5 Replies Latest reply on May 3, 2015 4:48 AM by JJMack
    How do I find the menuID for the Photoshop Transform menu
    caughtnapping Level 1
      I am new to using ExtendScript and want to create a script that starts by selecting Transform >> Skew. The JavaScript script reference mentions the method 'runMenuItem' but I don't know how to find the menuID to use it.
        • 1. Re: How do I find the menuID for the Photoshop Transform menu
          Philip Cord Level 4
          You create an action to select it using insert menuitem, then look at the scriptlistner output, from this you can use.
          try{
          app.runMenuItem(charIDToTypeID('Skew'));
          }catch(e){};
          • 2. Re: How do I find the menuID for the Photoshop Transform menu
            cTID = function(s) { return app.charIDToTypeID(s); };
            sTID = function(s) { return app.stringIDToTypeID(s); };
            //==================== Interactive Transform ==============
            function InteractiveTransform() {
              // Menu Edit>Free transform
                var desc1 = new ActionDescriptor();
                var ref1 = new ActionReference();
                ref1.putEnumerated(cTID('Mn  '), cTID('MnIt'), cTID('FrTr'));
                desc1.putReference(cTID('null'), ref1);
                executeAction(cTID('slct'), desc1, DialogModes.NO);
            Photoshop Javascript guide Appendix A: Event ID Codes has  all the cods like FrTr  for transform
            use Scriptlistener Plugin to record Action manager code.  Create functions the uset the functions.
            try{
              }catch(e){alert("Image Transform Canceled");}
            • 3. Re: How do I find the menuID for the Photoshop Transform menu
              Thanks for that....now if only I could get ScriptListener to work with Photoshop CC 2014. Not sure it's compatible yet as it doesn't show under Extensions after being placed in the Plugins folder and rebooting. Any suggestions?
              • 4. Re: How do I find the menuID for the Photoshop Transform menu
                Philip Cord Level 4
                Sorry can't help as I only have CS6.
                • 5. Re: How do I find the menuID for the Photoshop Transform menu
                  You need to download the correct version of scriptlistener for cc 2014 Adobe Photoshop Scripting | Adobe Developer Connection
                  On my windows system I have it installed at all times.  Which will make  recording Photoshop tool recording while recordind actions impossible for Adobe disables that Photoshop feature when  the scriptlistener Plug-in is installed.  Which I do not mind for the Photoshop tool recording features was not designed or implemented well.  Actions with tools recordings also only work when the actions are used on documents the same size and resolution that the actions were recorded.
                  With the Script listener plug-in installed on my Windows system I prevent the log files from becoming large by making them READ only.  When I want the plugin to actually record what I do ins Jacascript.  I will start a little Windows BAT file to control to control and utilize the Javascript log file.  The bat file is in a little Line Command  window in the lower right corner of my display. With it I control the Javascript log file Read only attribute so I can turn on and off the recording. The bat also enables me to extract what I need from the log file and also and can also clear out the log file .
                         @Echo Off
                  :loop
                         CLS
                  rem Display Log File Size
                         Dir "%USERPROFILE%\Desktop\ScriptingListenerJS.log" /T:W /4 | find "%ScriptingListenerJS.log"
                  rem Display Log Attributes  R read only Locked no R log is Unlocked
                         Attrib "%USERPROFILE%\Desktop\ScriptingListenerJS.log"
                  Rem If timeout is use the above display lines will refresh over time else you need to use enter or number
                         CHOICE /C 123456 /N /T 300 /D 6 /M "Enter:1 to Lock, 2 to Unlock, 3 to Edit, 4 to Clear, 5 To Exit :"
                         Echo %ERRORLEVEL%
                          if %ERRORLEVEL%==6 goto timeout
                          if %ERRORLEVEL%==1 goto one
                          if %ERRORLEVEL%==2 goto two
                          if %ERRORLEVEL%==3 goto three
                          if %ERRORLEVEL%==4 goto four
                          if %ERRORLEVEL%==5 goto five
                           goto loop
                  :timeout
                         goto loop
                  :one
                         Attrib +R "%USERPROFILE%\Desktop\ScriptingListenerJS.log"
                         goto loop
                  :two
                         Attrib -R "%USERPROFILE%\Desktop\ScriptingListenerJS.log"
                         goto loop
                  :three
                         Rem inline command use CMD independent command use start
                         CMD /C notepad "%USERPROFILE%\Desktop\ScriptingListenerJS.log"
                         rem Start notepad "%USERPROFILE%\Desktop\ScriptingListenerJS.log"
                         goto loop
                  :four
                         Rem If the script log file is unlocked not read only  this echo will clear it
                         Echo. > "%USERPROFILE%\Desktop\ScriptingListenerJS.log"
                        goto loop
                  :five
                        EXIT
