Hi all and welcome to the community TWSisters
In case it will help here, I just inserted two different
RelatedTopics controls. One configured to use the popup and the
other configured to use the dialog. Perhaps you can compare my code
to yours to ascertain any differences.
Popup
<!--Metadata type="DesignerControl" startspan
<object
CLASSID="clsid:FF80F713-5DC6-11d0-A7B4-00AADC53E937"
ID=RelatedTopics
BORDER=0
style="margin-top: 0px;
margin-bottom: 0px;
margin-left: 0px;
margin-right: 0px;
vertical-align: baseline;"
align=bottom>
<param name="_Version" value="65536" >
<param name="_ExtentX" value="2117" >
<param name="_ExtentY" value="556" >
<param name="_StockProps" value="13" >
<param name="ForeColor" value="0" >
<param name="BackColor" value="14215660" >
<param name="UseButton" value="-1" >
<param name="UseText" value="0" >
<param name="ControlLabel" value="Related Topics" >
<param name="UseIcon" value="0" >
<param name="Items" value="Add a Loading
Screen;..\Unit10\Add_a_Loading_Screen.htm$$**$$Add a Slide
Label;..\Unit7\Add_a_Slide_Label.htm$$**$$" >
<param name="Image" value="" >
<param name="FontInfo" value="MS Sans Serif,8,0,," >
<param name="_CURRENTFILEPATH"
value="C:\Rick\Captivate2Instructor\Unit14\Publish_a_Zipped_Flash_Project.htm"
<param name="_ID" value="RelatedTopics" >
<param name="UseMenu" value="-1" >
<param name="Frame" value="" >
<param name="Window" value="" >
</object>-->
<OBJECT
CLASSID="clsid:ADB880A6-D8FF-11CF-9377-00AA003B7A11"
ID="RelatedTopics" TYPE="application/x-oleobject" >
<PARAM NAME="Command" VALUE="Related Topics,MENU">
<PARAM NAME="Button" VALUE="Text:Related Topics">
<PARAM NAME="Font" VALUE="MS Sans Serif,8,0,,">
<PARAM NAME="Item1" VALUE="Add a Loading
Screen;..\Unit10\Add_a_Loading_Screen.htm">
<PARAM NAME="Item2" VALUE="Add a Slide
Label;..\Unit7\Add_a_Slide_Label.htm">
</OBJECT>
Dialog
<object
BORDER=0
id=OBJECT1
margin-bottom: 0px;
margin-left: 0px;
margin-right: 0px;
align=bottom>
<param name="Items" value="Add a Slide
Note;..\Unit7\Add_a_Slide_Note.htm$$**$$Add a Sound Effect to an
Object;..\Unit7\Add_a_Sound_Effect_to_an_Object.htm$$**$$" >
<param name="_ID" value="OBJECT1" >
<param name="UseMenu" value="0" >
</object>-->
<OBJECT
ID="OBJECT1" TYPE="application/x-oleobject" >
<PARAM NAME="Command" VALUE="Related Topics">
<PARAM NAME="Item1" VALUE="Add a Slide
Note;..\Unit7\Add_a_Slide_Note.htm">
<PARAM NAME="Item2" VALUE="Add a Sound Effect to an
Object;..\Unit7\Add_a_Sound_Effect_to_an_Object.htm">
</OBJECT>
Hopefully this helps... Rick
