• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
IDENTITY_INSERT is set to OFF.
New Here ,
May 02, 2015 May 02, 2015
I have a dynamic site.
When I insert an integer (a whole number) in a raw materials purchase table, I get the following message:
Error Executing Database Query.
[Macromedia][SQLServer JDBC Driver][SQLServer]Cannot insert explicit value for identity column in table 'tblRawMatlPurch' when IDENTITY_INSERT is set to OFF.
When I change to or insert a numeric, decimal, or money value, I get the following message:
Raw Materials Decision
Company:  Grande
You have NOT successfully submitted the Raw Materials Decision form
Please note that the purchase amount must be a whole number, please do not enter a decimal for this number.
Return to correct
I have two programs: one is in the secure section, and the name is secure/raw_materials_decision_action, indicating that the raw material purchase variable (rawMat) is a money variable. Giving this information I set it in SQL as a money variable. Here is the file:
<!---  get Company Name --->
<cfquery name="getCompany" datasource="#application.dsn#">
  Select companyName
  From tblCompNames
  Where companyID=<cfqueryparam cfsqltype="cf_sql_integer" value="#getAuthUser()#">
</cfquery>
<cfparam name="form.changes" default="">
<cfset error = "">
<!--- All users must have raw materials associated with city and product when user profile created --->
<!--- update action --->
<cfif form.changes NEQ "">
<!---  go through changes - if they changed cost or selling price, will contain cost_id --->
  <cfloop index="x" list="#form.changes#">
  <cfif trim(x) NEQ "">
  <cfset thisSalesOrderID = trim(x)>
  <cfset thisRawMatID = form["rawMatID_#thisSalesOrderID#"]>
  <cfset thisCity = form["cityID_#thisSalesOrderID#"]>
  <cfset thisProduct = form["productID_#thisSalesOrderID#"]>
  <cfset thisPurchase = form["purchase_#thisSalesOrderID#"]>
  <cfif thisPurchase NEQ "" AND (not isNumeric(thisPurchase) OR thisPurchase CONTAINS ".")>
  <cfset error = "yes">
  </cfif>
  <cfif error EQ "">
  <cfquery name="getRow" datasource="#application.dsn#">
  Select *
  From tblRawMatlPurch
  WHERE SalesOrderID=<cfqueryparam cfsqltype="cf_sql_integer" value="#thisSalesOrderID#">
  </cfquery>
  <cfif getRow.RawMat NEQ thisPurchase>
  <cfif getRow.recordCount NEQ 0 AND trim(thisPurchase) NEQ "">
  <cfquery name="updateRow" datasource="#application.dsn#">
  Update tblRawMatlPurch
  Set CityID = <cfqueryparam cfsqltype="cf_sql_integer" value="#thisCity#">
  , ProductID = <cfqueryparam cfsqltype="cf_sql_integer" value="#thisProduct#">
  , RawMatID = <cfqueryparam cfsqltype="cf_sql_integer" value="#thisRawMatID#">
  , RawMat = <cfqueryparam cfsqltype="cf_sql_money" value="#trim(thisPurchase)#">
  </cfquery>
  <cfelseif getRow.recordCount NEQ 0 AND trim(thisPurchase) EQ "">
  <cfquery name="deleteRow" datasource="#application.dsn#">
  Delete From tblRawMatlPurch
  </cfquery>
  <cfelseif getRow.recordCount EQ 0 AND thisPurchase NEQ "">
  <cfquery name="insertRow" datasource="#application.dsn#">
  Insert Into tblRawMatlPurch
  (SalesOrderID,companyID,cityID, productID,RawMatID,RawMat)
  VALUES
  (<cfqueryparam cfsqltype="cf_sql_integer" value="#thisSalesOrderID#">,<cfqueryparam cfsqltype="cf_sql_integer" value="#getAuthUser()#">, <cfqueryparam cfsqltype="cf_sql_integer" value="#thisCity#">, <cfqueryparam cfsqltype="cf_sql_integer" value="#thisProduct#">,<cfqueryparam cfsqltype="cf_sql_integer" value="#thisRawMatID#">,<cfqueryparam cfsqltype="cf_sql_money" value="#trim(thisPurchase)#">)
  </cfquery>
  </cfif>
  </cfif>
  </cfif>
  </cfif>
  </cfloop>
</cfif>
However, I have a second program in the files section: the raw material decision, which indicates that the variable must be an integer (a whole number).
<!---  Text Content for Raw Materials Decision Form
  DO NOT CHANGE ANY FORM NAMES OR ADD NEW FORM NAMES
  <input type="text" name="DO NOT CHANGE". . .>
  See raw_materials_decison_es.html for Spanish version of this file --->
<!---  User can enter just one purchase
  - the next time they use this screen it will show blank city/product/raw material purchases
  error message if they do not enter numeric value --->
<!---  get Materials for this company --->
<cfquery name="getMaterials" datasource="#application.dsn#">
  SELECT SalesOrderID, CityID, ProductID, RawMatID
  FROM tblRawMatID
  WHERE CompanyID=<cfqueryparam cfsqltype="cf_sql_integer" value="#getAuthUser()#">
  ORDER BY cityID, productID, rawMatID
</cfquery>
<!--- set Company name --->
<cfset thisCompany = getCompany.companyName>
<table width="600" border="0" cellpadding="5" align="center">
  <cfoutput>
  <tr>
  <td colspan="5" align="right">
  <a href="logout.cfm" style="text-decoration:none; font-weight:bold;">LOGOUT</a>
  </td>
  </tr>
  <tr>
  <td colspan="5">
  <h2>Raw Materials Decision</h2>
  <h5>Company:  #thiscompany#</h5>
  </td>
  </tr>
  </cfoutput>
<!---  Action display --->
  <!--- Error Message - if there --->
  <cfif error NEQ "">
  <tr>
  <td colspan="5">
  <p>
  </p>
  <p>
  <br /><br />
  <a href='Javascript: history.back();'>Return to correct</a>
  </p>
  </td>
  </tr>
  <cfelse>
  <tr>
  <td colspan="5">
  <p>
  Thank you for your submission.
  </p>
  </td>
  </tr>
  </cfif>
<!---  START FORM --->
<cfelse>
  <!---  Show Materials already entered when Company set up --->
  <form action="raw_materials_decision.cfm" method="post" name="materials">
  <!---  changes hold the ID for any values that are changed to minimize time to check for changes
  - uses onChange in form input to send ID --->
  <input type="hidden" name="changes" value="" />
  <!--- top column headings for table --->
  <tr>
  <th>
  City
  </th>
  <th>
  Product
  </th>
  <th>Raw Materials</th>
  <th>
  Price</th>
  <th align="center">
  Purchase
  </th>
  </tr>
  <cfoutput query="getMaterials">
  <cfquery name="getCity" datasource="#application.dsn#">
  Select cityName
  From tblCities
  Where cityID = <cfqueryparam cfsqltype="cf_sql_integer" value="#getMaterials.cityID#">
  </cfquery>
  <cfquery name="getProduct" datasource="#application.dsn#">
  Select productName
  From tblProductCategories
  Where productID = <cfqueryparam cfsqltype="cf_sql_integer" value="#getMaterials.productID#">
  </cfquery>
  <cfquery name="getMaterial" datasource="#application.dsn#">
  Select rawMatDescription
  From tblRmatCategory
  Where rawMatID = <cfqueryparam cfsqltype="cf_sql_integer" value="#getMaterials.rawMatID#">
  </cfquery>
  <cfquery name="getPrice" datasource="#application.dsn#">
  Select rawMatPrice
  From tblRawmatPrices
  AND cityID= <cfqueryparam cfsqltype="cf_sql_integer" value="#getMaterials.cityID#">
  </cfquery>
  <cfquery name="getPurch" datasource="#application.dsn#">
  SELECT RawMat
  FROM tblRawMatlPurch
  WHERE companyID=<cfqueryparam cfsqltype="cf_sql_integer" value="#getAuthUser()#">
  AND cityID = <cfqueryparam cfsqltype="cf_sql_integer" value="#getMaterials.cityID#">
  AND productID = <cfqueryparam cfsqltype="cf_sql_integer" value="#getMaterials.productID#">
  AND rawMatID =  <cfqueryparam cfsqltype="cf_sql_integer" value="#getMaterials.RawMatID#">
  </cfquery>
  <tr>
  <td>
  #getCity.cityName#
  <input type="hidden" name="cityID_#salesOrderID#" value="#cityID#" />
  </td>
  <td>
  #getProduct.productName#
  <input type="hidden" name="productID_#salesOrderID#" value="#productID#" />
  </td>
  <td>
  #getMaterial.RawMatDescription#
  <input type="hidden" name="rawMatID_#salesOrderID#" value="#RawMatID#">
  </td>
  <td>
  #dollarFormat(getPrice.rawMatPrice)#
  </td>
  <td align="center">
  <input  name="purchase_#salesOrderID#" type="text" value="#getPurch.rawMat#" size="12" onchange="document.materials.changes.value=document.materials.changes.value + ', #salesOrderID#';" />
  </td>
  </tr>
  </cfoutput>
  <!--- blank space before submit button --->
  <tr>
  <td colspan="5">
  <br />
  </td>
  </tr>
  <!--- submit buttons --->
  <tr>
  <td colspan="5">
  <input type="submit" value="Submit Raw Materials" />
  <input type="reset" value="Reset">
  </td>
  </tr>
  </form>
</cfif>
</table>
I understand there is a conflict between the secure/raw_materials_decision_action program and the raw materials decision program, except, that I do not know how to fix it.
Perhaps, I could change, the raw materials variable from money to integer. But, I am not sure this will solve the problem.
Alternatively, I could try to change the raw_materials_decision, specification, to accept a decimal, numeric, or money variable, but, I have been revieweing the file, and I do not know how to make this change.
It is not obvious to me.
Is there anyone who could help with this problem to find a best possible solution?
I would appreciate the assistance very much.
Thank you.
Views
784
Translate
Translate
Report
Report
Community guidelines
community guidelines
Advocate ,
May 04, 2015 May 04, 2015
TL;DR. The error you are receiving is from SQL. Identity fields are auto-assigned by the SQL server and you are sending a prepopulated value, thus the error. I can't really tell you how to easily fix this because I'm not sure what the app is trying to do nor do I know the underlying database schema. The most likely solution is to not send the identity value in your insert query and then use select @@identity if you require the auto-assigned value.
Votes
Translate
Translate
Report
Report
New Here ,
LATEST
I m working on your comment. Thanks!
Votes
Translate
Translate
Report
Report
Resources
Documentation
