6 Replies Latest reply on Apr 28, 2015 7:48 AM by Jim Birkenseer
    UnitValue vs. null issue.
    Jim Birkenseer Level 1
      Hi Folks,
      Has anyone come across an issue where a valid UnitValue object is considered null? I've tested this in Mac versions of: ID CS6, ID CC 2014, and when running the script within ExtendScript Toolkit v4.0.0.1. I haven't tried this on Windows.
      var x = .1;
      var uv = new UnitValue(x, "pt");
      $.writeln(uv);
      if (uv === null)
        // uv is incorrectly considered null when (uv.value > -1.0 && uv.value < 1.0)
        $.writeln("uv is null!");
      // Output:
      //   0.1 pt
      //   uv is null!
      It appears that a UnitValue object is considered to be null by ExtendScript when its value property (the x variable in the code above) is a fraction of 1. i.e.,(uv.value > -1.0 && uv.value < 1.0).
      And, yes, this issue can be worked around using a try/catch:
      function IsUVNull(theUV)
       // Returns true if null; false otherwise.
        try
          var dummy = theUV.constructor;
          return false;
        catch (e)
          return true;
      Am I missing something, or is ExtendScript just picking on me. Again. ;-)
      On the plus side, maybe I finally found a situation where null actually is an object!
      -- Jim
        • 1. Re: UnitValue vs. null issue.
          Loic.Aigon Adobe Community Professional
          Perfectly on my side. Mac os 10.7.5 same config as yours for apps (not tested in CS6 though).
          FWIW,
          Loic
          • 2. Re: UnitValue vs. null issue.
            Vamitul Level 4
            you don't need the try catch, you can simply use:
            if (uv.value === null)
            but i agree it is a strange bug (on windows also)
            • 3. Re: UnitValue vs. null issue.
              Hi Loic,
              Are you saying that you got the same unexpected output that I did when you ran the first code snippet--in other words, (uv === null) incorrectly matches null when really uv is a variable that references a valid UnitValue object?
              Thanks!
              -- Jim
              • 4. Re: UnitValue vs. null issue.
                Hi Vamitul,
                On my system, the workaround function with the try/catch, IsUVNull() is required in order to tell if a variable is set to null, or if a variable is set to something like (new UnitValue(.5, "in")).
                So, when I run the code snippet below:
                Line 1 correctly results in false.
                Line 2 incorrectly results in true. (Note the UnitValue value is between -1.0 and 1.0, which seems to causes the incorrect results for me.)
                Line 4 uses the workaround function, and correctly results in false.
                $.writeln((new UnitValue(1, "pt") === null)); // CORRECT: This results in false, as expected.
                $.writeln((new UnitValue(.5, "pt") === null)); // WRONG: This results in true, but it should be false!
                $.writeln(IsUVNull((new UnitValue(.5, "pt")))); // CORRECT: This results in false, as expected.
                  try
                    return false;
                  catch (e)
                    return true;
                Thanks!
                -- Jim
                • 5. Re: UnitValue vs. null issue.
                  Hello,
                  Yeah I got the same result but to be honest I first answered that it was ok on my side because I misunderstood your issue. Now I can confirm uv === null //true;
                  Loic
                  • 6. Re: UnitValue vs. null issue.
                    Hi Loic and Vamitul,
                    Thanks for taking the time to confirm this!
                    -- Jim
