10 Replies Latest reply on Jan 16, 2007 4:44 AM by pj20
    parabola in director
    pj20
      hello,
      this is the first time i use this site. i have been told that this is a good place to get help with using director. in director on the main stage i have drawn a ball, what i want to do, i want it to move up into the air and then drop again in the shape of a wide parabola. i have tried the following code: y=ax^2+bx+c, with a=-0.5, b=50 and c=5, but i must have got something wrong. can anyone help me with this? let me know where i am going wrong and what formula i should use instead?
      thanks
      pj20
        • 1. Re: parabola in director
          johnAq
          Check out this great site animation math in lingo
          http://www.jmckell.com/
          hth
          johnAq
          • 2. Re: parabola in director
            the real POTMO Level 1
            you can always make it with a spline or a vectorshape. should be fairly easy to first make a circle and then reshape it into a parabola
            • 3. Re: parabola in director
              pj20 Level 1
              Thanks for your help but i still have not got anywhere i need to have the equation written in lingo code .. i will be shooting a cannon ball from a cannon so i need to no how to write the equation out so i can attach this to the frame
              jacs
              • 4. Re: parabola in director
                Level 7
                You might just have to do a bit of searching when someone offers a URL. I
                spent, well, maybe 30 seconds and came up with this
                http://www.jmckell.com/generalgravity.html
                What you're looking for is really a gravity equation. This will take care
                of your vertical movement. Since mass travels at a constant velocity you
                can animate using a constant change in the locH and use the gravity math to
                calculate the vertical change as it rises and falls.
                Craig Wollman
                Lingo Specialist
                Word of Mouth Productions
                212-928-9581
                www.wordofmouthpros.com
                "pj20" <webforumsuser@macromedia.com> wrote in message
                news:eo3l2e$nsm$1@forums.macromedia.com...
                > hello,
                > good
                > have
                > then
                > code:
                > wrong.
                > thanks
                > pj20
                • 5. Re: parabola in director
                  Level 7
                  I meant to say constant horizontal velocity.
                  Craig Wollman
                  Lingo Specialist
                  212-928-9581
                  "forum.macromedia.com" <lingoboy@wordofmo.com> wrote in message
                  news:eo8obs$323$1@forums.macromedia.com...
                  > to calculate the vertical change as it rises and falls.
                  > Craig Wollman
                  > Lingo Specialist
                  > 212-928-9581
                  >> hello,
                  >> good
                  >> have
                  >> then
                  >> code:
                  >> wrong.
                  >> thanks
                  >> pj20
                  • 6. Re: parabola in director
                    Level 7
                    You might also be interested in looking at the Bezier Curve Xtra
                    http://www.the-mindseye.co.uk/prog/beziercurve.shtml
                    I haven't used it but from my understanding, you can create a curve and link an
                    animation to it. So, you may be able to create that curve based on some
                    mathematical formula and set it as your animation path.
                    regards
                    Dean
                    Director Lecturer / Consultant
                    http://www.fbe.unsw.edu.au/learning/director
                    http://www.multimediacreative.com.au
                    • 7. Re: parabola in director
                      Level 7
                      FWIW, there's a tutorial on creating a ballistic motion simulation in my
                      first book: Director 8.5 The Complete Reference...chapter 6. It's for 8.5
                      but nothing has changed as far as this goes. You can get a copy pretty
                      cheaply these days too...
                      Dave -
                      Head Developer
                      www.blurredistinction.com
                      Adobe Community Expert
                      http://www.adobe.com/communities/experts/
                      • 8. Re: parabola in director
                        oh now i understand what you want to do.
                        You want to simulate the ball flying from a cannon.
                        this is called the Euler Integration (i think):
                        You can do it a lot more accurate but thats another story,
                        Anyway you might have to tweak the values and constants to make it look good.
                        property pVel, pPos, pAirFriction, pGravityConstant
                        on beginSprite me
                        pPos = point(100,100)
                        pVel = point(3,-3) -- 40 degrees up
                        pGravityConstant = point(0, 0.9)
                        pAirFriction = 0.09
                        end
                        on exitFrame me
                        -- this will step the position each frame with the velocity
                        -- it will remove some speed in the bullet due to air friction
                        -- the gravity will pull it down
                        pPos = pPos + pVel*pAirFriction + pGravityConstant
                        --remember its good to keep the position and velocity in a variable
                        -- instead of using sprite(x).loc cos' its only integer not float so you loose som
                        -- precision.
                        sprite(me.spritenum).loc = pPos
                        end
                        you can of cource calculate where the ball will be at any given moment with a function but i think youll have to solve that out your self.
                        i can give you some links for help:
                        http://en.wikipedia.org/wiki/Trajectory
                        http://scienceworld.wolfram.com/physics/Trajectory.html
                        • 9. Re: parabola in director
                          pj20 Level 1
                          Thanks for your reply does all the code go onto one frame
                          • 10. Re: parabola in director
                            pj20 Level 1
                            I have it working the ball fires at a angle but just keeps going how would i bring it down because the gravity variable is not doing much could you help please ....
                            pj20
