Seems like this should be pretty straight forward but apparently not.
I've tried various combinations, placing xfa.host.beep(1) in:
- consecutively in the click event of button;
- separately in the mouseUp and click event;
- placing xfa.host.beep into a function and calling the function twice
- calling the function then xfa.host.beep(1);
Even tried xfa.host.beep(1) in the click event of Button1 and then executing the click event of hidden Button 2, which contained xfa.host.beep(1).
Any work around suggestions? Thanks!
Brian
Solved! Go to Solution.
Views
Total Likes
Hi Brian,
Try this;
xfa.host.beep(1)
app.setTimeOut("xfa.host.beep(1)",500);
Which calls the beep, then half a second (or 500 m/s) later calls it again.
Regards
Bruce
Views
Total Likes
Hi Brian,
Try this;
xfa.host.beep(1)
Regards
Bruce
Views
Total Likes
Bruce -
Thanks for the great response; works perfectly.
As a follow-up, could xfa.host.beep(1) be placed within the code for a custom dialog? So rather than calling the beep first, then triggering the dialog box, just place xfa.host.beep(1) within the dialog code so when the dialog box appears, the beep is triggered? I've tried placing it in various locations within a dialog's code without out success.
Thanks much again.
B
Views
Total Likes
You could pass in the xfa.host object so you could call the beep() method. But in a custom dialog the setTimeOut doesn't work, so you could try looping for half a second between beeps.
function dialog()
var dialogDescriptor =
description:
elements: [
type: "button",
item_id: "beep",
type: "ok",
beep : function(dialog)
dialogObject.host.beep(1);
var startTime = Date.now();
while (Date.now() - startTime < 500) { }
validate : function(dialog)
//add validate code here
return true;
var dialogObject =
execDialog: function() { return app.execDialog(dialogDescriptor); },
return dialogObject;
var d = dialog();
d.host = xfa.host;
d.execDialog();
Acrobat also has an app.beep(1) which you could use.
Regards
Bruce
Views
Total Likes
Copy all. Thanks, as always, Sensei.
Best,
Brian
Views
Total Likes
