5 Replies Latest reply on May 2, 2015 5:42 PM by A.T. Romano
    can't upload from premiere elements to youtube
    janicey38892545
      I'm trying to upload a 25 minute video to youtube. It says the following: "The video duration exceeds the maximum duration supported by the destination. Please reduce the duration of the video and try again."
      youtube supports videos of this size now.  How can I get past this?  Thanks!
        • 1. Re: can't upload from premiere elements to youtube
          Unfortunately, you can't upload a file that size directly from Premiere Elements. (In fact, even YouTube requires a special account for a file that size, I believe.)
          In any event, you can still try outputting the file manually and manually uploading it to Youtube.
          You didn't say which version of the program you're using but, in version 13, the best way to output a video for YouTube is to go to Publish & Share/Computer/AVCHD and select the YouTube HD option. This will create an MP4 that is perfect for uploading.
          • 2. Re: can't upload from premiere elements to youtube
            A.T. Romano Level 7
            janicey
            For your workaround, you have been pointed to Publish+Share/Computer/AVCHD with Presets = YouTube Widescreen HD.
            The default for that preset is 1280 x 720 @ 24 progressive frames per second with a bitrate of 8 Mbps (megabits per second).
            If you want other than that default setting, you can customize that preset to 1920 x 1080 @ 29.97 or 25 progressive frames as well under the Advanced Button Video tab of the preset. Determine if the bitrate needs adjustment and the file size is acceptable
            You might also want to explore using Presets = MP4 - H.264 1920 x 1080p30 (or 25 as appropriate) and customize the preset under the Advanced Button/Video Tab of the preset. Watch the file size.
            If you are OK with the 1280 x 720 for quality and file size, then please disregard the suggestion for this. If you are interested in the suggestion, do not hesitate to ask questions or ask for clarification if needed.
            ATR
            • 3. Re: can't upload from premiere elements to youtube
              janicey38892545 Level 1
              Steve:Thanks so much for this info.  It worked. Even though I'm using version 11 I was still able to follow your instructions and get my video on youtube.
              Saved me a lot of hassle. Thanks again.Jan
              To: Janice Yuvan <jayuvan@yahoo.com>
              Sent: Saturday, May 2, 2015 9:20 AM
              Subject:  can't upload from premiere elements to youtube
              created by Steve Grisetti in Premiere Elements - View the full discussionUnfortunately, you can't upload a file that size directly from Premiere Elements. (In fact, even YouTube requires a special account for a file that size, I believe.) In any event, you can still try outputting the file manually and manually uploading it to Youtube. You didn't say which version of the program you're using but, in version 13, the best way to output a video for YouTube is to go to Publish & Share/Computer/AVCHD and select the YouTube HD option. This will create an MP4 that is perfect for uploading. If the reply above answers your question, please take a moment to mark this answer as correct by visiting: https://forums.adobe.com/message/7505218#7505218 and clicking ‘Correct’ below the answer Replies to this message go to everyone subscribed to this thread, not directly to the person who posted the message. To post a reply, either reply to this email or visit the message page: Please note that the Adobe Forums do not accept email attachments. If you want to embed an image in your message please visit the thread in the forum and click the camera icon: https://forums.adobe.com/message/7505218#7505218 To unsubscribe from this thread, please visit the message page at , click "Following" at the top right, & "Stop Following"  Start a new discussion in Premiere Elements by email or at Adobe Community For more information about maintaining your forum email notifications please go to https://forums.adobe.com/thread/1516624.
              • 4. Re: can't upload from premiere elements to youtube
                Thanks A.T.  So far the default setting are working just fine, but this is good info in case that changes.Jan
                Sent: Saturday, May 2, 2015 11:30 AM
                created by A.T. Romano in Premiere Elements - View the full discussionjanicey For your workaround, you have been pointed to Publish+Share/Computer/AVCHD with Presets = YouTube Widescreen HD.The default for that preset is 1280 x 720 @ 24 progressive frames per second with a bitrate of 8 Mbps (megabits per second). If you want other than that default setting, you can customize that preset to 1920 x 1080 @ 29.97 or 25 progressive frames as well under the Advanced Button Video tab of the preset. Determine if the bitrate needs adjustment and the file size is acceptable You might also want to explore using Presets = MP4 - H.264 1920 x 1080p30 (or 25 as appropriate) and customize the preset under the Advanced Button/Video Tab of the preset. Watch the file size. If you are OK with the 1280 x 720 for quality and file size, then please disregard the suggestion for this. If you are interested in the suggestion, do not hesitate to ask questions or ask for clarification if needed. ATR If the reply above answers your question, please take a moment to mark this answer as correct by visiting: https://forums.adobe.com/message/7505552#7505552 and clicking ‘Correct’ below the answer Replies to this message go to everyone subscribed to this thread, not directly to the person who posted the message. To post a reply, either reply to this email or visit the message page: Please note that the Adobe Forums do not accept email attachments. If you want to embed an image in your message please visit the thread in the forum and click the camera icon: https://forums.adobe.com/message/7505552#7505552 To unsubscribe from this thread, please visit the message page at , click "Following" at the top right, & "Stop Following"  Start a new discussion in Premiere Elements by email or at Adobe Community For more information about maintaining your forum email notifications please go to https://forums.adobe.com/thread/1516624.
                • 5. Re: can't upload from premiere elements to youtube
                  A.T. Romano Level 7
                  Jan
                  Thanks for the good news of your success obtaining a suitable Premiere Elements export for upload to YouTube at the YouTube web site.
                  Good job of follow through.
                  If you decide to explore the choices beyond the YouTube Widescreen HD preset, please do not hesitate to ask if any questions on that.
                  Best wishes
                  ATR
