3 Replies Latest reply on Aug 27, 2015 7:49 AM by MobileDeveloperCK
    Options not working [iOS]
    pedro533441
      Why doesn't the option for highlighting/underline/strike through work? I am using an iPad mini
        • 1. Re: Options not working
          MobileDeveloperCK Adobe Employee
          I suspect that your document is either one of the following:
          (a) A scanned PDF document containing no actual text
          Can you tap over text and see if you can select it?  If you cannot, your PDF document is a scanned PDF.
          (b) A secured/encrypted PDF document that does not allow any changes including adding comments
          Do you see the lock icon in the bottom bar?
          When you try to switch to Comment in the Tool Switcher (see the screenshot below), do you see an alert message "This tool is not available due to the document's security settings."?
          • 2. Re: Options not working
            peroj38633693
            I have the (b) - "This tool is not available due to the document's security settings." problem, although I can comment the same document in Adobe Acrobat Reader DC on my PC.
            Here are the Permission Details of the document:
            How could I convince the iPad to allow me commenting as well?
            Thank you.
            • 3. Re: Options not working [iOS]
              Because of the document security & restriction settings, your PDF document is encrypted.
              Acrobat Reader mobile products (for iOS, Android, Windows Phone) have the known limitation where changes cannot be saved to encrypted PDF documents.  Therefore, users are not able to make any changes (e.g. adding comments/annotations or filling out forms) to encrypted PDF documents.
              As you already know, there is no such limitation in the desktop version of Adobe Reader or Acrobat.
              If you are the author of the PDF document or your know the password, you can remove the document restriction settings so that the PDF document will no longer be encrypted.  But you need to use the desktop version of Adobe Reader or Acrobat Pro/Standard to change the settings.
              Sorry for the inconvenience.
