1 Reply Latest reply on Apr 29, 2015 5:04 PM by A.T. Romano
    Quando cerco di condividere un video con l'opzione "in linea", non si apre la voce del menu e non vedo l'elenco dei social network dove pubblicare i contenuti. Cosa si può fare? Uso Windows7. Grazie. When I attempt to share my videos with the "on-line" op
    francescom5326621
      Quando cerco di condividere un video con l'opzione "in linea", dal menu "Pubblica / Condividi", non si apre la voce del menu e non vedo l'elenco dei social network dove pubblicare i contenuti. Cosa si può fare? Uso Win7. Grazie.
      When I attempt to share my videos with the "on-line" option, from "Publish /Share" window, I can't open the window and I don't see the list of social network to publish my contents. what can I do? I'm running on Windows7. Thank you
        • 1. Re: Quando cerco di condividere un video con l'opzione "in linea", non si apre la voce del menu e non vedo l'elenco dei social network dove pubblicare i contenuti. Cosa si può fare? Uso Windows7. Grazie. When I attempt to share my videos with the "on-line
          A.T. Romano Level 7
          francescom5326621
          What version of Premiere Elements do you have on your Windows 7 (assumed 64 bit) computer?
          Does the problem exist with and without the antivirus and firewall(s) disabled? Do you have a good connection to the Internet? Have you tried using another default browser? Have you gone to Edit Menu/Preferences/Web Sharing and refreshed Online Services?
          Do you have the latest version of QuickTime installed on your computer along with Premiere Elements? And are you running the programs as administrator?
          You can try deleting the Adobe Premiere Elements Prefs file, and, if that does not work, then delete the whole folder in which it exists. The path is
          Local Disk C
          Users
          Owner
          AppData
          Roaming
          Adobe
          Premiere Elements
          Folder with the number of your version
          and in that Folder is the Adobe Premiere Elements Prefs file that you delete. Be sure to be working with Folder Option Show Hidden Files, Folders, and Drives enabled so that you can see the complete path given.
          Is this a "it worked before but not now" or a "it never worked before" type problem. We may do a program uninstall/free ccleaner run through/reinstall with antivirus and firewall(s) disabled, but first let us look at the other considerations mentioned. Then we will plan troubleshooting strategy.
          CCleaner - Download
          Thank you.
          ATR
