HttpServlet.java:595)
      at javax.servlet.http.HttpServlet.service(HttpServlet.java:688)
      at flex.bootstrap.BootstrapServlet.service(BootstrapServlet.java:85)
      at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.j ava:252)
      at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:173)
      at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:213)
      at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:178)
      at org.apache.geronimo.tomcat.valve.DefaultSubjectValve.invoke(DefaultSubjectValve.java:56)
      at org.apache.geronimo.tomcat.GeronimoStandardContext$SystemMethodValve.invoke(GeronimoStand ardContext.java:342)
      at org.apache.geronimo.tomcat.valve.GeronimoBeforeAfterValve.invoke(GeronimoBeforeAfterValve .java:31)
      at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:126)
      at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:105)
      at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:107)
      at org.apache.catalina.valves.AccessLogValve.invoke(AccessLogValve.java:541)
      at org.apache.catalina.authenticator.SingleSignOn.invoke(SingleSignOn.java:419)
      at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:148)
      at org.apache.coyote.http11.Http11Processor.process(Http11Processor.java:869)
      at org.apache.coyote.http11.Http11BaseProtocol$Http11ConnectionHandler.processConnection(Htt p11BaseProtocol.java:667)
      at org.apache.tomcat.util.net.PoolTcpEndpoint.processSocket(PoolTcpEndpoint.java:527)
      at org.apache.tomcat.util.net.LeaderFollowerWorkerThread.runIt(LeaderFollowerWorkerThread.ja va:80)
      at org.apache.tomcat.util.threads.ThreadPool$ControlRunnable.run(ThreadPool.java:869)
      at java.lang.Thread.run(Thread.java:799)
      Does anybody know what that means by any chance?
      Cheers
      Julian
        • 1. Flex Data Services and Websphere Community Edition (Geronimo)
          peelmaster
          Julian,
          What JRE version are you using? I received NoSuchMethodErrors when trying to compile flex apps when I first started. The JRE does not recognize the XPath Method. Turned out that the JRE that I was using was the problem. I think I finally settled on using 1.4.2_12 (I had problems with some of the newest runtimes, and other problems if I go back too far) and haven't had problems since. Might be something to try.
          Andrew
          • 2. Flex Data Services and Websphere Community Edition (Geronimo)
            JulianQuist Level 1
            Hi Andrew,
            Thanks very much! I'll give that a go and let you know what I find. I'm currently using the most recent IBM JDK for Linux:
            $ java -version
            java version "1.5.0"
            Java(TM) 2 Runtime Environment, Standard Edition (build pxi32dev-20061002a (SR3) )
            IBM J9 VM (build 2.3, J2RE 1.5.0 IBM J9 2.3 Linux x86-32 j9vmxi3223-20061001 (JIT enabled)
            J9VM - 20060915_08260_lHdSMR
            JIT - 20060908_1811_r8
            GC - 20060906_AA)
            JCL - 20061002
