5 Replies Latest reply on Nov 17, 2016 12:25 PM by bigband98
    Flash player download: Adobe download manager is blank
    MR.VAKSIN Level 1
      Hi everyone,
      I'm running in circles here trying to find a solution - not getting anywhere...
      I'm trying to update my Flash Player PPAPI for Opera on Windows 7 sp1
      When I download the installer and the Adobe Download Manager opens, it shows nothing and is blank, nothing happens.
      Here a screen shot:
      I have tried uninstalling Flash Player, but the same thing happens when reinstalling.
      JavaScript is active, I've checked that. Any other solutions I have googled don't apply.
      This My log in ADM folder Log : https://cloud.acrobat.com/file/8a6dfd3b-1c66-4d92-bcbb-0f8453df7ed3
      Thanks in advance!
        • 1. Re: Flash player download: Adobe download manager is blank
          piyush2508 Adobe Employee
          Hi MR.VAKSIN,
          To accurately identify the issue, and help us improve the online installer experience, we would really appreciate it if you could do the following for us:
          1. Perform a speed test on your internet connection.  There are a myriad of sites that do this, for example, www.speedtest.net, www.speakeasy.net/speedtest, www.dslreports.com/speedtest, and your internet provider may also have a page in their support/help section to do a speedtest.
          2. Create an empty text file in your %TEMP% directory named ADM.trace
            • On Vista and above the TEMP directory is usually located at C:\Users\Your_User_Name\Temp
          3. Run the online installer again and wait for the connection error.  After getting the error, close
          4. Open Windows Explorer and navigate to the Adobe_ADMLogs directory inside the TEMP directory
          5. Upload the two log files (Adobe_ADM.log and Adobe_GDE.log) using the instructions posted here https://forums.adobe.com/thread/1408375
          6. Reply back to this thread with the results of the download speed test and the URL to the uploaded log files.
          In the mean time, the offline installer posted at the bottom of the Installation problems | Flash Player | Windows page in the 'Still having problems' section should work for you.
          Thank you in advance.
          Piyush
          • 2. Re: Flash player download: Adobe download manager is blank
            MR.VAKSIN Level 1
            It is my speedtest : Speedtest.net by Ookla - My Results
            This was taken via Google Chrome on a Win7 machine and we select to save locally and then run from the download directory.
            I created the logs as requested and looked at the file Adobe_ADM.log and it's obvious at least to me where the issue lays.  Here are a couple of lines from that log:
            04/30/15 21:08:37:555 | [INFO] |  | ADM |  | ApplicationContext |  |  | 4852 | *********************** ADM Workflow start. Version: 1.0.0.14s **************************
            04/30/15 21:08:37:555 | [TRACE] |  | ADM |  | ApplicationContext |  |  | 4852 | Command Line : test.exe
            04/30/15 21:08:37:555 | [INFO] |  | ADM |  | ApplicationContext |  |  | 4852 | Admin and not child process. No need for IPC
            04/30/15 21:08:37:617 | [INFO] |  | ADM |  | ApplicationContext |  |  | 4852 | White listed URLs are
            04/30/15 21:08:37:617 | [INFO] |  | ADM |  | ApplicationContext |  |  | 4852 | get.adobe.com
            04/30/15 21:08:37:617 | [INFO] |  | ADM |  | ApplicationContext |  |  | 4852 | get2.adobe.com
            04/30/15 21:08:37:617 | [INFO] |  | ADM |  | ApplicationContext |  |  | 4852 | aihdownload.adobe.com
            04/30/15 21:08:37:617 | [INFO] |  | ADM |  | ApplicationContext |  |  | 4852 | admdownload.stage.adobe.com
            04/30/15 21:08:37:617 | [INFO] |  | ADM |  | ApplicationContext |  |  | 4852 | admdownload.adobe.com
            04/30/15 21:08:37:617 | [INFO] |  | ADM |  | ApplicationContext |  |  | 4852 | airdownload.adobe.com
            04/30/15 21:08:37:617 | [INFO] |  | ADM |  | ApplicationContext |  |  | 4852 | ardownload.adobe.com
            04/30/15 21:08:37:617 | [INFO] |  | ADM |  | ApplicationContext |  |  | 4852 | ardownload2.adobe.com
            04/30/15 21:08:37:617 | [INFO] |  | ADM |  | ApplicationContext |  |  | 4852 | download.macromedia.com
            04/30/15 21:08:37:617 | [INFO] |  | ADM |  | ApplicationContext |  |  | 4852 | fpdownload.macromedia.com
            04/30/15 21:08:37:617 | [INFO] |  | ADM |  | ApplicationContext |  |  | 4852 | fpdownload2.macromedia.com
            04/30/15 21:08:37:617 | [INFO] |  | ADM |  | ApplicationContext |  |  | 4852 | fpdownload.adobe.com
            04/30/15 21:08:37:617 | [INFO] |  | ADM |  | ApplicationContext |  |  | 4852 | fpdownload2.adobe.com
            04/30/15 21:08:37:617 | [INFO] |  | ADM |  | ApplicationContext |  |  | 4852 | platformdl.adobe.com
            04/30/15 21:08:37:617 | [INFO] |  | ADM |  | ApplicationContext |  |  | 4852 | platformdl-stage.corp.adobe.com
            04/30/15 21:08:37:617 | [INFO] |  | ADM |  | ApplicationContext |  |  | 4852 | wwwimages2.adobe.com
            04/30/15 21:08:37:617 | [INFO] |  | ADM |  | ApplicationContext |  |  | 4852 | wwwimages.adobe.com
            04/30/15 21:08:37:617 | [INFO] |  | ADM |  | ApplicationContext |  |  | 4852 | wwwimages.stage.adobe.com
            04/30/15 21:08:37:617 | [INFO] |  | ADM |  | ApplicationContext |  |  | 4852 | wwwimages2.stage.adobe.com
            04/30/15 21:08:37:617 | [INFO] |  | ADM |  | ApplicationContext |  |  | 4852 | dlmping.adobe.com
            04/30/15 21:08:37:617 | [INFO] |  | ADM |  | ApplicationContext |  |  | 4852 | dlmping2.adobe.com
            04/30/15 21:08:37:617 | [INFO] |  | ADM |  | ApplicationContext |  |  | 4852 | dlmping3.adobe.com
            04/30/15 21:08:37:617 | [INFO] |  | ADM |  | ApplicationContext |  |  | 4852 | dlmping4.adobe.com
            04/30/15 21:08:37:617 | [INFO] |  | ADM |  | ApplicationContext |  |  | 4852 | get3.adobe.com
            04/30/15 21:08:37:617 | [INFO] |  | ADM |  | ApplicationContext |  |  | 4852 | get3.stage.adobe.com
            04/30/15 21:08:37:617 | [INFO] |  | ADM |  | ApplicationContext |  |  | 4852 | adobetag.com
            04/30/15 21:08:37:617 | [INFO] |  | ADM |  | ApplicationContext |  |  | 4852 | promotion.adobe.com
            04/30/15 21:08:37:617 | [INFO] |  | ADM |  | ApplicationContext |  |  | 4852 | stats.adobe.com
            04/30/15 21:08:37:617 | [INFO] |  | ADM |  | ApplicationContext |  |  | 4852 | sstats.adobe.com
            04/30/15 21:08:37:617 | [INFO] |  | ADM |  | ApplicationContext |  |  | 4852 | White listed Machine Registries are
            04/30/15 21:08:37:617 | [INFO] |  | ADM |  | ApplicationContext |  |  | 4852 | system\currentcontrolset\control\session manager\environment\
            04/30/15 21:08:37:617 | [INFO] |  | ADM |  | ApplicationContext |  |  | 4852 | software\microsoft\windows nt\currentversion\
            04/30/15 21:08:37:617 | [INFO] |  | ADM |  | ApplicationContext |  |  | 4852 | software\microsoft\windows\currentversion\uninstall\
            04/30/15 21:08:37:617 | [INFO] |  | ADM |  | ApplicationContext |  |  | 4852 | software\wow6432node\microsoft\windows\currentversion\uninstall\
            04/30/15 21:08:37:617 | [INFO] |  | ADM |  | ApplicationContext |  |  | 4852 | software\microsoft\windows\currentversion\app paths\
            04/30/15 21:08:37:617 | [INFO] |  | ADM |  | ApplicationContext |  |  | 4852 | software\macromedia\
            04/30/15 21:08:37:617 | [INFO] |  | ADM |  | ApplicationContext |  |  | 4852 | software\adobe\setup\reader\
            04/30/15 21:08:37:617 | [INFO] |  | ADM |  | ApplicationContext |  |  | 4852 | software\wow6432node\adobe\setup\reader\
            04/30/15 21:08:37:617 | [INFO] |  | ADM |  | ApplicationContext |  |  | 4852 | White listed User Registries are
            04/30/15 21:08:37:617 | [INFO] |  | ADM |  | ApplicationContext |  |  | 4852 | software\microsoft\windows\shell\associations\urlassociations\
            04/30/15 21:08:37:617 | [INFO] |  | ADM |  | ApplicationContext |  |  | 4852 | Actual OS locale:'en_US', OS locale for this instance:'en_US', ADM locale : en
            04/30/15 21:08:37:617 | [TRACE] |  | ADM |  | WorkflowManager |  |  | 4852 | Initializing application.
            04/30/15 21:15:03:827 | [TRACE] |  | ADM |  | ApplicationContext |  |  | 4852 | About to open URL
            04/30/15 21:15:03:827 | [TRACE] |  | ADM |  | ApplicationContext |  |  | 4852 | Default browser : "c:\program files (x86)\google\chrome\application\chrome.exe" -- "%1"
            04/30/15 21:15:03:889 | [TRACE] |  | ADM |  | ApplicationContext |  |  | 4852 | URL opened : https://get.adobe.com/flashplayer/
            04/30/15 21:15:03:920 | [INFO] |  | ADM |  | ApplicationContext |  |  | 4852 | *********************** ADM Workflow end. Version: 1.0.0.14s **************************
            • 3. Re: Flash player download: Adobe download manager is blank
              m_vargas Adobe Employee
              Hi MR.VAKSIN,
              Thank you for providing the log file. I have forwarded it to the folks who handle the online installer.
              Maria
              • 4. Re: Flash player download: Adobe download manager is blank
                Amsxae Level 1
                [UPDATE - SOLUTION!]
                I navigated to the help site, and downloaded the Flash Player for Firefox - NPAPI
                And it worked! *Use the uninstaller first to clear all installations!
                However, I STILL can't install adobe reader. :/
                Hi.
                I have the exact same problem, and have searched the net for solutions.. But came up short.
                There are NO support for this anywhere, and it's quite dissapointing.
                Note. Same problem with Adobe Reader: Manager just goes blank and opens IE instead of firefox.
                Please advise... I have no flash now.
                • 5. Re: Flash player download: Adobe download manager is blank
                  bigband98 Level 1
                  I am having the EXACT same problem.The download manager goes blank and that is as far as it goes.This never used to be the case.What download speeds have to do with the problem is beyond me.I have used the same server for years and nothing has changed speed wise.Yet until recently Abobe installation worked fine.And now it does not.Something is definitely rotten in Adobe land...but what?
