2 Replies Latest reply on May 2, 2015 3:10 PM by LR_Mowang
    Problem exiting Lightroom 6
    LR_Mowang Level 1
      Ever since installing Lightroom 6 I have had a problem with a clean exit. When I choose File > Exit>  I get the error window saying there was an issue with Lightroom and do I want to close the program. This happens about 50% of the time. The other times it seems to work cleanly.  When looking at the error information I get the Following:
      Problem signature:
         Problem Event Name:    APPCRASH
         Application Name:    Adobe QT32 Server.exe
         Application Version:    8.0.0.0
         Application Timestamp:    535600cc
         Fault Module Name:    QuickTime.qts_unloaded
         Fault Module Version:    0.0.0.0
         Fault Module Timestamp:    542dbdf4
         Exception Code:    c0000005
         Exception Offset:    5e2bccf9
         OS Version:    6.1.7601.2.1.0.256.48
         Locale ID:    1033
         Additional Information 1:    0a9e
         Additional Information 2:    0a9e372d3b4ad19135b953a78882e789
         Additional Information 3:    0a9e
         Additional Information 4:    0a9e372d3b4ad19135b953a78882e789
      I have tried to re-install Lightroom 6 and the problem continues to occur. I am not having any other problems with the system or programs and this started with LR6.  This is running on a Windows 7 Pro OS.  Oh... I have even upgrade my video drivers.
      Others having this issue or any ideas??
        • 1. Re: Problem exiting Lightroom 6
          Alain Capéran Level 1
          obviously it's a problem with Quicktime have you install it? It's needed by Lightroom if you want to use video.
          Check to re-install or uninstall QuickTime? And it seems that you don't have the last version.
          It's an awful software under windows, I never install it on my actual system (windows 7).
          • 2. Re: Problem exiting Lightroom 6
            LR_Mowang Level 1
            Thanks...
            I did have some video and it seemed to work fine within Lightroom.  I checked Quicktime and found it was failing after executing and would not even come in a standalone mode. Re-installed and now Quicktime works..  I have not had the problem with Lightroom since..  hope this has been the fix...  thanks again.
