0 Replies Latest reply on Apr 28, 2015 5:31 AM by Henrik Nerr
    LR CC, LR6: How To Set Filter Brushes Reliably to ADD ?
    Henrik Nerr Level 1
      Hi, in the new Lightroom versions, the new filter brush can ADD to or SUBTRACT from the area affected by graduated filter or radial filter.
      But i am not sure how to *reliably* set a brush to ADD or to SUBTRACT. I had assumed:
      - brush "Erase" does subtract (minus sign within cursor)
      - brushes "A" and "B" do add (plus sign within cursor); if you press Alt, brushes switch temporarily to "Erase" brush
      But i had at least one instance where brushes A and B only *subtracted* and there was no way to get them back to *adding* (except by restarting LR with a different language).
      Do you know if there is way to *permanently* set brushes A and B to ADD? Or at least: How to bring brushes A and B back to ADD when for some reason they are fixated on SUBTRACT?
      In Photoshop's raw dialog, the same task is very easy – there are two brushes, one with a plus sign and one with a minus sign, and they always work as expected.
      I searched a lot of sites, but none answers my above question.
      ---snip---
      As we are here already, i have another question regarding the mask overlay for gradual filter etc.: Initially, the mask overlay is red. In Lightroom, I can switch to other colors with Shift-O.
      Can i also
      - change opacity of mask overlay
      - invert mask overlay appearance, so that non-selected areas are overlaid?
      It's possible in Photoshop's ACR, but perhaps not in LR?
        Thanks!
